B16 in 91 Rex....hesitates / boggs
#26
Re: B16 in 91 Rex....hesitates / boggs
your running the wrong injectors as said before. Either 1. get rid of the resistor box or 2. get some obd0 injectors. You can put the crx SI injectors in and see if that makes it better until you find the right ones.
#27
on my dads ef we swapped it with a b16 and had all type of problems. idle, it bogged down. didnt have much power etc even swapped it to obd1 it was pretty lame still, so last weekend swapped and made it into an ls vtec and omg day and night diference
#28
It's the o2 sensors you have to switchthem and the problem will go away. I had this problem when I did my swap. I cut the wires for both o2 sensors and switched them
WWTeg
03-09-2008 05:00 PM
ek_slut
07-15-2005 02:15 PM
gringo7718
21
04-12-2004 09:23 AM
