four wire oxygen sensor -- this normal?
Old 08-23-2004, 07:47 PM
Driven's Avatar
Default four wire oxygen sensor -- this normal?
I have a four wire O2 obd1 sensor.
has a green, white and two black wires?
White = signal
Green = heater
1 black = ground
1 black = 12v...
right!?
damn ecu keeps throwing code 41 regardless of how i have it wired up. checked, double checked, triple checked. voltmeter verified. I did have the o2 sensor wired INCORRECTLY when i first got the engine running, thinking it wouldn't fry itself...
I'm guessing i might need a new o2 sensor.
Old 08-23-2004, 08:14 PM
CRX_Control's Avatar
Default Re: four wire oxygen sensor -- this normal? (Driven)
Im lookin for a 4 wire o2 sensor too..whould you happen to know where to get one? sites or anything?
Old 08-23-2004, 08:16 PM
EF4lyfe's Avatar
partsamerica.com 92 honda civic si, emissions -> o2 sensor bosh 70$
Old 08-23-2004, 08:17 PM
Frog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">I have a four wire O2 obd1 sensor.
White = signal
Green = heater
1 black = ground
1 black = 12v...
right!?
I'm guessing i might need a new o2 sensor.</TD></TR></TABLE>
I think I might have one, I'll take a look when I get a chance.
Pascal
EG8R's Avatar
Default Re: four wire oxygen sensor -- this normal? (CRX_Control)
Code 41 is the heater I believe.... I had that code and I had to get a new one.
Any 92-95 Civic(just to make it easier to find one) O2 sensor will work for sure
Old 08-24-2004, 12:00 PM
Driven's Avatar
Default Re: four wire oxygen sensor -- this normal? (skelly ed666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 &raquo;</TD></TR><TR><TD CLASS="quote">Code 41 is the heater I believe.... I had that code and I had to get a new one.
Any 92-95 Civic(just to make it easier to find one) O2 sensor will work for sure</TD></TR></TABLE>
what's odd is this o2 sensor has TWO black wires...
everywhere I read says there should be black, white, green, and orange.
Old 08-24-2004, 01:37 PM
Keyboard Humorist
4drEF's Avatar
The Bosch I bought just 4 days ago had 2 black wires as well.
The black wires were both for the heater. The heater can be hooked up either way so the wires are both black.
Then you are left with the O2 signal wire and the sensor ground.
Old 08-24-2004, 01:45 PM
senpai's Avatar
The two factory OEM ones I have also have (2) black wires
Old 08-24-2004, 03:46 PM
fourthgenhatchB17's Avatar
Default Re: four wire oxygen sensor -- this normal? (maztur)
What u need to do is go by the wire colors on the engine harness side, not the O2 side. So if ur running a obd-0 harness, u wont have the side im talkin about. U need to find a obd-1 harness (no CX's) and cut off the matching plug. Then u will have the wire colors that ppl are referring to. If u are converting to obd-1, u must be careful when hookin up a 4 wire O2, because from experience, u can fry the ecu. I did that once and it forever threw code 41.
Old 08-25-2004, 06:26 PM
Driven's Avatar
Default Re: four wire oxygen sensor -- this normal? (fourthgenhatchB17)
alright, figured it out... boosted.org's site helped with this fix-it.
no code 41 anymore, woot!
Old 08-26-2004, 09:30 AM
Keyboard Humorist
4drEF's Avatar
So what did you end up doing?
Old 08-30-2004, 08:35 PM
Driven's Avatar
Default Re: four wire oxygen sensor -- this normal? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">So what did you end up doing? </TD></TR></TABLE>
checked all four wires about five times to make sure all connections were correct.
I have a connector at the firewall to ease the removal of the engine harness.
Then, there's the connector at the O2 sensor.
then there's the soldered wires at the vtecfrog harness.
just made sure they were all connected and grounded the one ground wire...i essentially had a bad ground for the O2.
Sereth
Honda Civic (2001 - 2005)
08-23-2017 01:12 AM
Azelas
06-07-2008 03:19 PM
Soled Out
01-06-2003 04:24 PM
Quick Reply: four wire oxygen sensor -- this normal?
