16" back to 15"
I like the tuna here
Re: 16" back to 15"
Depends, but possibly less rotating mass. Having a larger sidewall will likely make the ride slightly more comfortable, although it may have an adverse affect on your cornering ability with having more sidewall "roll".
Re: 16" back to 15"
I had 16s on my Integra for a while. 195 50 16s to be exact. It looked good, but I eventually hated the rough ride. My car is stock 195 60 14s, at 28psi. Personally I prefer the taller sidewall for a daily driver. Chances are you won't notice much if any difference in handling.
Re: 16" back to 15"
I'm confuse. If your talking about 15" rims vs a 16" rims? The only thing you have to worry is fitment issue if you have upgraded your rotors and calipers.
Re: 16" back to 15"
This is absolutely right. If the brakes are still stock, you'll have no issues. Really the only "advantage" to going to a smaller rim, is a taller tire sidewall for a softer ride and less stress on your bushings. Other than that, it's likely the 15" tires will be cheaper.
papi123
Honda Civic (2001 - 2005)
04-26-2010 06:42 PM
