What crank pulley/Harmonic balancer are you running?
Old 07-13-2004, 04:48 PM
hondaguyef's Avatar
Default What crank pulley/Harmonic balancer are you running?
I want to see what everyone is running. If you select one please reply and post the setup or just simply if your car is turbo/supercharged or all motor. Also if you have positive or negative feedback about one of the pullies listed please post. Thanks
Phil
Old 07-13-2004, 04:50 PM
PM-Performance's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (hondaguyef)
stock ITR here
Old 07-13-2004, 04:55 PM
Jokerluv's Avatar
stock D series
Old 07-13-2004, 04:57 PM
SpeedDreamz.com's Avatar
Default Re: (Jokerluv)
unorthodox and oe
Old 07-13-2004, 05:15 PM
jdkindle's Avatar
stock K series
Old 07-13-2004, 05:17 PM
SIckH22Atch's Avatar
Default Re: (jdkindle)
UR... makes for quick revving
Old 07-13-2004, 05:22 PM
EGkid's Avatar
Default Re: (SIckH22Atch)
oem gsr
Old 07-13-2004, 05:24 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv &raquo;</TD></TR><TR><TD CLASS="quote">stock D series</TD></TR></TABLE>
Old 07-13-2004, 05:40 PM
Blown90hatcH's Avatar
Default Re: (tegunderpressure)
N1 pulley killed my oil pump after 1k miles. Now I am stock ITR oil pump with Fluidampr crank pulley.
Old 07-13-2004, 05:41 PM
Rod.'s Avatar
oem LS
E-Town4229's Avatar
CTR here. works well. havent noticed any problems yet. single pulley is key with such a tight space.
-Roger
Old 07-13-2004, 05:45 PM
Robb's Avatar
Default Re: (E-Town4229)
stock H22 pulley.
Old 07-13-2004, 05:49 PM
wpgcivic's Avatar
stock b16
Old 07-13-2004, 06:05 PM
GSRswapandslow.
Guest
Posts: n/a
stock ITR
Old 07-13-2004, 06:09 PM
opto_isolator's Avatar
Haha - no Dick Hickman listed? Comon now, his crank pulley is only like freaking 4 ozs or something.....
Old 07-13-2004, 06:12 PM
jdmoutlaw's Avatar
Default Re: (opto_isolator)
Stock b16, have yet to have a need for anything more . lol
Old 07-13-2004, 06:57 PM
doublej's Avatar
You IM me for my experiences since I advertise Fluidampr in my sig. Here go's.
The Fluidampr test was conducted at my shop. I freely admit to understanding little on their computer test screens. But we dyno'd more than a dozen prototypes both sweep runs and at various static rpms. It's quite a process to map the harmonics. Fred Rowland is a very smart man, an enthusiest, and hands-on knowlege about their products. I enjoyed and learned alot during the test. I believe in the company and support the product.
My "personal" conclusions, based on this test and prior experience in other forms of four cylinder auto racing, were the Honda engine does need some sort of damper. And tailored to the engines use. The harmonics of a race engine are not the same as a stock street engine. That is the point. The oil pump and the bearings will thank you.
Can you get by with stock or no damper? Others obviously have but my luck doesn't run that way. More important, you have alot of money invested in your engines and want them to last a reasonable time. A little more than $300 is cheap compared to fixing/replacing an engine.
And you can open the hood and see it! Can't do that with piston.
Howard Anderson, AR Fabrication, uses the Fluidampr Racedampr. Jason Hunt and Brian Ballard (on it's way) use the Fluidampr Streetdampr. Both SFI approved. The Streetdampr fits their CRX's without mods to the traction bar. I think Z10 has a modified bar for the Racedampr and ATI damper.
Jim
Old 07-13-2004, 07:02 PM
Jared's Avatar
I use OE since I've seen two oil pumps destroyed with N1 and Unorthodox.
Old 07-13-2004, 07:45 PM
* B A N N E D *
chris_m's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (Jared)
dh-racing.com
Old 07-13-2004, 08:16 PM
bomber's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (alld16a)
Since someone brought this subject up...I have been meaning to ask about the SFI 18.1 spec harmonic balancer rule for cars running 10.99 or faster.
I know the OEM one isn't supposed to be legal, but it seems everyone at the track is still using the stock one.
So, is this some rule that doesnt get enforced or what? If it is something I need to worry about, who makes a H22A balancer?
Old 07-13-2004, 08:17 PM
* B A N N E D *
chris_m's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (bomber)
I think it's just one of those rules that isnt really paid attention too.
Old 07-13-2004, 09:02 PM
OaksRacing's Avatar
ATI steel damper with Peterson's Dry sump system - This was the prototype for their H22 Dry Sump System.
Check it out - http://www.cardomain.com/id/oaksracing
Steve Sr.
Old 07-13-2004, 09:12 PM
Better than steak
Arturbo's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (doublej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublej &raquo;</TD></TR><TR><TD CLASS="quote">You IM me for my experiences since I advertise Fluidampr in my sig. Here go's.
Jim</TD></TR></TABLE>
Jim Justice is my hero. I too run the Fluidamper and thanks for all the research you did with it jim. I have so much respect for you..
art
Old 07-14-2004, 08:29 PM
Tbone's Avatar
I run the ATI steel unit.
Jim Justice also Does all my machine work
And yes z10 can make a mod kit for the units to clear traction bars in crx's,(thanks to me )
Old 07-15-2004, 09:56 AM
turbo*s2k's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (Tbone)
Stock b16a2 here!
Quick Reply: What crank pulley/Harmonic balancer are you running?
