Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 09-09-2004, 05:55 PM   #1
JinDIESEL
Send a message via AIM to JinDIESEL
Default which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil?
JinDIESEL is offline   Reply With Quote
Old 09-09-2004, 05:56 PM   #2
Opie
Opie's Avatar
Send a message via AIM to Opie
The kind that doesn't care what oil you use Click the image to open in full size.
Opie is offline   Reply With Quote
Old 09-09-2004, 06:00 PM   #3
slammed_93_hatch
slammed_93_hatch's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (JinDIESEL)
i have found threw "search" that BG44K kicks ***, some people say its the same as the techron concentrate some say its not
slammed_93_hatch is offline   Reply With Quote
Old 09-09-2004, 06:07 PM   #4
Nishant
Nishant's Avatar
Send a message via AIM to Nishant
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (slammed_93_hatch)
i used red line...was 6 bucks at pep boys
PS3: Tailor83
XBOX: NTailor
Nishant is offline   Reply With Quote
Old 09-09-2004, 06:35 PM   #5
KOALA YUMMIES
KOALA YUMMIES's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (Nishant)
Used Chevron most of the time, STP was highly reccomended too. Just based off of what I've heard from friends and whatnot. I dont do it too often.
KOALA YUMMIES is offline   Reply With Quote
Old 09-09-2004, 06:48 PM   #6
Two_K Si
Two_K Si's Avatar
Send a message via AIM to Two_K Si
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (KOALA YUMMIES)
Fuel power is what i use. 2 oz's every fill up is the dosage. I prefer this regiment rather than just dumping a bottle of cleaner every 3k or so. I seem to be getting a little better mileage to boot.
<U>[I][B]SOLD TO:[/B][/I]</U> NickQ, DA KING, imc2pid, hasback_00, civic duty, s.cali alan, CRITTERMATT, 2 point 0, SiReg-6, kanzenr91si, Rtistik.
Two_K Si is offline   Reply With Quote
Old 09-09-2004, 06:59 PM   #7
Batoutahell
Batoutahell's Avatar
STP = free t-shirt.
And this is a hard decision, why?
Driving FLAT OUT in an actual supercar - like I do - is an art form. I can’t expect you to understand.
Batoutahell is offline   Reply With Quote
Old 09-09-2004, 07:05 PM   #8
sil
sil's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (Batoutahell)
because there are so many choices.. many of which probably don't work.. but both redline and techron are great.... check out bobistheoilguy.com
sil is offline   Reply With Quote
Old 09-09-2004, 07:07 PM   #9
.RJ
.RJ's Avatar
Send a message via AIM to .RJ
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (sil)
Motul Fuel System Cleaner
http://www.hmsmotorsport.com - where I order all my Motul bling, great service.
Madison Motorsports
CB750 | CB350 | SV650
04 Trek 8000 | 06 Trek Pilot 2.1 | 85 Trek 660
Racing is one of the finest mechanisms for the disposal of money - RR98ITR
.RJ is offline   Reply With Quote
Old 09-09-2004, 08:04 PM   #10
FrostyDC4
"Haters Gonna Hate"
2007 Nissan 350Z
FrostyDC4's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (.RJ)
How do you like it?
Chevron works well for me Click the image to open in full size.
GDD Aesthetics Krew / Famke Janssen is a goddess crew / Denise Milani is a goddess crew / Getting ready for the 2014 NPC season
Originally Posted by FrreeeBird View Post
I peed on your mother once, and she liked it.
FrostyDC4 is offline   Reply With Quote
Old 09-09-2004, 08:15 PM   #11
v-attack
v-attack's Avatar
Location: First in Flight, Type Rs of East Coast, NC, FL
iTrader Rating: (1)
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (FrostyDC4)
At work we sell and use an injector cleaner that acutally does work... it is not an additive to your gas tank.
The cleaner we use is in a compressed can similar to a spray paint can. The vehicle runs off of this bottle until it runs out.
Basically you remove the fuel pump fuses, run the vehicle out of the gas left in the rail and lines...then you remove the fuel line from the rail...hook up your regulator and can of injector cleaner and start the vehicle....cycle it through different rpm ranges then let it idle...we have tested the injectors and found they flow more after doing this procedure.
I dont remember the brand name. You might be able to find it online. Click the image to open in full size.
WTB: USDM Phoenix Yellow Type R front end body parts, WTB: B Series JDM ITR trans with LSD + 4.7 FD, WTB: B Series or K Series Type R Swapped Civic Hatch,
FS: Integra LS 5spd. Cluster, 2 LS Cylinder Heads and Intakes
v-attack is offline   Reply With Quote
Old 09-09-2004, 08:18 PM   #12
[HrZn]4life
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (v-attack)
I've heard that techron is the best and I try to only use Chevron gas with techron... but last time I pulled my head I still had a good amount of carbon buildup around my valves.
[HrZn]4life is offline   Reply With Quote
Old 09-09-2004, 08:56 PM   #13
kim_2_da_chee
kim_2_da_chee's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? ([HrZn]4life)
Do these fuel additive "injection cleaners" really make that much of a difference? I always thought that using high octane fuel already cleans out the system from carbon build up on injectors and valves? I use 94 octane every time i fill up. What advantage do these cleaners have over high octane fuel?
91HatchB16A
The Rebuild of my EF
http://www.youtube.com/watch?v=0yJIR-fMHws
kim_2_da_chee is offline   Reply With Quote
Old 09-09-2004, 09:25 PM   #14
SLCTyper
SLCTyper's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (kim_2_da_chee)
Higher octane can potentially leave fewer carbon deposits but doesn't do anything by itself to clean injectors or valves. That's the purpose of additives like Techron.
SLCTyper is offline   Reply With Quote
Old 09-09-2004, 10:11 PM   #15
MugenHonda
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Send a message via AIM to MugenHonda
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (SLCTyper)
CD2 Fuel Treatment
best 4 dollars
MugenHonda is offline   Reply With Quote
Old 09-09-2004, 10:18 PM   #16
kim_2_da_chee
Roger
91HatchB16A
Old 09-09-2004, 10:36 PM   #17
ejprimo
ejprimo's Avatar
Send a message via AIM to ejprimo Send a message via Yahoo to ejprimo
chevron gas
redline fuel cleaner or fuel power or chevron techron.
(proguard is not the techron concentarte.)
JRZ Novak Racing
ejprimo is offline   Reply With Quote
Old 09-10-2004, 03:40 AM   #18
DontBlink
DontBlink's Avatar
Send a message via AIM to DontBlink
Originally Posted by slammed_93_hatch
BG44K
Click the image to open in full size. good stuff, i been useing this for years, its just a little on the expensive side.
97 Type Turbo 97-0305(parted out) / 98 Type R 98-0041(sold) / 98 Type R 98-XXXX(sold)
99 FRC corvette(considering going back to a Type R)
DontBlink is offline   Reply With Quote
Old 09-10-2004, 04:52 AM   #19
Enrikez
Enrikez's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (DontBlink)
Lucas Click the image to open in full size.
1meanb18c5civic member since 7-01
Enrikez is offline   Reply With Quote
Old 09-10-2004, 05:13 AM   #20
B18CXr
B18CXr's Avatar
Berryman's B12 is hands down the best, no question.
Yack- '92 EG6 '12 848EVO
2002 Honda Challenge H1 Champion (Pre-asshat NASA)
Neptune, Apexi, AEM EMS certified tuner, Toda Racing Dealer
B18CXr is offline   Reply With Quote
Old 09-10-2004, 06:25 AM   #21
pyromaster
pyromaster's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (Two_K Si)
That's what I use too Click the image to open in full size.
Thieves suck!!!
pyromaster is offline   Reply With Quote
Old 09-10-2004, 07:03 AM   #22
tnord
Send a message via AIM to tnord
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (pyromaster)
91 Spec Miata - 90% done
01 Silverado 5.3 Z71
94 Acura Legend - FOR SALE $4250
Kansas City Region SCCA
"Find Tenths." - Pat diNatale
"it's easy as hell to drive inside of someone if I have enough power to overcome the fact that my apex is rooster-in-the-morning early." -Kirk Knestis
tnord is offline   Reply With Quote
Old 09-10-2004, 02:48 PM   #23
Enrikez
Enrikez's Avatar
Default Re: which fuel and injector cleaner brand is best (B18CXr)
also the only one that contains acetone.
Lucas.
Old 09-10-2004, 03:37 PM   #24
Padawan
Darth ModerVader
Padawan's Avatar
Another alternative some of you might want to consider if you're concerned about thoroughly cleaning your injectors is sending them out and having them professionally serviced. There are numerous shops you can locate online that will perform a complete cleaning and servicing for ~$50 total. In my opinion it's quite a good deal when you consider the cost of a few bottles of some of the high-end injector cleaners. Doing this perhaps every other year (or even yearly) in conjunction with running some of the inexpensive off-the-shelf fuel system cleaners would most likely keep your injectors in excellent shape.
Here is a link to the shop that recently serviced the Prelude injectors being used in my brother's setup - WitchHunter Performance
-NEMO ME IMPUNE LACESSIT-
Padawan is offline   Reply With Quote
Old 09-10-2004, 04:01 PM   #25
Vu
Vu's Avatar
Send a message via AIM to Vu
Using a higher octane fuel than your car need usually leaves more carbon deposits, not less. If your car can't efficiently burn that extra fuel, than it will create some carbon buildup.
"There are five possible operations for any army. If you can fight, fight; if you cannot fight, defend; if you cannot defend, flee; if you cannot flee, surrender; if you cannot surrender, die. " - Sima Yi "Romance of the 3 Kingdoms"
Vu is offline   Reply With Quote
additive, castrol, cb350, chevron, civic, cl350, cleaner, fuel, honda, injection, injector, injectors, octane, redline, si, tech, techron
