Anyone else think 1st gear sucks bad!!!!??
Don't know why but this gear sucks big time.......why is that? anyone know? it takes forever to pull . . .. .
Re: Anyone else think 1st gear sucks bad!!!!?? (martilafox)
1st gear? i like first gear
Re: Anyone else think 1st gear sucks bad!!!!?? (integls98)
our car has 128LBs of torque maybe....duh.... http://images.zeroforum.com/smile/emwink.gif
Re: Anyone else think 1st gear sucks bad!!!!?? (CrAZyRaCeR)
i dont like 1st that much... it goes by too fast... and before u even have a chance to look... its over 9! http://images.zeroforum.com/smile/emsmilep.gif
Re: Anyone else think 1st gear sucks bad!!!!?? (ek9t)
oh yeah....forgot about the torque issue....!! damn.........do you guys rev up to 5k in 1st during normal city driving (assuming you guys have GSRs)
i rev anywhere from about 3500 to about 4500 in normal driving
1st gear is fine...as long as your above 5k rpms
Re: Anyone else think 1st gear sucks bad!!!!?? (01GSR)
true, 1st gear is way too short, even for vtec...with 4.4 FDR, its short but with the 4.78 its unbelivibly short.....from my expirence mine is too quick in revs (damn 7lbs flywheel, especially with 8.5k redline).....need higher redline around 10.0k, that would fix it
Re: Anyone else think 1st gear sucks bad!!!!?? (eg6ajk)
first gear isn't slow for me. If anything, there is too much toque in that gear. once 5.3K (Vtec for me) hits the tires light up (ok start sliping and squealing) and before I can blink I'm at redline. Driving normally, I shift like at 3-4 in first because there is plenty of torque there. -C
Re: Anyone else think 1st gear sucks bad!!!!?? (TypeC)
what sucks is the gearing from 1st to 2nd. revs drop way too low always under vtec for the 1-2 shift. all other gears are ok as the car stays in vtec .
I like first gear, but I don't have VTEC. I hate second gear sometimes, when my elbo hits the center console while shifting, and I grind the gear. I tell my baby I'm sorry, but the damage is already done . . . . http://images.zeroforum.com/smile/emcrook.gif http://images.zeroforum.com/smile/emsad.gif
Re: Anyone else think 1st gear sucks bad!!!!?? (slapmyfro)
what sucks is the gearing from 1st to 2nd. revs drop way too low always under vtec for the 1-2 shift. all other gears are ok as the car stays in vtec . |
Yeah, I do not like the 1-2 shift either. The revs drop too low.
With my pucked clutch, I have to pay special attention to rev matching on the 1-2 shift or I get all jerky. Dustin |
Re: Anyone else think 1st gear sucks bad!!!!?? (WOTTEG)
I go through first gear so fast, it sucks....
Re: Anyone else think 1st gear sucks bad!!!!?? (Jesse H)
You are shifing much too slow. Maybe you're confusing the sound of the secondary intake runners opening up as the cam crossover? But then I don't recall it closing in the 1-2 shift either. [Modified by slapmyfro, 12:35 PM 7/27/2001] |
Jesse, Just to let you know, it is impossible to keep the second vtec point on a gsr open............................................. or as you call it the second set of runners opening up at the cam switchover point. if you do keep it open, all you are doing is riding your clutch and spinning your tires............................ Ive asked about 20 different people and they all say because of the GEARING, 1-2 shift drops below vtec [Modified by slapmyfro, 12:35 PM 7/27/2001] |
Jesse, Just to let you know, it is impossible to keep the second vtec point on a gsr open............................................. or as you call it the second set of runners opening up at the cam switchover point. if you do keep it open, all you are doing is riding your clutch and spinning your tires............................ Ive asked about 20 different people and they all say because of the GEARING, 1-2 shift drops below vtec vtec is at 4400 rpms...if you drop below 4400 rpms when you shift from 1-2....you need not be driving a GSR...or any stick for that matter |
VTEC is 4400+
On the 1-2 shift, a GSR usually just barely drops below the secondary intake runner opening point @5800RPM. If you shift quick you can land in second while keeping the manifold open (but abusing the clutch), but generally you land just shy of the crossover point by about .5 seconds. I personally think an ITR second gear would shave .3+ sec off the 0-60 time. |
Re: Anyone else think 1st gear sucks bad!!!!?? (Stephen)
You are shifing much too slow. Maybe you're confusing the sound of the secondary intake runners opening up as the cam crossover? But then I don't recall it closing in the 1-2 shift either. Jesse, Just to let you know, it is impossible to keep the second vtec point on a gsr open............................................. or as you call it the second set of runners opening up at the cam switchover point. if you do keep it open, all you are doing is riding your clutch and spinning your tires............................ Ive asked about 20 different people and they all say because of the GEARING, 1-2 shift drops below vtec [Modified by slapmyfro, 12:35 PM 7/27/2001] [Modified by TypeC, 10:38 PM 7/27/2001] |
Jesse, Just to let you know, it is impossible to keep the second vtec point on a gsr open............................................. or as you call it the second set of runners opening up at the cam switchover point. if you do keep it open, all you are doing is riding your clutch and spinning your tires............................ Ive asked about 20 different people and they all say because of the GEARING, 1-2 shift drops below vtec sorry, but your wrong.... vtec is at 4400 rpms...if you drop below 4400 rpms when you shift from 1-2....you need not be driving a GSR...or any stick for that matter |
first off keeping the rpms above 5800 isnt that hard....i thougt it was impossible till i went out one day practicing. now i can do it with out even trying it. i have an ACT 4 puk clutch.
but VTEC only crossesover at 4400 (under WOT) partial throttle it opens at 5000 what happens at 5800 is the intake manifold opens up four more butterfly type doors on the intake manifold. that is tha big udible change that you hear bwaaaaaBAAAA. a lot people get that confuzed with VTEC or think its the secondary stage of VTEC. so baicly if you are dropping out of VTEC there is a problem shifting at 8000 slowly you will land at around 5300 and if you shift fast enough you can kep the rpms above 5800. and thats that! |
My advice: get rid of that nasty 2nd gear in favor of ITR gearing. Still my favorite mod to date.
BTW, stop calling the secondary runners opening up the 2nd VTEC crossover point. That's a misnomer. VTEC only crosses over once in the integra. Low cam, hi cam -- that's it. When you're balls to the wall, this occurs at 4400rpm in a GSR. The runners opening up in the GSR snail-shell manifold has nothing to do with VTEC. |
Re: Anyone else think 1st gear sucks bad!!!!?? (Y2kGsR)
first off keeping the rpms above 5800 isnt that hard....i thougt it was impossible till i went out one day practicing. now i can do it with out even trying it. i have an ACT 4 puk clutch. but VTEC only crossesover at 4400 (under WOT) partial throttle it opens at 5000 what happens at 5800 is the intake manifold opens up four more butterfly type doors on the intake manifold. that is tha big udible change that you hear bwaaaaaBAAAA. a lot people get that confuzed with VTEC or think its the secondary stage of VTEC. so baicly if you are dropping out of VTEC there is a problem shifting at 8000 slowly you will land at around 5300 and if you shift fast enough you can kep the rpms above 5800. and thats that! |
Why not get a vafc and set the low cam to high at 5300 and set the high cam to low cam and 5100. That would make it ideal for first to second shifting. Another reason i love my vafc! Just my .02$.
Tim |
