Aluminum Rust?
I have some rust on my skunk2 pro series shocks on the aluminum sleeves and it won't adjust. The shocks and the aluminum sleeve are one piece so I cant just purchase another sleeve set. How do I remove rust from aluminum?
I have tried wd 40 and pb blaster and no luck. btw its the rear suspension. Any help will be very appreciated thanks |
Re: Aluminum Rust?
aluminum doesn't rust........ do you have pics?
Re: Aluminum Rust?
It does pit though
Re: Aluminum Rust?
it will oxidize tho wd40 and a scub pad will work to clean it up
Re: Aluminum Rust?
try a scotch pad with some pb blaster. if it still doesnt budge id try lightly tapping the adjustment wrench with a hammer while trying to adjust.
Re: Aluminum Rust?
Gotta love Junk2 products. I'd go at it with pb blaster and a wire brush for a while to get into the threads.
| All times are GMT -8. The time now is 09:52 AM. |
