Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 08-17-2004, 11:38 AM   #1
borristebel
borristebel's Avatar
Default Does a defective EGR valve affect the idling of a car?
My 98 Prelude timing belt tensioner broke loose while driving on interstate highway. My car was disabled so I had it towed and had the timing belt and all the parts replaced. Everything works fine except it dies at idle.So the idle was raised at twice the recommended idle speed at 1500 rpm. What do you think is the problem?
borristebel is offline   Reply With Quote
Old 08-17-2004, 11:45 AM   #2
delguiner
delguiner's Avatar
Default Re: Does a defective EGR valve affect the idling of a car? (borristebel)
yes it does affect idling... I had the problem that my car would idle incredibly low so i blocked off the EGR... havent had the problem since.. good luck
delguiner is offline   Reply With Quote
Old 08-17-2004, 11:52 AM   #3
92blackprelude
Send a message via AIM to 92blackprelude
Default Re: Does a defective EGR valve affect the idling of a car? (delguiner)
if you block the egr it adds hp doesn't it?
92blackprelude is offline   Reply With Quote
Old 08-17-2004, 11:54 AM   #4
BLACK_DEL_SOL
BLACK_DEL_SOL's Avatar
if you block off a working egr valve does it affect you performance ? my buddy says yes that you lose hp ,but i say no that you gain slight hp 1-5. cause all it does is allow co2 to go back into the engine.
BLACK_DEL_SOL is offline   Reply With Quote
Old 08-17-2004, 12:02 PM   #5
delguiner
delguiner's Avatar
Default Re: Does a defective EGR valve affect the idling of a car? (92blackprelude)
if the EGR gets stuck open thats whats causing your bad idling and yes is does create a little hp... nothing very noticeable!
Old 08-17-2004, 02:15 PM   #6
SuperSlow
SuperSlow's Avatar
Only if it is stuck. Otherwise, EGR usually operates at idle and cruise. Not really a power adder I thought.
EK Traction Bar & CD6 Accord replica Greddy Evo SS Exhaust For Sale http://www.hondamarketplace.com/show....php?t=2478924
SuperSlow is offline   Reply With Quote
Old 08-17-2004, 02:31 PM   #7
spnbb2
Guest
Posts: n/a
my engein is throwing a code 12, egr valve, and it idles fine
Old 08-17-2004, 04:08 PM   #8
delguiner
delguiner's Avatar
Default Re: (SPN BB2)
thats probably cause your EGR broke while it was in the closed position!
Old 08-17-2004, 08:14 PM   #9
sleepy_vtec
sleepy_vtec's Avatar
Send a message via AIM to sleepy_vtec
Default Re: (delguiner)
did you ever think it may have jumped timing and bent a valve?
They call me Steve!!
92 si w/ JDM h22
All Type-S internals
Type-S header
DC catback
MSD Cap and wires
Oh and cant forget the SPARCO Pedals!!!(15hp) [img]http://images.honda-tech.com/set1/smile/emsmileo.gif[/img]
sleepy_vtec is offline   Reply With Quote
Old 08-18-2004, 06:56 AM   #10
delguiner
delguiner's Avatar
Default Re: (sleepy_vtec)
now my idling is going good right after i blocked the EGR
Old 08-18-2004, 07:01 AM   #11
Behan
Behan's Avatar
Code 12 is the lift circuit code. It means your egr valve isn't opening. All you need to do is remove it and clean the carbon and reinstall.
-Steve
<FONT COLOR="red"> My 93 lude </FONT> Sold http://images.honda-tech.com/set1/smile/emsad.gif
Proud Owner of 06 Mitsubishi EVO http://images.honda-tech.com/set1/smile/emthup.gif
Vouches: <FONT COLOR="blue"> Kteller8, Andy D, vehic illu
</FONT>
Behan is offline   Reply With Quote
Old 08-18-2004, 04:52 PM   #12
nota944mechanic
nota944mechanic's Avatar
Send a message via AIM to nota944mechanic
if you block off a working egr valve does it affect you performance ? my buddy says yes that you lose hp ,but i say no that you gain slight hp 1-5. cause all it does is allow co2 to go back into the engine." lol. the egr is closed when you are accelerating unless you are barely on the throttle. so blocking it will not add power.
nota944mechanic is offline   Reply With Quote
Old 08-18-2004, 10:47 PM   #13
sIcWiTiT
sIcWiTiT's Avatar
Send a message via AIM to sIcWiTiT
Default Re: (nota944mechanic)
up fer da peeps
sIcWiTiT is offline   Reply With Quote
Old 08-19-2004, 05:35 AM   #14
sharkcohen
sharkcohen's Avatar
Default Re: (flosSIn)
The EGR is only open at part throttle. It's purpose is to cool the combustion temps during the stoich conditions of closed loop operation. It is also beneficial for reducing NOx emmisions (during part throttle). It is closed during open loop. Blocking the EGR does not increase performance.
[b]<FONT COLOR="red">back to stock[/b]
shark is a boost *****</FONT>
sharkcohen is offline   Reply With Quote
2003, affect, bad, block, defective, egr, erg, honda, hp, performance, pilot, prelude, timing, transmission, valve
