single cam boost
Old 07-11-2006, 05:13 AM
dademax24's Avatar
Default single cam boost
hey i wanted to see if anyone could help i have an eg hatch d15b7 i wanted to go boost like 7-8 punds the most just to get around for now while i get a b motor but i also want to keep my ac what would i need in order for that to be possible i heard something about the downpipe and a special turbo manifold please help and make any suggestions please thank you ........
Old 07-11-2006, 05:46 AM
Everyones Hero's Avatar
Default Re: single cam boost (dademax24)
When you're looking for a turbo manifold make sure you find one that is "AC Compatible". Most websites that you can order from will tell you if it's AC compatible.
If you're looking to turbo your D now and boost the B later you will have to buy a new manifold. You might be better of waiting to do your swap before you boost.
Old 07-11-2006, 06:06 AM
Super Trooper's Avatar
You can keep your a/c, but you wont be able to do a 3" down pipe.
Old 07-11-2006, 06:08 AM
LowSlow93Sol's Avatar
Default Re: (Super Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Trooper &raquo;</TD></TR><TR><TD CLASS="quote">You can keep your a/c, but you wont be able to do a 3" down pipe. </TD></TR></TABLE>
Why not? Down pipe size has nothing to do with A/c or not. Its the manifold and size of the turbo that will let you keep a/c.
Old 07-11-2006, 06:13 AM
Default Re: (onefast93sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefast93sol &raquo;</TD></TR><TR><TD CLASS="quote">Why not? Down pipe size has nothing to do with A/c or not. Its the manifold and size of the turbo that will let you keep a/c.</TD></TR></TABLE>
Depending on how everything is setup a 3" could cause you to loose AC.
Best thing to do is find an AC compatible turbo setup.
Old 07-11-2006, 06:14 AM
skylinetph26's Avatar
I have heard about downpipes rubbing against the fan on the AC, so it could be a problem, correct me if Im wrong though.
Old 07-11-2006, 07:27 AM
slowsol95's Avatar
Default Re: (skylinetph26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinetph26 &raquo;</TD></TR><TR><TD CLASS="quote">I have heard about downpipes rubbing against the fan on the AC, so it could be a problem, correct me if Im wrong though. </TD></TR></TABLE>yes you are right. for all of your d series turbo questions, visit turbod16.com. there is alot of information there for what you need to make a reliable turbo d series.
Old 07-11-2006, 09:25 AM
akdasniper's Avatar
Default Re: (slowsol95)
TURBOD16.COM
turbohatch96y7
06-18-2009 06:51 AM
hondaracin24
02-21-2007 01:03 PM
aalb1
04-09-2005 09:53 AM
downeyballz
03-02-2005 01:28 PM
Drag_On
09-22-2003 10:00 PM
Quick Reply: single cam boost
