What could cause a cylinder not to fire?
Old 11-30-2001, 06:22 AM
Will you make something up for me please?
shamoo's Avatar
Default What could cause a cylinder not to fire?
I posted something similar to this not too long ago, but this is really bugging me.
What could cause a cylinder not to fire? I have pretty much everything replaced (plugs/injectors/injector clips/cap and rotor/MAP sensor/intake fuel pump/FMU/inline fuel pump) I think it has been doing this for a long time now.
Anyway, you guys should be honored that you know the owner of the fastest 3 cylinder turbo Integra out there!!
Please help guys!
Old 11-30-2001, 06:24 AM
Crazydave's Avatar
Default Re: What could cause a cylinder not to fire? (shamoo)
spark plug wires?
did you check the compression in the cylinders?
are you sure the injector is delivering fuel?
are the valves opening and closing?
do you know what cylinder is not firing?
Old 11-30-2001, 06:25 AM
Spade's Avatar
plug wires?
Old 11-30-2001, 08:59 AM
shamoo's Avatar
Default Re: What could cause a cylinder not to fire? (Spade)
plug wires?
My bad, I forgot to mention them. I replaced those too, no change. It's the 3rd cylinder.
Incidentally, here are my comp. test results:
1: 180
2: 180
3: 165
4: 200
I didn't perform a leakdown test, I don't have the tools required for it.
I pulled out the plug wire for the 3rd cylinder while idling, and there wasn't any change. The other wires yielded a pretty noticable change.
Any other ideas? Thanks.
Old 11-30-2001, 09:04 AM
Jim S. '95 Z28's Avatar
Sounds electrical, most likely the plug wire or coil. However, faulty coils do not selectively affect just one cylinder.
Old 11-30-2001, 09:06 AM
integRated109's Avatar
ill bet i would take you down........and when i pass you ill blow oil all over your car
Old 11-30-2001, 09:31 AM
Spade's Avatar
Default Re: What could cause a cylinder not to fire? (integRated109)
i'm stumped.....how nasty is the plug of #3? How does it compair to #4 and #1?
Old 11-30-2001, 09:58 AM
Crazydave's Avatar
plug wires?
1: 180
2: 180
3: 165
4: 200
why is 3 down 9% on compression. when all the others at 180+
[Modified by Crazydave, 6:59 PM 11/30/2001]
Old 11-30-2001, 10:02 AM
Powered by Honda's Avatar
This happened to me just a couple months ago. I too, had everything you mentioned checked to no avail. The culprit ended up being a bunk wire on my interior wiring harness. My friends soldered it and everything was cool again...
[Modified by MugenHondaFormula1, 7:03 PM 11/30/2001]
Old 11-30-2001, 10:06 AM
Crazydave's Avatar
Default Re: What could cause a cylinder not to fire? (MugenHondaFormula1)
switch the number 1 and 3 injectors.. and see if clyinder 3 still doesn't fire
I don't think the compression on 3 should be that low though
Just trying to eliminate fuel/electrical problems
before we start looking for mechanical problems
[Modified by Crazydave, 7:15 PM 11/30/2001]
Old 11-30-2001, 10:12 AM
StreetStyle VTec's Avatar
Default Re: What could cause a cylinder not to fire? (Crazydave)
I once had an oldsmobile Achieva S and two of my pistons weren't firing. I switched out everything that you did and it still didn't fire. Than I found out that everything, and I mean everything on the inside of my ebgine was shot all to hell. But I don't want to put your hopes down.
mouab18c1
10-01-2012 08:40 AM
civic90hatch
03-16-2011 01:09 PM
thunderboy
04-24-2010 08:39 AM
jvillagran2000
15
12-02-2008 02:03 PM
Calvinator
07-21-2006 02:29 AM
Quick Reply: What could cause a cylinder not to fire?
