Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 08-09-2004, 03:15 AM   #1
BlueShadow
Default FAQ B series torque specs
Hey guys,
I just got done again compiling a list of things that I will be torqueing down while I assemble my motor and do my swap. I'll have a FSM handy, but I dont wanna be flipping through pages looking for torque specs, so I got all the numbers beforehand and put them in a word document.
I figured I'd go ahead and share them with you guys. This is right out of the 94+ Integra FSM and the 90-93 Teg FSM.
EDIT: I've updated the list to let you guys know what year/model the specs are applicable to. These are all the specs I got out of the 94+ Teg, 90-93 Teg, 89-91 Civic/CRX VTEC supplement FSM, and my 84-91 USDM Haynes manual. The only number I got from the Haynes though was the Civic/CRX fuel banjo bolt and service bolt specs.
CYLINDER HEAD BOLT TORQUE SPECS (tightening) / (loosening)
8, 4, 2, 6, 10 <---intake order 3, 7, 9, 5, 1
7, 3, 1, 5, 9 <---exhaust order 4, 8, 10, 6, 2
Torque in steps: 22ft-lbs (264in-lbs), Then to 63ft-lbs (756in-lbs) (final spec) 94+ Teg
Torque in steps: 22ft-lbs (264in-lbs), Then to 61ft-lbs (732in-lbs)(final spec) 90-93 Teg / B16's
CAMSHAFT COVER SPECS
13, 9, 5, 1, 3, 7, 11 (side of cam cover closest to intake)
14, 10, 6, 2, 4, 8, 12 (side of cam cover closest to exhaust)
Shown above is one cam cover, sequence is the same for intake and exhaust cam cover.
#1-10 20ft-lbs (240in-lbs) #11-14 7.2ft-lbs (86in-lbs) (94+ B18C specs)
#1-10 16ft-lbs (192in-lbs) #11-14 8ft-lbs (96in-lbs) (B16A specs)
**not sure what the specs are for non-VTEC motors, sorry**
Seat each camshaft by pushing it towards the dizzy side of cylinder head.
VALVE COVER SPECS
7<FONT COLOR="white">______________</FONT>5<FONT COLOR="white">______</FONT>(Intake side of valve cover)
<FONT COLOR="white">_____</FONT>3<FONT COLOR="white">____</FONT>1<FONT COLOR="white">____</FONT>
<FONT COLOR="white">_____</FONT>4<FONT COLOR="white">____</FONT>2<FONT COLOR="white">____</FONT>
8<FONT COLOR="white">______________</FONT>6<FONT COLOR="white">______</FONT>(Exhaust side of valve cover)
7.2 ft-lbs (86in-lbs) (all B series)
FLYWHEEL TORQUE SPECS
<FONT COLOR="white">_______</FONT>1
<FONT COLOR="white">_____</FONT>6<FONT COLOR="white">___</FONT>8
<FONT COLOR="white">___</FONT>4<FONT COLOR="white">_______</FONT>3
<FONT COLOR="white">_____</FONT>7<FONT COLOR="white">___</FONT>5
<FONT COLOR="white">_______</FONT>2
Torque in steps: 19ft-lbs (228in-lbs), 38ft-lbs (456in-lbs), 57ft-lbs (684in-lbs), Then to 76ft-lbs (912in-lbs) (all B series)
PRESSURE PLATE TORQUE SPECS
<FONT COLOR="white">_____</FONT>6<FONT COLOR="white">___</FONT>3
<FONT COLOR="white">_____</FONT>4<FONT COLOR="white">___</FONT>5
Torque in steps: 5ft-lbs (60in-lbs), 10ft-lbs (120in-lbs), 14ft-lbs (168in-lbs), Then to 19ft-lbs (228in-lbs) (all B series)
FUEL FILTER BANJO BOLT
25ft-lbs (300in-lbs) (94+ Teg specs)
16ft-lbs (192in-lbs) (90-93 Teg / B16 / 89-91 Civic CRX specs)
FUEL FILTER SERVICE BOLT
11ft-lbs (132in-lbs) (94+ GSR specs)
9ft-lbs (108in-lbs) (90-93 Teg / B16 / 89-91 Civic CRX specs)
HEADER A-PIPE TO B PIPE (x3)
40ft-lbs (480in-lbs) (all B series)
B PIPE TO CAT (x2)
12ft-lbs (144in-lbs) (all B series)
SHIFT LINKAGE EXTENSION ROD TO TRANNY BOLT (8x1.25mm)
16ft-lbs (192in-lbs) (90+ Teg specs)
12ft-lbs (144in-lbs) (B16 specs)
SPEED SENSOR TO TRANNY BOLT
9ft-lbs (108in-lbs)
ALTERNATOR TOP BOLT
17ft-lbs (204in-lbs) (all B series)
ALTERNATOR BOTTOM BOLT
33ft-lbs (396in-lbs) (all B series)
CRANKPULLEY BOLT
130ft-lbs (1560in-lbs) (90+ Teg)
If the crankpulley bolt is new:
145ft-lbs (1740in-lbs) loosen it a little, then re-tighten to 130ft-lbs (final spec)
87ft-lbs (1044in-lbs) (B16A, first gen)
**not sure what torque is for B16A2 and B16A3's**
TIMING BELT TENSIONER
DRIVER SIDE BRACKET TO BLOCK (x3)
DRIVERS SIDE BRACKET STUD AND BOLT
54ft-lbs (648in-lbs) (all B series)
DRIVER SIDE ENGINE TO CHASSIS MOUNT BOLT
TRANNY MOUNT TO TRANNY BOLTS (x3)
TRANNY MOUNT TO CHASSIS BOLT
REAR ENGINE BRACKET TO TRANNY BOLTS (x3)
43ft-lbs (516in-lbs) (1 passenger side) 86.8ft-lbs (1041in-lbs) (2 driver side) (94+ Teg specs)
43ft-lbs (516in-lbs) (90-93 Teg / B16 specs)
REAR ENGINE BRACKET TO MOUNT BOLT
43ft-lbs (516in-lbs) (all B series)
REAR MOUNT TO REAR SUBFRAME BOLTS (x3)
TRANNY TO BLOCK BOLTS (x5)
47ft-lbs (564in-lbs) (all B series)
LONG AND SHORT STARTER BOLTS
CLUTCH COVER LOWER BOLTS (8mm)
CLUTCH COVER UPPER BOLTS (6mm)
9ft-lbs (108in-lbs) (all B series)
INTERMEDIATE SHAFT TO BLOCK BOLTS (x3)
28ft-lbs (336in-lbs) (all B series)
FRONT AND REAR STIFFENER TO TRANNY BOLT
42ft-lbs (504in-lbs) (all B series)
FRONT AND REAR STIFFENER VERTICAL BOLTS
INTAKE MANIFOLD BOLTS
EXHAUST MANIFOLD BOLTS
23ft-lbs (276in-lbs) (all B series)
BALL JOINT CASTLE NUT
LCA TO DAMPER FORK LOWER NUT
DAMPER FORK UPPER BOLT
32ft-lbs (384in-lbs)
32mm AXLE SPINDLE NUT
134ft-lbs (1608in-lbs)
OIL DRAIN PLUG
TRANNY FILL PLUG
TRANNY DRAIN PLUG
29ft-lbs (348in-lbs)) (all B series)
SPARK PLUGS
Modified by BlueShadow at 9:39 AM 8/13/2004
BlueShadow is offline   Reply With Quote
Old 08-09-2004, 03:34 AM   #2
Westrock2000
Westrock2000's Avatar
Default Re: FAQ B series torque specs (BlueShadow)
nice work with the white lines Click the image to open in full size.
Good post too! Click the image to open in full size.
2006 Lotus Exige
310HP and only 1970 pounds.
Westrock2000 is offline   Reply With Quote
Old 08-09-2004, 03:40 AM   #3
BlueShadow
Default Re: FAQ B series torque specs (Westrock2000)
hehehe, thanks...I didn't like how H-T wouldn't accept my spaces so I put some white underlines in to get around it.
Old 08-10-2004, 04:24 PM   #4
LagunaSecaEG
LagunaSecaEG's Avatar
so all B-series motors have the same torque specs?
1992 Honda Civic Hatch CX
LagunaSecaEG is offline   Reply With Quote
Old 08-10-2004, 04:28 PM   #5
Jester88Si
Jester88Si's Avatar
Send a message via AIM to Jester88Si
Great info for those who don't have the FSM
- Victor
2013 G37
94 Del Slo b18b1 auto
Jester88Si is offline   Reply With Quote
Old 08-10-2004, 04:28 PM   #6
Mr_CRX
Mr_CRX's Avatar
iTrader Rating: (1)
Send a message via AIM to Mr_CRX
I didnt even notice those at first on my laptop screen. I wondered how he made those all spaced out Click the image to open in full size.
Anyways, good job! Click the image to open in full size. This will help a lot of people out.
Mr_CRX is offline   Reply With Quote
Old 08-10-2004, 04:33 PM   #7
Blaze45
Blaze45's Avatar
This thread rocks! Thanks! Click the image to open in full size. Click the image to open in full size.
Blaze
Blaze45 is offline   Reply With Quote
Old 08-10-2004, 04:36 PM   #8
kaoss_11
B A N N E D
Send a message via ICQ to kaoss_11 Send a message via AIM to kaoss_11
Cool buddy
kaoss_11 is offline   Reply With Quote
Old 08-10-2004, 06:57 PM   #9
BlueShadow
Default Re: FAQ B series torque specs (LagunaSecaEG)
When I get home in a few hours I'll check and see if I can find B16 specs, and I'll also add some of the CRX specs if they are different.
Old 08-11-2004, 01:02 AM   #10
BlueShadow
I just got done going through all the specs, and I broke them down by the different B series specs too.
Old 08-11-2004, 05:22 AM   #11
crxkane
crxkane's Avatar
good job, realy need this going through the process of building a motor and i have 4 different books looking at them all to see the different specs sux's, this realy helps need to keep this post bookmarked..... Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Let me show you how we do this "dallas pull up"....
Good buyers/sellers:
JDM_RICE_MONSTER, b20turbojason, b20vtecv8killer, silverEH2, B18c7t, TurboMark, Alikat, 1quickvr4, 99SlammedCivic, msgboardking
crxkane is offline   Reply With Quote
Old 08-11-2004, 07:26 AM   #12
crx2fast
crx2fast's Avatar
Send a message via AIM to crx2fast
Default Re: FAQ B series torque specs (crxkane)
nice write-up. very helpfull Click the image to open in full size.
god i love crx's
realhomemadeturbo
crx2fast is offline   Reply With Quote
Old 08-13-2004, 08:32 AM   #13
BlueShadow
Default Re: FAQ B series torque specs (crx2fast)
Hey guys, thanks for the replies.
I just wantd to let you all know that I went ahead included the specs in INCH POUNDS as well. I used the online calculator at http://www.onlineconversion.com
Modified by BlueShadow at 10:41 AM 8/13/2004
Old 08-13-2004, 08:36 AM   #14
APEX CRX
APEX CRX's Avatar
good looking out Click the image to open in full size.
BAR certified B18C1 89 CRX Track Car 10/2004 sold =(
Bone stock 95 EJ coupe 2/2012 I'm back in the game !!
APEX CRX is offline   Reply With Quote
Old 05-25-2005, 12:36 AM   #15
RATED EG
RATED EG's Avatar
Send a message via AIM to RATED EG
Default Re: FAQ B series torque specs (APEX CRX)
niceeeeeeee Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
RATED EG is offline   Reply With Quote
Old 05-25-2005, 02:28 AM   #16
limpy
limpy's Avatar
Default Re: FAQ B series torque specs (RATED EG)
printing now... awsome definatly need to go to the faq section... vap take care of it. Click the image to open in full size.
"if it doesn't fit, force it. if it breaks then it needed to be replaced anyway."
limpy is offline   Reply With Quote
Old 11-06-2005, 04:20 PM   #17
transpar_nt
transpar_nt's Avatar
this just saved my *** Click the image to open in full size.
Originally Posted by Ricey McRicerton
Is it necessary for me to drink my own urine? No! I drink it because it's sterile, and I like the taste!
Originally Posted by litterbox
Pee drinkers unite!
<FONT COLOR="#0099FF">VOUCHES</FONT> <FONT COLOR="grey">| DaX | UrbanFuturistic | RalliartRSX | kadburry | R6 | 92integraVTECgsr | hatchi | BuilltB18C5 | 92HB_HB | qat727 | EFfinSedan |</FONT>
<FONT COLOR="#003366"></FONT>
transpar_nt is offline   Reply With Quote
Old 11-06-2005, 04:55 PM   #18
31flavorscivic
31flavorscivic's Avatar
Send a message via AIM to 31flavorscivic
Default Re: FAQ B series torque specs (transpar_nt)
Planning an ls/vtec over here, so if I ever get that off the ground *saves to hard drive*
91 civic SI - Freshly painted white, DOHC ZC swap
My Websites: http://bumrockerforlife.mine.nu, http://www.iREALLYhatechurch.com
Originally Posted by 31flavorscivic
"Down in 'da Hood" is not an acceptable language here.
I FOUND 20 PAGES INDEXED FROM HONDA TECH'S CLASSIC FUNNY SEX STORIES THREAD BEFORE IT WAS DELETED. CLICK HERE FOR THE INDEX
Good sellers: Molitor, Tippyman, STDClayton, EFn JP (ty so much)
31flavorscivic is offline   Reply With Quote
Old 04-08-2006, 09:19 PM   #19
4gencivicef9
4gencivicef9's Avatar
oil pump , water pump do you have the specs for these
OUT OF THE GAME!
4gencivicef9 is offline   Reply With Quote
Old 05-26-2006, 12:46 PM   #20
SD_Lurker
HT White Ops
SD_Lurker's Avatar
iTrader Rating: (4)
Send a message via AIM to SD_Lurker
sweet
SD_Lurker is offline   Reply With Quote
Old 05-26-2006, 01:45 PM   #21
ludesrv
Nice. Bookmarked.
ludesrv is offline   Reply With Quote
Old 12-16-2006, 10:40 AM   #22
DRAG_WORKX
DRAG_WORKX's Avatar
DRAG_WORKX is offline   Reply With Quote
Old 12-20-2006, 01:47 PM   #23
SD_Lurker
HT White Ops
SD_Lurker's Avatar
iTrader Rating: (4)
sweet thread!
Old 12-20-2006, 01:48 PM   #24
Ass$nyper
Pirate General...YARRRR
Ass$nyper's Avatar
Send a message via AIM to Ass$nyper
holy **** you need a Click the image to open in full size. thank you much PM user Tyson and ask him to pop this in the FAQ v2 he helped put together.
It would benifit a ton of us
again Click the image to open in full size.
-Max
Es gibt keinen Schaden beim Verzichten auf Dinge. Es dürfte sogar gut für Sie sein, sich an ein weiches Leben nicht zu gewöhnen.
Ass$nyper is offline   Reply With Quote
Old 12-20-2006, 02:26 PM   #25
ludesrv
Default Re: FAQ B series torque specs (Capt. Blonde Beard)
It's already in there.
1990, 92, b16, b16a, b18, brake, cam, civic, head, honda, sequence, specifications, specs, torque, torquing
