Signs of bad rotor?
Old 07-22-2004, 07:36 PM
djtony5's Avatar
Default Signs of bad rotor?
How do you tell whether your rotor is bad or not? Mine have some rust on top of the middle on the rotor.
Old 07-22-2004, 07:38 PM
timmy8151's Avatar
Default Re: Signs of bad rotor? (djtony5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">How do you tell whether your rotor is bad or not? Mine have some rust on top of the middle on the rotor.</TD></TR></TABLE>
Nothing wrong with rust on the rotor or hub. If you had bad rotors, there would be some shaking when you brake.
Old 07-22-2004, 07:52 PM
Greg James's Avatar
When the rotors are cool, feel the surface, it should be smooth, if there are any grooves, they could be bad
Old 07-22-2004, 07:58 PM
djtony5's Avatar
Hahaha sorry guys...I mean the rotor inside the distributor cap.
Old 07-22-2004, 08:05 PM
sabotage7's Avatar
omg....okay.....is the metal burnt or plastic melted? thats usually a good sign!
IVI
IVI's Avatar
if you have rust on the distributor rotor change it.
also check to see why your getting moisture in there.
it shouldnt be rounded off. also check the cap pins.
Old 07-22-2004, 08:10 PM
djtony5's Avatar
Default Re: Signs of bad rotor? (IVI)
hmm I just went out and inspect closely and notice that there were a little crack on the cap. It just a little crack though, not much. I guess I should change both of these and hopefully my cel light goes away. No wonder why my cel light comes on everytime it humid outside!
Old 07-22-2004, 08:14 PM
sabotage7's Avatar
that would explain it! ....your lucky your car still runs! ive had customers come in w/cracked caps and thier car wouldnt run at all bc of it.
Old 07-22-2004, 08:33 PM
IVI
IVI's Avatar
Default Re: Signs of bad rotor? (sabotage7)
cracked cap your losing electricity in those cracks. what code are you throwing? i dont think there is a code for a bad distributor cap or cracked cap or anything like that.
let me know what code your throwing it could be something completely diffrent.
Old 07-22-2004, 08:50 PM
djtony5's Avatar
It a code 63, Secondary o2 sensor. Iono how it could cause that either? I was just wondering because I can't figure how to get the cel to dissapear.
Old 07-22-2004, 09:48 PM
IVI
IVI's Avatar
why dont you take a look at your secondary o2 sensor.
Old 07-22-2004, 10:50 PM
Stripped Honda's Avatar
if there is rust on the rotor then you probally have a bad dizzy the bearring it going bad just be carefull they freeze up sometimes and you will get stuck ... i recomend buying a new dizzy housing and putting your old coil and ignitor in it
roboda
12-17-2008 10:51 AM
superhatchbackbros
05-19-2005 04:54 PM
-faded-
07-19-2004 02:54 PM
del_sol
04-17-2003 07:02 AM
TheHater
01-17-2003 06:14 PM
Quick Reply: Signs of bad rotor?
