95 integra belt tension.
repaired a blown head gasket. all went well. cant seem to get the belt ternsioned correctly though. folllow instructions in book over and over. belt still seems loose. all help appreciated. this is my younger sons car. its vtec, i did this before when this car was non vtech and had no problems. cant remember what was different, it was a few years ago. need to figure this out so i can try adjusting the valves.
Re: 95 integra belt tension.
it doesnt have to be bad just needs to be tightend. the easiest way is to get a coat hanger, make it into a hook, then theres a lil hole for it to fit into, from there you should be able to get it tight enough. if not then yea maybe its time for a new one. oh and not jokin about the coat hanger. worked for me.
I do not understand why people are using coat hangers and such to tighten the timing belt tensioner. Do you all understand that it is possible to get the belt TOO tight? Do you also understand that the OEM tensioner spring is perfectly adequate at putting proper tension on the belt, when the proper belt tensioning procedure is followed?
Now I always replace the tensioner pulley and the spring whenever I change the timing belt. Also, make sure the belt is installed in the proper order. Crank sprocket -> tensioner pulley -> water pump -> exhaust cam -> intake cam. It is very important that you install the belt over the exhaust cam gear first, and then over the intake cam gear. When you do this, you're automatically going to pull tight on the belt from the crank sprocket up to the exhaust cam gear. If you put it over the exhaust cam gear last, you're going to end up with slack on that long side of the belt, which means you'll be 1-2 teeth out of time.
As for tensioning, make sure everything is lined up at TDC, install the belt, loosen the tensioner pulley bolt so that the spring pulls and applys tension to the belt, then snug down the tensioner bolt. Rotate the engine over a few times to verify that everything stays lined up each time the engine passes TDC on the #1 piston.
Once you have checked that it stays lined up, loosen the tensioner pulley bolt. Now this is important - while the tensioner pulley bolt is loose, turn the crank pulley so that the cam gears move past each other by about 3 teeth. Finally, tighten the tensioner pulley bolt and torque to spec.
What you're doing by turning the belt with the tensioner loose is the belt tightens and pulls against that spring. This puts the proper tension on the belt, and then the tensioner bolt keeps the tensioner in place. At this point the spring doesn't do anything. It's really not that hard to do, and IMHO it easier doing it this way than guessing what the correct tension is by using a coat hanger or some other such make-shift tool.
now thats the reply i was looking for. Thanx Patrick. unfortunatly, from what my other son just told me, this motors gonna come completely apart. he telle me the cylinders were pretty scored up when his brother pulled the head. so now i need to open it up and recheck things so that it dosent fail in the near future. thanx guys.
I did that Patrick, exactly like the Helsm said: Too loose. You coudl actually HEAR the belt slapping around. I purchased a new tensioner spring and it STILL DID IT.
I used a piece of metal to loop through the lil ear that the spring hooks to and tightened it manually.
The belt DOES NOT twist too far now and it doesn't sound like the top end is abotu to fly apart when it cranks up.
It was horrid man, I felt very uncomfortable with it.
To the OP, you don't want the tension to be super tight, but it doesn't need to be flapping around (like mine was). I'd rather it be a lil too tight than too loose.
Just a note...the suggested torque rating for the tensioner bolt is 40 ft/lbs. I tried getting that w/ a 1/4" drive ratchet before; didn't happen.
I did it exactly man... Exactly. Rotated the crank 3 teeth on the cam gears.. Still too loose. Dunno why.
Or heck, maybe it's the way it should have been? I dont think so because it was actually slapping. The thought of a slapping timing belt + boost didnt' set good with me.
ive tried doing it like the helms says and i also feel it leaves the belt just a very tiny bit too loose. my first lsvtec was tensioned that way and i can remember watching the belt twist around like crazy on the dyno when it hit the limiter it scared me honestly. i know from watching that the belts tighten up a bit when the motor warms up.
i sorta go by the deflection/whine method. i like the belts to have like 3/4 inch deflection in the middle of the exhaust side and maybe around 3/8 inch between the wp and intake gear. if it whines its too tight, but dont confuse a whine with the noise that the back of the crank pulley can make sometimes if it rubs on the outer lower tb cover
DEF use a tq wrench on that tensioner bolt the fate of your motor lays in its hands
SHG_EasyE
14
12-18-2006 05:50 AM
