BLOX Intake Manifold How-To Install
#54
Re: (OUTKAST_R)
wow, nice write up... but that looks like a pain in the *** to install
i'd get one for $200 if i wasn't so lazy
does the butt dyno detect any gains?
#58
Re: (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">Great thread, I just hope the pics stay up!
Nice right up!</TD></TR></TABLE>
No, i'll make sure I keep the pics up as long as I still have my domain name, heh.
Modified by Honda Hick at 9:26 AM 3/31/2005
#59
Re: (Honda Hick)
Im assuming that the install for this intake manifold on the GSR will be the same for an EG hatch? Im gonna be installing mine pretty soon and Im about to head out for some parts.
#60
Re: (ringgold)
Do you mean a B18C1 in a hatch? If so, then it should be pretty much the same I would think. The air intake might be a little different though. I would expect the fuel lines, etc. to be in the same locations.
#61
Re: (Honda Hick)
Yeah its a JDM B18C but its basically the USDM version with more hp. I just went to the Acura dealership and bought an ITR throttle cable and bracket and the gaskets that are needed. Now I need to locate the tb pulley and spring. I had one of those buts its gone now.
#62
Re: (ringgold)
Try and find a round pulley, not a ear-shaped pulley. That way you don't have to worry about adjusting that non-adjustable screw. It can be a real pain getting it just right.
#63
Re: (Honda Hick)
What does the stock GSR tb pulley look like? My car isnt in my possesion right now its at the body shop. Can I just use that I thought it was round if my memory serves me correctly.
#64
Re: (ringgold)
This is how the throttle cable is going to be situated with the ITR cable and bracket:
The stock one pulls has the cable pulling it upwards. That's why the stock pulley won't work with a ITR cable.
#66
Re: (ringgold)
Well I was in the process of finishing my blox intake mani install up and I started the car up. What do you know high idle at about 2000 rpms. I have tried a few different things to make it go down and nothing. I can blip the throttle and it will idle down for a split second and then right back to anywhere from 1600-2000 rpms. I knew this would happen before I even started this swap of manifolds. Anyone else had this problem yet and if so what did you do to solve the problem?
#68
Re: (wally_the_whale)
hey whats up man. Awsome write up, but i did not do my installation the right way. I installed it the right way i believe? but my car won't rev past 3k. i threw the old one back on assumming that stuff would go back to normal but i still had the same problem. now your probably wondering if half-assed anything, and yes i did. THe top six studs i kept in because i could not find a place to get them. another thing that confused me was that my car only had 5 plugs and 6 sensors. I think the plug missing is the one for the black vaccum box under the intake manifold due to the fact that i might have a 93 si wiring harness. another think that i forgot to mention is im installing the skunk2, but it looks the same exact thing as yours so everything should be the same. ANYONE"S HELP WOULD BE APPRECIATED THANK YOU!!
#69
Re: BLOX Intake Manifold How-To Install (spooned out)
oh yeah my car wasnt not throwing any codes whats so ever before i tried installin this, and im keeping the stock throttlecable.
#71
Re: BLOX Intake Manifold How-To Install (slotec)
instead of spacing out your fuel filter, just run it over the top of the intake pipe
that what i did
that what i did
#72
Re: BLOX Intake Manifold How-To Install (AK94GSR)
anyone know where i can find the studs that come off the back of the head for the intake manifold? ANYONE? an exact store that woul have them would be great
#73
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out »</TD></TR><TR><TD CLASS="quote">oyeah do you have a check light for the secondary butt? since gsr has butterflies or what ever its called versues blox/skunk/itr which does not.....</TD></TR></TABLE>
This was answered in the witeup.. Thats why the ECU was swapped for a p28.
On a sidenote...
Ive heard of the blox from other posts on here, but specifically I have a few questions.
Is this strictly a NA application? or would it not be worth it on a boosted motor?
also what are the gains on a NA application like shown above?
On a sidenote...
#74
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec »</TD></TR><TR><TD CLASS="quote">anyone know where i can find the studs that come off the back of the head for the intake manifold? ANYONE? an exact store that woul have them would be great</TD></TR></TABLE>
Any local auto parts store should be able to get them for you. The first place I stopped (local place) had them for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR »</TD></TR><TR><TD CLASS="quote">instead of spacing out your fuel filter, just run it over the top of the intake pipe
that what i did
That still looks too tight for my liking though. It doesn't look like there's any play at all in that hose and it could snap over time from sthe tress on it.
#75
Re: BLOX Intake Manifold How-To Install (vtecluder97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 »</TD></TR><TR><TD CLASS="quote">
also what are the gains on a NA application like shown above?</TD></TR></TABLE>
No one can answer my simple question?
