5 Lug Conversion Question?
I recently did a 5 lug conversion on my 98 GSR and put on DC5 Type R wheels. Now my first question is this if my stock offset was +45 and with my new wheels i dont know what the hell it is now? The wheels by them self are +60mm what i notice is they do rub a little on the inner wheel well but not much i could live with it my car is tucked to the ground and i like the fact that the wheels are under the car with minimal camber. My Second question is this, if i change my offset from stock to what ever it is now let say 55mm would it totally mess up my handling and should i try to space it out some?
Re: 5 Lug Conversion Question? (Spec R_GSR)
The ITR, stock, uses +50 offset wheels.
I say get +50 offset wheels. |
i believe if you put dc5 wheels on a 5lug dc2r conversion, you'll need 6mm spacer i believe if i'm not mistakend.
Re: (nautica_t)
From those that have RSX wheels on their dc i've heard needed spacers not sure of the size though.
Re: (bg-33p)
Re: (Spec R_GSR)
Re: (Paul*DC4)
The dc5-r wheels have 60mm offset. Most rsx users use 15mm spacers.
| All times are GMT -8. The time now is 06:59 PM. |
