Check out my Turbo set up...do i need anything else??
T3/T4 Turbonetics
Turbo Type R GReddy Blow Off Valve
Delta Wastegate
Drag Manifold For H22
Piping and Intercooler (Front Mount)
Bosch Fuel Pump
4 RC 440 CC/MIN Injectors
APEX AFC Fuel Controller
NOS Feul pressure regulator
APEX AVCR Boost Controller
Akimoto Air
How does this set up sound? Its going on a 1994 prelude Vtec.
thanks
Delta Wastegate
Bosch Fuel Pump
Akimoto Air
thanks
Texas B*tch!
Re: Check out my Turbo set up...do i need anything else?? (Immortal23)
You have all your oil lines, vacuum hoses? Probably look into getting a turbo timer as well. Looks decent though.
Texas B*tch!
Re: Check out my Turbo set up...do i need anything else?? (ForcedAccord)
Oh yeah and another thing, look into getting a MAP Bypass valve, a few of them I'm sure will be needed so you don't have the good ol check engine light on all the time.
Texas B*tch!
Yeah, also check to see if you have all the gaskets and shhhhhhtuff.... colder running spark plugs.... c'mon ppl add more stuff that I'm misssing.
4doorturbo
12-19-2003 05:52 PM
Immortal23
12-06-2001 07:47 AM
