How do I test my gsr ignitor with a multimeter to check if it's good or bad?
Old 08-26-2004, 06:33 PM
SaTownTegGsr's Avatar
Default How do I test my gsr ignitor with a multimeter to check if it's good or bad?
Can anyone please tell me how to test an ignitor with a multimeter to check if it's good or bad?
Old 08-26-2004, 09:18 PM
Default Re: How do I test my gsr ignitor with a multimeter to check if it's good or bad? (SaTownTegGsr)
Can anyone tell me?
Old 08-27-2004, 07:59 PM
sugarloafpkwy's Avatar
a;right dude i hope you have a wiring diagram.
If you put one lead on battery positive and the othe ron the coil negative (-) screw and crank the engine (with the dist cover off) voltage shoul dbe like between 4 and 8 volts. this is cause the ignitor is rapidly swithcing the voltage from open and ground (12 volts and 0.1 volts averaged together). if not check the wire from the ECU to the ignitor for the same voltage so iit can tell the ignitor to fire.
Old 08-28-2004, 06:57 AM
Default Re: How do I test my gsr ignitor with a multimeter to check if it's good or bad? (sugarloafpkwy)
But is there a way I can test it with a multimeter?
Old 08-28-2004, 07:05 AM
with the ignitor out of the distributor?
Old 08-28-2004, 10:41 AM
not really. to check it it has to have power. You basically check to make sure that it's getting a signal from the ecu, and if it is it should ground and unground the coil. If you really wanted to bench test it, you'd have to kind of set up a whole mock ignition system
Old 08-28-2004, 10:46 AM
The quickest check for ignitor is to take distributor cap off and put a test light on the coil (-) screw terminal, and put the other end on battery positive. Crank engine and if the light flashes and you're not getting spark then your coil is bad, if it doesn't flash it's 9 times out of 10 your ignitor. The only other things it could be would be TDC/CYL/CMP sensors inside the distributor, or the ecu, which are both pretty damn expensive.
Hope that helps.
Old 08-28-2004, 03:11 PM
Okay thanks alot I appreciate it.
bfpicard
09-21-2013 04:42 AM
4 door beast
03-16-2012 03:55 PM
rollinswapshop
03-16-2011 07:43 PM
rollinswapshop
03-15-2011 03:11 PM
thug252
10-22-2004 02:57 AM
Quick Reply: How do I test my gsr ignitor with a multimeter to check if it's good or bad?
