bolt size help
what are the bell housing bolt size and the 2 bolts #21 on the rear mount bottom #10
http://www.acuraoemparts.com/delray/...All&vinsrch=no and yes i have searched and yes i looked in Common Honda Bolt thread pitch size dimension thread |
Re: bolt size help
The acura page lists #21 as "BOLT, FLANGE (14X67)", so it's M14 by 67 millimeters length. Also, the common bolt thread lists it as M14 x 1.25 thread pitch. The trans bolts should be M12 x 1.25. The lengths will probably be on the acura parts site.
Re: bolt size help
i have a 12x1.25 die and it does not work with the tranny bolts
Re: bolt size help
Originally Posted by dkrex001
(Post 37007205)
Re: bolt size help
Originally Posted by vietnamezerice
(Post 37008997)
not a 12mm an M12... should be a 17mm
Re: bolt size help
The 12x1.25 die is to small
And does any one know the size for the rear mount bolts #21 Any help |
Re: bolt size help
(Post 37011947)
And does any one know the size for the rear mount bolts #21 Any help Helms lists the thread size and pitch, but I don't have it handy right now. |
Re: bolt size help
i tried the 12x1.25 die on the bolts that every one says is 12x1.25 like the bolts that mount the tranny to the motor and the die is to small.
for the other ones like #21 i know are bigger just do not know the size ok i found out that my die was to small mismarked 12x1.25 is the size sorry and thanks and the bolts for #21 are 14x1.5 |
