[FAQ] Post your Gas mileage (MPG) & Setup
#53
official honda whore
Re: (TEXREX88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXREX88 »</TD></TR><TR><TD CLASS="quote">98 LS Coupe 125k miles 5spd totally stock except for intake/filter.
26 city
31 Hwy cruise control @ 72mph
(Having fun off the line, then shifting at @ 2.5k rpm's, coasting in neutral when traffic slows or stops ahead..) </TD></TR></TABLE>
its bad to coast in nuetral for gas mileage as idle consumes alot of gas, you are supposed to coast in gear to get the best mileage
btw i average about 26mpg on a basemap for my turbo integra, looking to get into the mid 30's with a highway tune to help compensate for the high gas prices
4.29 for 93 here in pa
Modified by EARLdaSQUIRREL at 12:49 PM 5/28/2008
26 city
#54
Re: (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">
Not saying you are incorrect, but do you have any proof to back that up?
I figured coasting in neutral would result in better MPG due to hondas/acuras not using much gas at idle.. When your in gear in higher rpms wouldn't you consume more gas?
#55
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
I figured coasting in neutral would result in better MPG due to hondas/acuras not using much gas at idle.. When your in gear in higher rpms wouldn't you consume more gas?</TD></TR></TABLE>
when your in gear and not on the gas the injectors are completely shut, whereas if your in neutral and coasting the injectors are keeping the car at idle which will consume more gas
#56
when your in gear and not on the gas the injectors are completely shut, whereas if your in neutral and coasting the injectors are keeping the car at idle which will consume more gas</TD></TR></TABLE>
Cool.. well from now on.. guess i'm going to leave mine in gear..
#58
Re: Post your Gas mileage (95BG33PGSR)
i'm not sure how you guys are calculating how much you get on streets and highway hah but i get about 320 miles to the tank in my b20b integra..
b20b, b16 tranny
exhaust, and ecu chip. thats it
b20b, b16 tranny
#59
Re: (Jimmy)
Cool.. well from now on.. guess i'm going to leave mine in gear.. </TD></TR></TABLE>
after reading that, me too
#60
Re: (dohcFTW)
i get like 250 a tank.
90 integra
b18b w/ like 30k on it
b16 cable
i think if i get an alignment i should get more miles, but i don't think it'll affect it that much
90 integra
b16 cable
#61
Re: Post your Gas mileage (dohcFTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcFTW »</TD></TR><TR><TD CLASS="quote">i'm not sure how you guys are calculating how much you get on streets and highway hah but i get about 320 miles to the tank in my b20b integra..
b20b, b16 tranny
exhaust, and ecu chip. thats it</TD></TR></TABLE>
fill your tank up, reset your trip odometer, drive around till almost empty and fill up, divide how many gallons it takes to fill it up by how many miles you drove
examply i drove 266 miles and filled up with 10 gallons, i got 26.6mpg
b20b, b16 tranny
#62
Re: Post your Gas mileage (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">fill your tank up, reset your trip odometer, drive around till almost empty and fill up, divide how many gallons it takes to fill it up by how many miles you drove
examply i drove 266 miles and filled up with 10 gallons, i got 26.6mpg</TD></TR></TABLE>
hah well i know that, but people are posting up how much they get on city and how much they get highway.. hows that calculated?
#63
Re: (Ls92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls92 »</TD></TR><TR><TD CLASS="quote">92 Ls B18a1
9.5-1 comp pistons
pnp head ,crower 404's
Blox IM,SK2 68mm Tb
Gsr ys1 transmission
dc headers, 3" exhaust (from headers)
HWY-18-20mpg
City -18-20mpg
Is that tuned?
9.5-1 comp pistons
Blox IM,SK2 68mm Tb
HWY-18-20mpg
City -18-20mpg
Is that tuned?
#64
Re: (Jimmy)
9.5-1 comp pistons
Blox IM,SK2 68mm Tb
HWY-18-20mpg
City -18-20mpg
Your fuel economy sucks because of your large exhaust on a very mild setup...not a good combo there. I would expect that compression for FI, supercharger on the way?
Thats probably not tuned either.
Average (90-100% city) = 26mpg (280 miles a tank)
City = 25-26mpg (270-280m miles a tank)
Highway = 35-39mpg @ 65-67mph (around 3k rpm for LS trans)
Record = 55mpg going from Bay area to LA, CA (550 miles on a tank) Cruise control @ 67mph
Those extra mph really dont get you anywhere...so why speed? Btw, I did a few (3-4) 130mph+ pulls on I-5 going down to LA...still got the fuel economy posted above. I wish I had kept that receipt...
9.5-1 comp pistons
Blox IM,SK2 68mm Tb
HWY-18-20mpg
City -18-20mpg
#66
Re: (jentee)
stock 97 ls stock with k&n drop in and ngk wires.
130k miles.
MPG:
city: 24-26 mpg
highway: 30-33mpg
mixed: 27-29mpg
I drive avg 5 mph over speed limit in the city, and about 75-80 mph on the freeway... I consider my driving conservative for so-cal.
things that can help gas mileage:
keep tire pressure at max tire psi.
make sure your alignment is straight, jacked up alignment causes extra friction and hurts your mpg by like 1 or 2 mpg.
change the fuel filter every year or so, I was amazed how much sludge was in there the first time I changed it. OEM honda fuel filter is about $20
change spark plugs O.E. works fine for a stock DD... I don't notice much a difference when I buy expensive spark plugs.
clean your car out and leave the extra crap in your car at home.
87 $4.50 gal... on base $3.55 gal. gotta love working for the government.
130k miles.
MPG:
city: 24-26 mpg
highway: 30-33mpg
mixed: 27-29mpg
#67
Re: (hueyduey)
1998 GS-R 4dr
Stage 1 Cams (Skunk2)
2 1/4" piping from cat to stock muffler
K&N air filter (oem style)
City: 25-27 mpg
Highway: 35-37 mpg (about 70-80mph)
Average: 28-30 mpg on mix driving
City: 25-27 mpg
#68
2000 integra gsr. 5 spd. 108k
dc 4-1 header, skunk2 60mm catback
average 30mpg in town. 33 mpg when i had very few races and managed 26mpg when i stomped on it all the time.It hasn't been on any roadtrips yet so i dunno the interstate gas mileage.
#72
Re: Post your Gas mileage (MPG) & Setup (Jimmy)
i have a 96 gsr that i turboed i get 27 highway and 23 city i has je pistons eagle rods skunk 2 valve springs block guard running 15 psi on e85
#74
LS-V
CTR Head, pistons, b18a bottom, AEM/DC/Apexi WS2
GSR Trans
I always get 29 mpg, no matter what I do. I've never gotten above that, but 85% of my driving is highway @ 80-85 mph. I should try the backroads for a week, see what happens.
GSR Trans
