Old 08-01-2004, 09:56 AM   #1
confucius
Default car shakes when AC is turned on
anyone know what the problem is?
my whole car shakes, and rattles when i turn the AC on.
any fix?
thanks
confucius is offline   Reply With Quote
Old 08-01-2004, 10:20 AM   #2
Brand
Brand's Avatar
Send a message via AIM to Brand
Default Re: car shakes when AC is turned on (confucius)
doesit do it only at idle? or while u are driving too?
2006 Acura RSX Type-S for sale!
Brand is offline   Reply With Quote
Old 08-01-2004, 10:44 AM   #3
chrisnova
chrisnova's Avatar
WHat RPM is it before AC and what RPM after. It is normal for the car to sometimes run a little lower RPM with e AC on. The throttle regulator usually compensates for the additional load of the compresosr and the alternator when the AC is on, but if the engine idles low to begin with, plus perhaps is not well tuned, then this willnot be an uncommon problem. Quick fix is to raise your idle and RPM. LOng term fix is to dig into the engine to find out why it runs rough, if that is the case.
chrisnova is offline   Reply With Quote
Old 08-03-2004, 09:49 PM   #4
confucius
Default Re: car shakes when AC is turned on (Brand)
i think it only shakes when idle.
Old 08-03-2004, 10:13 PM   #5
jaydeemmmm
jaydeemmmm's Avatar
Send a message via AIM to jaydeemmmm
My Teg is like that sometimes. On idle, when you turn the steering wheel it also shakes. When my fan goes, my car feels like it's going to die. I haven't fixed it yet, but I got a good guess on what's wrong. After warm up, what's your RPM when you are on idle? Try this out. When your car is finish warming up(800-1000 RPM), tap the accelerator slightly and see if the RPM starts jumping up and down by itself. If it jumps up and down by itself, then there might be something wrong. Try tightening your throttle cable. Let us know your results.
JayDeeMmMm...
Holla.
[url="http://www.HondaHookUp.com"]http://www.HondaHookUp.com[/url] - JdmTeG
[url="http://www.Team-Integra.net"]http://www.Team-Integra.net[/url] - JayDeeMmMm
[url="http://www.g2ic.com"]http://www.g2ic.com[/url] - JayDeeMmMm_g2
Old Honda-Tech member, but forgot login name and password. I know, shame on me. [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
90 Integra LS - Traded
91 CRX HF - Sold
94 Integra LS - Current
LS/V
jaydeemmmm is offline   Reply With Quote
Old 08-03-2004, 10:19 PM   #6
tsdenny
tsdenny's Avatar
check the belts
WTB
for my 95 civic ex rear lip, amber corners, MR hood, MR trunk, oem fog light coupe,,
tsdenny is offline   Reply With Quote
Old 08-03-2004, 10:24 PM   #7
B2FiNiTY
B2FiNiTY's Avatar
iTrader Rating: (2)
Send a message via AIM to B2FiNiTY
Default Re: car shakes when AC is turned on (chrisnova)
It should run at higher rpms to compensate for the parasitic draw it is taking.
B2FiNiTY OG Vouch Thread
http://hondamarketplace.com/showthread.php?t=762550
B2FiNiTY is offline   Reply With Quote
Old 08-03-2004, 10:47 PM   #8
riceball777
riceball777's Avatar
it shakes because the ac drad is bring the idel lower than 700rpm which will cause the car to chake
my car did this and it got so bad that if i ever turned on the ac the car would just die, the computer did not bring up the idel to compansate for the ac drag. it turned out that my computer was bad and as soon as i tryed another computer it fixed the problem.
but you can just try to turn you idel up a lil
2002 turbo GPW s2000 442whp 91 octane gtx3576r.
http://honda-tech.com/showthread.php?t=3152804
2.4 f24 stroker build http://honda-tech.com/showthread.php?t=3214780
riceball777 is offline   Reply With Quote
Old 08-04-2004, 12:19 AM   #9
SOL1D
SOL1D's Avatar
my integ use to shake bad when the a/c was on but the idle was fine, just when the a/c was on, at the same time i was changing out my motor mounts, when i did the shaking was gone, i guess the mounts were so bad that when the extra load on the engine was put on, the engine shock more which transfered to the cabin *shrugs* that was my only problem
SOL1D is offline   Reply With Quote
Old 08-04-2004, 08:00 AM   #10
confucius
Default Re: car shakes when AC is turned on (SOL1D)
dont know what rpm is running at, have to check after work.
but after warm up, it idels about half a centimeter below 1.
Old 08-04-2004, 08:26 AM   #11
PlastikOwl
Guest
Posts: n/a
mine does it for a split second when the compressor turns on.
Old 08-04-2004, 09:43 AM   #12
confucius
Default Re: car shakes when AC is turned on (PlastikOwl)
its probably the idle since it only happends when the car is in idle.
i think the cars idle at about 600 rpm.
Old 08-05-2004, 09:31 AM   #13
confucius
yea its the idel. the shaking stops when i rev the car.
Old 08-05-2004, 10:10 AM   #14
Vu
Vu's Avatar
Send a message via AIM to Vu
Default Re: (confucius)
When I'm at a red-light with my A/C on, sometimes my rpm drops to 550rpm for a few seconds, than moves back up to 750. It would just alternate like that every few seconds. As long as it's at 750, everything is ok, but as soon as it drops to 550, the car, most noticeably my exhaust, begins to vibrate.
"There are five possible operations for any army. If you can fight, fight; if you cannot fight, defend; if you cannot defend, flee; if you cannot flee, surrender; if you cannot surrender, die. " - Sima Yi "Romance of the 3 Kingdoms"
Vu is offline   Reply With Quote
Old 08-12-2004, 01:46 PM   #15
confucius
Default Re: (Vu)
fixed it.
by turning the throttle screw and tightening the throttle cable a bit.
Old 08-12-2004, 02:01 PM   #16
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
Originally Posted by confucius
fixed it.
Throttle cable should have no effect, unless it's too tight and it's idling faster than it should.
Idle at normal operating temperature w/o any accessories on should be between 700-800 rpm. Does it idle like this right now? If it idles higher, but idles normally when the A/C is on, then you have a problem somewhere else, since the ECU is supposed to bring the idle up when you turn on the A/C.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 08-12-2004, 04:32 PM   #17
confucius
Default Re: (PatrickGSR94)
my idle before was at 500 rpm.
when i turn the a/c on, it idel near the 2nd bold line after 0.
prolly around 300 rpm.
Old 08-12-2004, 05:55 PM   #18
Gee3
Gee3's Avatar
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Send a message via AIM to Gee3
If your motor mounts are old and bad, that may contribute to the bad shake. Then again, if you put ES bushings in the motor mounts it'll hsake as well. Just a thought.
I learn something new everyday. I have a 5 year old daughter!
Vouch Thread: http://honda-tech.com/zerothread?id=1031408
Softball Team Sponsored by ARTURBO.COM http://images.honda-tech.com/set1/smile/emthup.gif
Gee3 is offline   Reply With Quote
Old 08-12-2004, 07:55 PM   #19
Malakai
1994 Acura Integra
My Garage
Malakai's Avatar
u could just roll the windos down and not use the a/c?
94 GSR - Hytech replica header, f&f type 2, sk2 mani, pwjdm whale
98 DX Hatch- motor dead
Malakai is offline   Reply With Quote
Old 08-13-2004, 07:15 AM   #20
nocable4me
nocable4me's Avatar
speaking of AC noises..... Whenever i turn on the AC and accelerate, i hear a small whinning noise and when im not accelerating the noise is gone. Anyone have any idea what it is?
10/25/04
stolen white 94 LS sedan
sad sad day
11/12/04
5speed 95 EX http://images.honda-tech.com/set1/smile/emthup.gif V-TEC http://images.honda-tech.com/set1/smile/emthup.gif sedan accord
3/20/08
99 TL .... time for a little luxury
nocable4me is offline   Reply With Quote
Old 08-13-2004, 11:11 AM   #21
confucius
Default Re: (nocable4me)
my ride has black vinyl, rolling the window down will not do.
Old 08-15-2004, 01:55 PM   #22
Malakai
1994 Acura Integra
My Garage
Malakai's Avatar
that would be the belt moving faster. kinda like a blower.
Old 08-15-2004, 09:09 PM   #23
PnX-R
One of the civics at the dealership did that. The problem with the civic was that the pump would lock up intermittently..
Honda Technician
PnX-R is offline   Reply With Quote
2008, ac, accord, car, honda, idle, rattles, shake, shakes, shaking, shekes, shut, start, turn, turned
