Is it bad for a GSR temp not to be in the normal Temp?
I do notice at times that my car doesn't run at the normal temp when warmed up.
It fluctuates to the middle and then goes down a bit. Is that good for the engine? |
Re: Is it bad for a GSR temp not to be in the normal Temp? (peel17)
As long as it's not super hot you'll be OK. Get a new thermostat from Honda
Re: Is it bad for a GSR temp not to be in the normal Temp? (Lan)
Heres some pics on how it looks like.
https://i34.photobucket.com/albums/d...rmeduptemp.jpg https://i34.photobucket.com/albums/d...17/running.jpg |
Thermo is just old...... replace it and you'll be https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
right on.. thanks for the confirmation
No problem, my car would take forever to heat up, and would cool off completely driving on the freeway. When I replaced the thermostat it works good now.
same here, car would almost never warm up, it always stayed cold. i got a new thermostat and its all fixed
Re: Is it bad for a GSR temp not to be in the normal Temp? (matto23)
I had the same problem too, if I was on the highway going over 70 i wouldnt have vtec my car ran so cold. I never worried about it because I am boosted and the cooler temps are better in my opinion.
