how can you tell if a fuel pump is going bad? 93 civic-b16
Old 07-21-2004, 06:15 PM
DjN3M3S1S's Avatar
Default how can you tell if a fuel pump is going bad? 93 civic-b16
well ive been having problems starting my car lately. sometimes i dont hear my fuel pump ingage when i turn the key half ways, and doesnt start. sometimes i do hear it, it starts, and then dies right away. its been going on like this for awhile, just started getting worse lately.
and if i do need a new one, do i buy one to match b16 or the 93 civic. cuz i looked online and its seems to be different parts.
if anyone could help that would be great.
thanks
Old 07-21-2004, 06:46 PM
bens_redeg's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (DjN3M3SiS)
it could be your main relay;that controls your fuel pump but if you find out that it is your fuel pump get one for the car not for the motor are you throwing any codes
Old 07-21-2004, 06:51 PM
VvPeachyvV's Avatar
i'm have the exact same problem with my d series motor, i haven't got the chance to see what it is tho, but i thought about it being the main relay, i'm not quite sure how to check that though =/
Old 07-21-2004, 07:00 PM
Ricey McRicerton's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (VvPeachyvV)
Take a look at the FAQ thread. There is a how to on checking/fixing it.
Old 07-21-2004, 08:51 PM
wizzards581's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (bens_redeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bens_redeg &raquo;</TD></TR><TR><TD CLASS="quote">it could be your main relay;that controls your fuel pump but if you find out that it is your fuel pump get one for the car not for the motor are you throwing any codes</TD></TR></TABLE>
the civic is putting less lph (liters per hour). i rather get the one for the motor and not the car.
i have gsr fuel pump in my civic for the b18c.
Old 07-21-2004, 09:08 PM
Spence's Avatar
take the fuel pump out hook up a couple of wires and test it on the battery and see if the motor is spinning !!!!!!!!!!!! Thats how i did it and i think thats how the helms tell you to do it
Old 07-21-2004, 09:11 PM
DjN3M3S1S's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (Ricey McRicerton)
where do i find
"Take a look at the FAQ thread. There is a how to on checking/fixing it. "
Old 07-22-2004, 01:57 AM
LSpimpTEC's Avatar
same thing happened to me...main relay....i have an extra one if you want to buy it. pm me
Old 07-22-2004, 03:22 AM
Silent_Bob's Avatar
If the main relay doesn't klick, open the door and hit the left side of the dashboard, works everytime, you can also keep the starter going while hitting the side of the dashboard and the car will start. If the car has been in the sun for a while, thats enough to make the realy not click, or if the car has been used for like 10minutes.
Old 07-22-2004, 03:12 PM
DjN3M3S1S's Avatar
Default Re: (Silent_Bob)
wow. never thought of hitting the side of the dash. im thinkin it may be the main relay, because its starts every morning, during the day when i drive it in this AZ heat is when i have the most problems. also when it sits in the sun all day, it wont klick until the its starts cooling off. and at night, it always starts..
think is could be the main relay?
if soo how much do they run
Jay_Mills
03-16-2012 10:05 AM
Jaynik
10-22-2010 04:55 PM
Nicram
08-27-2007 06:16 PM
kaychi
03-28-2007 03:56 PM
93FlatBlackHatch
12-30-2006 03:22 PM
Quick Reply: how can you tell if a fuel pump is going bad? 93 civic-b16
