Old 07-09-2004, 09:23 AM   #1
sykowmn36
sykowmn36's Avatar
Send a message via AIM to sykowmn36
Default Have 1994 Acura Integra - brakes keep failing for no reason!
My mother has a 1994 Acura Integra. She has had constant brake problems. The ABS light stays on all the time. She takes to the mechanic who says there is nothing wrong. But when she comes to a sudden stop the brake pedal will sometimes go all the way to the floor for no reason. She pumps the pedal and it will return to normal position. She's had new brake pads ,etc... They squeak all the time.
She is at the end of her rope. Any ideas?? Click the image to open in full size.
sykowmn36 is offline   Reply With Quote
Old 07-09-2004, 09:32 AM   #2
Slo Car
Slo Car's Avatar
Default Re: Have 1994 Acura Integra - brakes keep failing for no reason! (sykowmn36)
if she is loosing pressure i.e. the pedal goes to the floor...then it's probably the master cylinder has gone bad...
2004 Nissan Titan SE
92 Integra RS with LS/VTEC swap
Yes...I am a [B]chick[/B] that is into cars!!! [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img]
[B]DA Squad Member #120[/B]
[url="http://www.honda-tech.com/zerothread?id=1146547"]http://www.honda-tech.com/zerothread?id=1146547[/url]
[url="http://www.myspace.com/slocar"]http://www.myspace.com/slocar[/url]
Slo Car is offline   Reply With Quote
Old 07-09-2004, 10:08 AM   #3
Kendall
Kendall's Avatar
Sounds like you need to find a new mechanic.
Check the brake booster and associated hose for leaks and then take the master cylinder and have it checked out.
Grizzly Adams STILL has a beard.
Kendall is offline   Reply With Quote
Old 07-09-2004, 10:44 AM   #4
iH8RICERZ
iH8RICERZ's Avatar
Send a message via AIM to iH8RICERZ
Default Re: Have 1994 Acura Integra - brakes keep failing for no reason! (Kendall)
my 94 gsr has the same exact problems.......my abs light stays on, abs doesnt work, checked the code and my car says its my passenger front wheels speed sensor............then once in a while (not all the time), my brake pedal will go to the floor............i havent replaced the master cylinder in years, so thats probably my problem
2008 Lexus ISF 2006 Infiniti M35 Sport REDZONE Tuned N/A 1994 GSR: STOLEN (10/9/09)
My Vouch Thread http://hondamarketplace.com/showthread.php?t=494064
iH8RICERZ is offline   Reply With Quote
Old 07-09-2004, 01:20 PM   #5
94civicEX
94civicEX's Avatar
Send a message via AIM to 94civicEX
Just like they said, get a new mechanic and a new master cylinder.
Honda-Acura.net Administrator
1999 FBP GSR
2006 ABP TSX 6MT/Navi
94civicEX is offline   Reply With Quote
Old 07-09-2004, 11:55 PM   #6
ctegsta
ctegsta's Avatar
same problem with my 94 , its the master cylinder
ctegsta is offline   Reply With Quote
Old 07-10-2004, 05:21 AM   #7
Cliffjumper2
Cliffjumper2's Avatar
Send a message via AIM to Cliffjumper2
agreed Click the image to open in full size.
"It is not because things are difficult that we do not dare, it is because we do not dare that they are difficult".- Seneca
Cliffjumper2 is offline   Reply With Quote
1994, 199401, 94, acura, booster, brake, brakes, breaks, failing, floor, integra, pedal, pressure, why, working
