2009 Accord 2.4L #2&3 misfire code under load.
I had switched coils,plugs,injectors & did compression checked. Fuel pressure is normal. Still 2 & 3 miss. Honda dealer said it's because of a aftermarket starter which causes interference to ECU.
Re: 2009 Accord 2.4L #2&3 misfire code under load.
hello. You should post this at the Accord section. This is for Acura Integra.
You mention compression check, I am assume it is good? If not do a leakdown. If the compression is fine, then it is either your timing or distributor.
You may want to take a look at some of the TSB's for your car. My 09 V6 Coupe is in the Honda shop right now getting warranty work due to this. Time is running out out it though. I think this is the final summer for the extended powertrain warranty for 09 models...
Here is the TSB affecting mine. MIL Comes On with DTCs P0301 thru P0304 ? 2008-2012 Honda Accord | honda.oemdtc.com
barefoothonda
08-21-2018 07:31 AM
Rick_Kaz
12-21-2013 10:25 AM
