94-97 fog lights wont work
I got a fog light kit for my integra off ebay... I cant seem to figure out the interior wiring... the kit came with 2 harnesses... 1 for the outside... plugged into the lights the brown plug by driver headlight and grounded to a headlight bolt... not sure if I picked tbe best ground but I wanted it out of sight... for the interior harness there was one end with the switch, one plug that goes to the other brown plug up by cruise control box? One that goes into fuse box I guess with a fuse in the middle... and a ground... my problem is depending on which spot in fuse box I plug into the switch stays lit but either way the lights wont turn on... and wen I hit the switch you hear the relay click but nothing... another slot in the fuse box wont turn the lights or the switch on? What am I doing wrong
Re: 94-97 fog lights wont work
Should be two power sources gong to the fuse box, one for the relay and another for the switch its self. Put the other brown plug to somewhere on the fuse box options. Depending on which slot you choose theres going to be power constantly (you should put the plug that has the inline fuse here), when the key is in ignition 2, or when you have your parking/headlights on.
Here's the DIY I used to install mine, except I have the switch in the center console instead of using the cruise control slot. Hope this helps.....
http://www.team-integra.net/forum/17...t-install.html |
