94 integra auto wont go into drive
hello there ht. i have a 94 integra that i recently rebuilt the **** out of and now once all back together and purring like a kitten it simply will not engage into drive. WTF!!! car starts up and runs just fine absolutely nothing wrong except it wont go into drive and only drive. i can hit all other gears no problemo. keep in mind this is an AUTO.
ANY HELP?
please please please get back to me. im dieing here!
ANY HELP?
Re: 94 integra auto wont go into drive
your trans is fucked up i would do a 5 speed swap if u get your auto repaied somewhere it is atleast 1500 you can get 5 speed trans on cregs for 400 to 500 bucks for a good one
wow. care to elaborate on why exactly you think it is "fucked up"? i mean, you must have wonderous diagnostic skills in order to determine that with such little information given.
anyways. op. what exactly is happening? you can't shift to drive on the selector?
can select drive, but car won't shift when in drive? what repairs did you make prior to this? and before the repairs this problem wasn't occurring?
Old Fart
Ditto all the above^^^
Need lots more info.
When you say, "it wont go into drive and only drive" does that mean shifter will not go into the drive position or it will go into the drive position but car will not move?
When you say, "can hit all other gears no problemo" does that mean the other gears work, car moves? 94
originally the tranny felt like it would drop when shifting from park to drive. shifting felt kinda laggy and jumpy then we pulled the whole motor cuz of a blown head gasket. so i said **** it im replacing them all. i have no maintnance records on the car whatsoever and have drove it for 30k doing normal maintnance but i figured it coudlnt hurt at like 150k miles on the cluster. replaced every gasket there is motorwise. we did seperate the tranny from the motor but the tranny was left untouched.
have you checked for codes at the TCM?
silly question, but have you checked your fluid?
there will be several shift solenoids located on the transmission. did you disconnect any of them? are you sure nothing was left disconnected?
if level is good, i would probably check for power after the selector. if power exists, check at the solenoid(s)
check TCM codes first though
what does d4 mean? or maybe im mistaken and it was d3?????
helpppp please
how did you "make it go away"?
