96 integra car starts but then does right after need help
So yea I have a 96 integra with a lsv I re,ently changethestarter on it but now it has another problem the car feelsasis choking n when it does turn on it wants to turn back off it starts backfiring I have a feeling its something with the fuel the fuel pump turns on the starter is good the dizzy is sending spark to the plugs the car crankslikenormal but car dosent start stay on help me out guys what can it be bump if View also fuel gauge marks 40psi not sure if that's the right amount of fuel I need stock fuel,pump
Re: 96 integra car starts but then does right after need help
Bimppppppppppppp
was it running fine before you changed the starter? fuel psi should be a few psi higher, but shouldn't be a huge deal. do you have an adjustable regulator? also are the plug wires in the right firing order?
Yes was running perfect n write are well put n no don't have an adjustable regulator about how much psi I should have?
b18c1/5 should be 47-54 psi.
b18b should be 40-47 psi. |
Take apart the dizzy and check the rotor, sometimes the screw backs out. I seen it happen alot.
