Old 09-15-2004, 04:32 AM   #1
Mark Murda
Send a message via AIM to Mark Murda
Default One headlight shining brighter than the other
Did this ever happen to anyone one of my headlight is shining brighter than the other.I tought the bulb blew,but my high beams work. When i turn on my low beams nothing.But when i turn on my high beams and turn if off,and turn on my low beam the bulb stays lite but just not as bright as the other one.If i turn off my foglights then it goes off completly.WTF. I checked the fuse its good. I switched bulbs and the same thing happend. Whats going on.Should i just change both bulbs change all the fuses just to be safe.?BTW its the driver side headlight. Any help would be great thanks. Click the image to open in full size.
Mark Murda is offline   Reply With Quote
Old 09-15-2004, 04:58 AM   #2
murmur9
murmur9's Avatar
Send a message via AIM to murmur9
Default Re: One headlight shining brighter than the other (Mark Murda)
same thing happened to me, except it was the passanger side. it turned out to be my connection. The plug that directly plugs , or the female end you could say that the bulbs male end fits into. just wiggled that bitch around, still ***** with me though when its pissed i guess. the outside plastic is kinda melted, but i donno why. no open wires. bump for you
F/S :
~P2E ECU (manual)
~D16y7 Intake Manifold with all sensors, throttle bod..etc -make offer
~D16y7 wiring harness
~D16y8 (P2E) ECU
WTB:
~CRX HF exaust manifold</U>!!!!!! ASAP please pm me if you have one
murmur9 is offline   Reply With Quote
Old 09-15-2004, 06:49 AM   #3
Mark Murda
I'll try that this afternoon thanks..
Old 09-17-2004, 10:04 AM   #4
Mark Murda
Ok I tried messing with the plugs and nothing happened.Any other ideas...
Old 09-17-2004, 10:36 AM   #5
Ricey McRicerton
Former Moderator
Ricey McRicerton's Avatar
Default Re: One headlight shining brighter than the other (steve123)
Originally Posted by steve123
your low beam is died, so your high beam comes on in place of it... Click the image to open in full size.
replace that bulb..
Ummmm....not at all. If your low beam burnt out, you'd just have one low beam, and when you switched to hi beams both would work. It doesn't work that way.
13 STi
04 4Runner
93 VFR750F
06 VFR800
Ricey McRicerton is offline   Reply With Quote
Old 09-17-2004, 11:11 AM   #6
SOHC4life 96
SOHC4life 96's Avatar
Default Re: One headlight shining brighter than the other (Ricey McRicerton)
EXACT same thing happend to me. I took it to a guy I know, they do tint, stereo, alarms, etc. Anyway, I cant remember what he said it was exactly but, from what I remember, he cut the ground wire (something about the relay was in what he said to) and just took it and ran a little screw thingy to it and connected it to the radiator support. Ill go take a picture in about 2 minutes to show you what I mean. Kinda confusing but it did the trick. My driver side headlight was not as bright as my passenger side. Switched the bulbs, nothing. Asked him and he fixed it. I love those guys they hook me up. Click the image to open in full size. And if you live in the LA/LBC area and need tint/stereo/alarm put in just let me know Ill hook you up. Click the image to open in full size.
Originally Posted by ressuREXion
after reading how i got caught in both of those, maybe it would be safe to assume i have narcalepsy
Originally Posted by Mr. E.G.
whoa, thats tough. i guess i would have to say that i would rather lick a dudes ******* that sick his duck.
RIP Earl Laskey 1944 - 2006 You will be missed
SOHC4life 96 is offline   Reply With Quote
Old 09-17-2004, 11:17 AM   #7
ej1 pilot
ej1 pilot's Avatar
Send a message via AIM to ej1 pilot
Default Re: One headlight shining brighter than the other (DOHC4life)
id say its the plus also...sometimes they can get a bunch of dirt or goop or whatever **** in there and it messes with the connection, easiest thing to do is just replace them
1994 Magma Red Integra LS- TOTALED
1995 Metallic Jade Green Civic EX- STOLEN
1997 Frost White Civic EX- Current
ej1 pilot is offline   Reply With Quote
Old 09-17-2004, 11:31 AM   #8
dukduk
dukduk's Avatar
Send a message via ICQ to dukduk
mine is the same, running silverstars, but its probably because one headlamp housing is newer
dukduk is offline   Reply With Quote
Old 09-17-2004, 11:34 AM   #9
SOHC4life 96
Default Re: One headlight shining brighter than the other (Art In Motion)
Here you go. It is the wire on top that has the blue connector on it and goes to the radiator suppport.
Sorry for the crappy quality, I dont have photoshop and paint isnt the best resizing program out there. Click the image to open in full size.
Modified by DOHC4life at 12:46 PM 9/17/2004
Old 09-17-2004, 11:55 AM   #10
Mark Murda
Thanks for all the help/ideas i'll try those today and see what happens.Looks likes its gonna rain..Damn..Ivan!!!
03, 93, accord, adjust, bright, brighter, civic, corolla, crx, dimmer, head, headlight, honda, light, toyota
