Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 11-21-2001, 04:03 PM   #1
internet ay
Default how do i get pinstriping off without hurting paint
is there a good way to get the pinstriping off i am assuming maybe i should compound it when i am done too any suggestions would help thanks matt
internet ay is offline   Reply With Quote
Old 11-21-2001, 04:36 PM   #2
kefka
kefka's Avatar
iTrader Rating: (1)
Send a message via AIM to kefka
Default Re: how do i get pinstriping off without hurting paint (internet ay)
depends if the pin has a clear coat over it...if not take a razor blade to it..;p
Nothing can beat the music of hundreds of voices screaming in unison!
-kefka
kefka is offline   Reply With Quote
Old 11-21-2001, 06:34 PM   #3
Xstatic
Default Re: how do i get pinstriping off without hurting paint (madeinjapan)
if it is the stock pin stripe, and it is more than a couple of yrs old, then there is no way around it....it has sat in the sun for so many years that it is pretty much a permanent part of the paint now.......
Xstatic is offline   Reply With Quote
Old 11-23-2001, 11:20 AM   #4
02WRX
02WRX's Avatar
Default Re: how do i get pinstriping off without hurting paint (Xstatic)
Actually I removed my pinstripes after 11 years on the car. What I did was to first start peeling off a pinstripe. Then I used a hair dryer to heat up the pinstriping in the direction I was going (medium works better than the full hot setting for this) and peeling the pinstriping back. This gets the big majority of the pinstriping off. For the bits that didn't come off and the general adhesive residue left on the paint, I used this stuff called "Removes-All - Graffiti Remover Towels" I don't know where to get them (they were at work) but they're made by Ultra-Chem & their # is 800 451 0726. The towels did a great job of getting off all the extra stuff (they do seem to remove any wax on the car) but don't seem to damage the paint.
Eric
Oh yeah - If you get some of those towels, get rubber gloves - they ain't good for any sort of contact.
02 WRX - Boost is good - AWD is good - Boost+AWD rocks, especially with 236whp!
formerly the artist known as 90CivicEX
<---- check avatar for H-T eligibility verification!
02WRX is offline   Reply With Quote
Old 11-23-2001, 11:28 AM   #5
WuShu
WuShu's Avatar
Send a message via AIM to WuShu
Default Re: how do i get pinstriping off without hurting paint (90CivicEX)
heat is the key, take a blow dryer to it, and try to peel as much of it off as possible, it also all depends on how long its been on the car but generally rule of thumb is if you can peel off a tiny bit from the ends then it will most likely come off.
proud member of:
[B]HB SQUAD[/B]
"We dont need no stinkin trunks!"
Marked001: My wife gave me a track day for our anniversary!
Mariocrx: Thats right up there with ****! [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
WuShu is offline   Reply With Quote
Old 11-23-2001, 01:21 PM   #6
CrXgUrLeE
You can try to use Windex and a razor blade. I heard that works.
CrXgUrLeE is offline   Reply With Quote
Old 11-25-2001, 05:27 PM   #7
sihatchbackcivic1993
Send a message via AIM to sihatchbackcivic1993
over the summer we had to pull factory pinstriping off of my friends 91 accord all we did was use blow dryer and it will wrinkle then grab with ur fingers and pull while heating in front of it to keep it going.DO NOT USE RAZOR BLADE OR ANYTHING BESIDES HAND it will mess up ur paint hella.
sihatchbackcivic1993 is offline   Reply With Quote
all, car, damaged, hurting, paint, peeling, pin, pinstriping, remove, removes, sacramento, stripe, striping, stripping, ultrachem
