Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 08-30-2004, 02:17 PM   #1
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Default GSXR Throttle Bodies (a thread continuation)
I made this thread to keep continuity of a good topic. The orginal thread was locked due to size, but the link is here:
http://www.honda-tech.com/zerothread?id=775280
I'll ask Lip to put this link in his last post on the original thread. Click the image to open in full size.
404: Care not found.
Dogginator is offline   Reply With Quote
Old 08-30-2004, 05:19 PM   #2
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Default Re: GSXR Throttle Bodies (Dogginator)
The 2000-2003 GSXR 750 throttle bodies measure 50 mm (may be 49.5 mm) at the inlet and 42 mm at the outlet. These are the same dimensions as the GSXR 1000 throttle bodies. I measured my throttle bodies. They are stamped with code 35F0. Check these links for the GSXR 1000:
http://www.mcnews.com.au/NewBi...2.htm
http://www.motorcyclistonline....gsxr/
Modified by Dogginator at 8:26 AM 8/31/2004
Old 08-31-2004, 02:02 AM   #3
edc
edc's Avatar
Originally Posted by Dogginator
The 2000-2004 GSXR 750 throttle bodies measure 50 mm at the inlet and 42 mm at the outlet. These are the same dimensions as the GSXR 1000 throttle bodies. Check these links for the GSXR 1000:
Copied from old thread:
GSXR750 bodies, internal diameter of 48mm at opening taper down to 40mm and 44mm where the injector leads in.
Above were measured for me from a 1999 model with the desginaion WW, apparently the same as WX.
edc is offline   Reply With Quote
Old 08-31-2004, 04:24 AM   #4
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Default Re: GSXR Throttle Bodies (edc)
Indeed. The 96-99 GSXR 750 throttle bodies are smaller. They are stamped with the code 33E5.
Old 08-31-2004, 05:42 AM   #5
Speedz
1992 Honda Civic
Speedz's Avatar
Send a message via ICQ to Speedz Send a message via AIM to Speedz
i'm still working on my runners.. got everything else pretty much worked out
here's pic of the epoxy i've gotta port smooth..
1990 Accord EX Sedan
1988 Mazda Rx7
2012 Toyota Camry SE
Speedz is offline   Reply With Quote
Old 08-31-2004, 08:03 AM   #6
sCeRaXn
Honda-Tech Double Platinum Member
2000 Audi S4
My Garage
sCeRaXn's Avatar
sceraxn
I havent read all of the other post yet...but i have a few questions. First of all...what would be the benefits of having shorter/longer runners with ITB's? It seems like shorter would give you better throttle response...but im not sure if longer ones would have that much if any benefit. Also, how do you figure out what size ITB's youll need? Thanks
Originally Posted by Kiwibird83
Can you not hear the sounds of his love? They sounds like the skulls of babies being dashed upon the rocks...lovingly that is.
sCeRaXn is offline   Reply With Quote
Old 09-06-2004, 08:17 PM   #7
Speedz
1992 Honda Civic
Speedz's Avatar
Default Re: GSXR Throttle Bodies (sCeRaXn)
here's one of the runners thats done, i filled in the injector hole as u can see by this pic.
also got a question for you guys who've alread done the diy itbs.. what would work better: having one vaccuum line coming from runner #1 for brake booster? or just have it plugged into the vaccuum log with the rest of the vaccum lines?
Modified by Speedz at 5:28 AM 9/7/2004
1988 Mazda Rx7
Old 09-10-2004, 09:51 PM   #8
Speedz
1992 Honda Civic
Speedz's Avatar
Default Re: GSXR Throttle Bodies (Speedz)
finally took the time to finnish these runners inside.. heres pics Click the image to open in full size.
next is drilling holes for my vaccuum lines to go to the vaccuum log.
1988 Mazda Rx7
Old 09-11-2004, 07:45 AM   #9
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
It looks like its coming along. Click the image to open in full size. Did you have any problem with the manifold warping when you welded the tubes?
Old 09-11-2004, 08:53 AM   #10
Speedz
1992 Honda Civic
Speedz's Avatar
thanks man, no my welder was very careful about that.. i'm probably gonna surface the flange tho anyway. (i'm a perfectionist)
1988 Mazda Rx7
Old 09-15-2004, 09:35 PM   #11
Speedz
1992 Honda Civic
Speedz's Avatar
another update
1988 Mazda Rx7
Old 09-15-2004, 10:52 PM   #12
mEr
mEr's Avatar
looking good Click the image to open in full size.
mEr is offline   Reply With Quote
Old 09-16-2004, 09:40 PM   #13
Speedz
1992 Honda Civic
Speedz's Avatar
Default Re: GSXR Throttle Bodies (mEr)
thanks Click the image to open in full size.
still got more work to do.. gonna try to get the block in my hatch this weekend Click the image to open in full size. still got alot of other things to do before i can start the thing tho.
gotta piece together an engine harness first LOL
1988 Mazda Rx7
Old 09-17-2004, 04:34 AM   #14
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
It looks like it is coming along well. Those velocity stacks are quite nice. Where did you find them? Have you check for brake booster clearance?
Old 09-17-2004, 05:42 AM   #15
Speedz
1992 Honda Civic
Speedz's Avatar
not yet.. but when i had the ITB's in my engine bay, i think it was ok..
here's the guys email address i got them from (was waiting from email from him befor i posted) FASTLISLE@aol.com
he has them made locally.. he gets them in 3 sizes.. 1-7/8....2-1/8 and the 2-1/2 sizes.. and has a large supply of each size..
the 2.1/8" stacks fit perfect on the gsxr 1000 itbs. (at least they do on mine)
1988 Mazda Rx7
Old 09-17-2004, 06:01 AM   #16
MysteryWagon
MysteryWagon's Avatar
where the throttle bodies just laying around or did you purchase them?
and if so how much do a set of GSXR TB's go for?
Are there any charts for throttle body sizes that are appropriate to use with certain set ups?
info would be great
thanks alot Click the image to open in full size.
Justin
frankinside-Frank(not)inside
Geheimnis
90 lsvtec hatch (sold shell, parting out engine)----parts found below
http://hondamarketplace.com/zerothread/1671842
91 black crx (sold)
04 Black EM2 wife
06 steel grey WRX
MysteryWagon is offline   Reply With Quote
Old 09-17-2004, 03:46 PM   #17
Speedz
1992 Honda Civic
Speedz's Avatar
Default Re: GSXR Throttle Bodies (MysteryWagon)
i bought mine off Ebay for $115 shipped.. they normally go for around 150 or so from what i've been seeing.. i guess it depends on if u get lucky or not as to how much you'll end up paying.
Jenvey's website has alot of good info on ITB sizing.. they also give a good idea on how a system should be designed.
here's a link to their Advice & FAQs http://www.jenvey.com/~Tech_QA.htm
also i suggest reading the VERY long archived thread that's posted at top of this thread. lots of good info there as well.
and here's a small update on fitting my stacks this afternoon.. i think they came out well.
Modified by Speedz at 1:08 AM 9/18/2004
1988 Mazda Rx7
Old 09-17-2004, 04:14 PM   #18
EKhatch
EKhatch's Avatar
Very, very nice work Speedz. Click the image to open in full size.
Why ask for help when you ignore those willing to give it?
"Racing on the street is like kissing your sister, it just doesn't make any sense at all."
EKhatch is offline   Reply With Quote
Old 09-17-2004, 09:59 PM   #19
Speedz
1992 Honda Civic
Speedz's Avatar
Default Re: GSXR Throttle Bodies (EKhatch)
thanks man, gonna try to have the hatch running in 2 weeks for our Oct2 race.. u should come on over from ID Click the image to open in full size.
1988 Mazda Rx7
Old 09-18-2004, 04:25 PM   #20
OLM-02R
OLM-02R's Avatar
that looks awesome man...keep us updated... Click the image to open in full size.
[img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [url="http://www.teamgroundzero.net"][B]Team Ground Zero[/B][/url] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
[img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img] [B][I]"Bullshit Stops When The Clutch Drops"[/I][/B] [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img]
[B][I]"Life Begins Above 6100rpm"[/B][/I]
[B]<FONT COLOR="red">VTEC - CLUB[/B]</FONT>
[B]<FONT COLOR="red">VTEC-Club[/B]</FONT>[B] member #2[/B]
[B]<FONT COLOR="red">ACCESS[/B]</FONT>[B]Photo[/B]
OLM-02R is offline   Reply With Quote
Old 09-18-2004, 04:43 PM   #21
GreensleeperB16
GreensleeperB16's Avatar
Default Re: (OLM-02R)
Nice VTECH phone in backround!
"Twin trubos Barking"
I miss my boosted 3g lude
"Loose is fast and on the edge of out of control"
GreensleeperB16 is offline   Reply With Quote
Old 09-18-2004, 06:36 PM   #22
dmotoguy
1993 Honda Civic
My Garage
dmotoguy's Avatar
Send a message via AIM to dmotoguy
Default Re: (GreensleeperB16)
what do most people use to tune on a basically stock d16z6.. vafc?
can someone do a rundown of the parts needed?
gsxr work best for d-series?
dmotoguy is offline   Reply With Quote
Old 09-19-2004, 08:09 AM   #23
CRX_VTEC
CRX_VTEC's Avatar
Default Re: (dmoto)
for d series any gsxr would be good. 600 750 1000.. they'll all work. Hyabusa for B-series. Also.. for K series too. (1 set made) Click the image to open in full size. Click the image to open in full size.
CRX_VTEC is offline   Reply With Quote
Old 09-19-2004, 01:54 PM   #24
Speedz
1992 Honda Civic
Speedz's Avatar
Default Re: (CRX_VTEC)
couple pics showing brake booster space vs my itb stacks
1988 Mazda Rx7
Old 09-19-2004, 05:51 PM   #25
JUNcr-x
JUNcr-x's Avatar
Send a message via AIM to JUNcr-x
Default Re: (Speedz)
lookin great..good work Click the image to open in full size. Click the image to open in full size.
ENDLESS GARAGE : (808)454-2580 call marcus http://images.honda-tech.com/set1/smile/emthup.gif
::custom fabrication::dyno tuning::service & maintanance::
MYGARAGE link&gt;&gt;&gt; http://honda-tech.com/garage?cmd=viewcar&id=1337 &lt;&lt;&lt;
JUNcr-x is offline   Reply With Quote
1000, 2002, 750, bodies, body, bodys, gsxr, gsxr1000, identify, individual, installation, sale, size, suzuki, throttle
