01 integra gsr build questions
alright iv done alot of research i just want to see other peoples opinions and see if i should make any last min changes.
ENGINE b18c1 block and head 82mm bore w/ 12.0:1 compression supertech pistons eagle rods stock crank stock valves skunk 2 valvetrain skunk 2 pro 2 cams arp head studs supertech valve seals skunk 2 cam seals oem head gasket im going to get a engine mount kit as well INTAKE skunk 2 intake mani w/ skunk2 throttle body port matched injen short ram intake EXHAUST skunk 2 alpha series headers skunk 2 mega power exhaust 3 in test pipe. SUSPENSION skunk 2 pro c coilovers blackworks lower control arms. Basically everything is done except the pistons and the bore. after i get it done iam going to tune it on hondata and in the future ill throw 50-75 shot of nos. i just want some opinions of what else i can do what people think of the build what can i do to the overall car. and how much hp you think ill be at after a good tune |
Re: 01 integra gsr build questions
My build is so similiar,, same cams, everything, cept I have stock rods, 81 mm Nippon pistons on 10.8 compression, made 201 whp and 149 ft tq on a shitty tune by eriks racing. (only took half hr) what im going to do which would probably benefit your build as well, better intake manifold (performer ex, custom made) a better header (hytech/replica, toda/replica, ect) 3" tuned cold air intake with velocity atack, and whatever else.
