94-01 Rear main seal install help?
I have a 99 LS integra that I am changing the rear main seal on. I am using the felpro gasket set and it came with the seal and 3 wrong gasket for the outer edge of the casing that bolts to the engine. I realized the gasket set was for a few different models which is why there are 3 extra pieces. Anyway my big question is what do I need to seal the outer casing with when I bolt it back to the engine? Im guessing RTV is a no no. Im also considering on going to Acura to get an Acura main seal to be safe.
Re: 94-01 Rear main seal install help?
i got my rear main seal from acura cause i used 2 cheapo autozone ones and they kept leaking, some people just pry the old one out and stick on the new one but i just pulled the whole housing out, hondabond or rtv seal it then stuck the rear main seal on, goodluck on your journey
RTV will work well, there is an RTV sealant designed specificaly for aluminum it comes in a black tube at napa.
