Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 07-08-2004, 12:17 AM   #1
Westrock2000
Westrock2000's Avatar
Default Welding with pocket butane torches????
Hey guys, I was wondering if you can do light use welding of like steel and aluminum with these hand held butane torches. They say they can get up to and over 2000*F
Like these little things;
2006 Lotus Exige
310HP and only 1970 pounds.
Westrock2000 is offline   Reply With Quote
Old 07-08-2004, 12:48 AM   #2
dustin
Default Re: Welding with pocket butane torches???? (Westrock2000)
Umm good luck.
How do you plan to "weld" again?
What's your plan for shielding gas?
You can definately *braze*/solder with one though. Silver soldering renders a very strong joint.
dustin is offline   Reply With Quote
Old 07-08-2004, 12:55 AM   #3
Accord94DX
2010 Toyota iQ
Accord94DX's Avatar
Send a message via AIM to Accord94DX
Default Re: Welding with pocket butane torches???? (dustin)
Shit. I was going to weld a 3 ton rated towing hitch to my civic with that.
Thank Jesus for Toyota, Lexus, Scion, Hino, Daihatsu, Toyota Material Handling, and 10% of Fuji Heavy Industries.
Accord94DX is offline   Reply With Quote
Old 07-08-2004, 01:02 AM   #4
Westrock2000
Default Re: Welding with pocket butane torches???? (Accord94DX)
Alright since you all want to be sarcastic asses!
I'm talking light duty here, like something that would have probably 3-4 pounds on it, inside a house. Nothing going on a car, not even car related.
I don't know how to weld with it, thats why I'm asking. I guess you use one of those rods, and melt it on???? I don't know.
2006 Lotus Exige
Old 07-08-2004, 01:04 AM   #5
dustin
What material are you welding?
brass?
steel?
aluminum?
Old 07-08-2004, 01:05 AM   #6
Nid Styles
If you really ned something welded you'd be better off taking it to someone that knows what they are doing, so you don't hurt yourself, or anyone else.
Nid Styles is offline   Reply With Quote
Old 07-08-2004, 01:06 AM   #7
dustin
Regardless, if it's only 4-5 lbs, solder it.
Acid core solder is extremely strong.
In addition to the acid core, you can even use flux for an easier joint.
Silver solder is even stronger.
I silver soldered the ends onto the clutch cable for my go-kart.
Old 07-08-2004, 01:17 AM   #8
Nid Styles
Well Dustin you are just special anyways Click the image to open in full size.
Old 07-08-2004, 01:19 AM   #9
Westrock2000
But solder doesn't really stick well to all surfaces. Your talking electrical solder right? Like for electrical circuits? Or some other kind of solder....they have thick stuff in the plumbing section of Home Depot I have seen before.
The application is plated steel I believe, its one of those 1"x1" square tubes that has 1/4" holes every 1" or so. I need to attach an aluminum 1.25" conduit to it.
The bar looks like the feet in this picture.
2006 Lotus Exige
Old 07-08-2004, 01:21 AM   #10
Nid Styles
You could use some quick arc welding, but it really depends on what it's made out of, and what it's being welded to.
Old 07-08-2004, 05:36 AM   #11
Drew M
Drew M's Avatar
Oxy-Acetylene welding doesn't use any shielding gas and I guarantee you that there are people out there who can gas weld with a torch every bit as nice as what someone can do with a MIG/TIG.
Westrock: It would cost you less money to pay someone to MIG the weld for you than it will cost you to buy that stupid little BRAZING torch.
Also - solder doesn't stick to metal when the metal is not hot enough. Electric irons don't generally have enough wattage to get metal much more than a 16th of an inch thick hot.
Technical Manager - Team MER
E36 M3/4
Drew M is offline   Reply With Quote
Old 07-08-2004, 05:39 AM   #12
Drew M
Drew M's Avatar
Default Re: Welding with pocket butane torches???? (Nid Styles)
You aren't saying he could do some quick ARC welding with that little butane torch are you?
Please tell me you aren't.
E36 M3/4
Old 07-08-2004, 05:53 AM   #13
Deemeetree
Electrician
Deemeetree's Avatar
Send a message via AIM to Deemeetree
Go to Home Depot and get a $15 Propane torch. With that, you can solder and flux. More than you need. The Bernz-O-Matic ones.
Aegean Wiring and Lighting
[email]dspanoudakis@hotmail.com[/email]
E-mail me for all types of electrical work needed in the Tri-State area.
K.G.K. Electrical Contracting
Deemeetree is offline   Reply With Quote
Old 07-08-2004, 07:01 AM   #14
blykins
Banned
Send a message via AIM to blykins
Default Re: (Dimi)
This guy I used to work w/ had a pocket butane lighter he used to smoke his meth with.
blykins is offline   Reply With Quote
Old 07-08-2004, 07:05 AM   #15
david@didrace.com
david@didrace.com's Avatar
Send a message via AIM to david@didrace.com
Click the image to open in full size. You can't arc weld with a torch and you especially can't arc weld steel to aluminum with a torch.
Originally Posted by NYLuder
The roach was real and the vacuum is real. I have hoover vacuum from bby.
- 1996 Honda Civic Ex - B20, SC60 @ 20psi, Tuned on E85
david@didrace.com is offline   Reply With Quote
Old 07-08-2004, 07:06 AM   #16
david@didrace.com
The only way to bond steel to aluminum correctly without getting into some high-end welding technology is to braze/solder.
Old 07-08-2004, 07:14 AM   #17
Drew M
Drew M's Avatar
Default Re: Welding with pocket butane torches???? (10-94-55)
You can't ARC weld anything with a torch EVER. ARC is electric. Torches are gas.
E36 M3/4
Old 07-08-2004, 07:34 AM   #18
david@didrace.com
Default Re: Welding with pocket butane torches???? (Evil Drew M)
My statement is true. Thanks for clearing it up a little bit better for those that don't know though. Click the image to open in full size.
Old 07-08-2004, 12:01 PM   #19
dustin
Oh blah blah. The byproducts of the acetylene catalyzation and the high ratio of acetylene vs. oxygen in the mix form a "shielding gas" that prevents the metal from oxidizing.
How do you plan on working that out with a butane torch? If you actually could get the metal hot enough to melt it (assuming we are talking about steel here), the metal would "burn" rather than melt -- so you could not weld.
Of course, this is a moot point, considering mild steel melts above 2700 degrees fahrenheit.
Old 07-08-2004, 12:03 PM   #20
dustin
I am talking about acid core solder. Rosin core solder (used for electronics) has no strength and will not bond to much of anything.
You can't weld steel to aluminum anyways. You will have to braze/solder it.
Old 07-08-2004, 12:04 PM   #21
dustin
Tig is electric, and it has a torch.
Old 07-08-2004, 12:35 PM   #22
HatchBox
Skoobie no more...
HatchBox's Avatar
Send a message via AIM to HatchBox
check this out, u can weld with this stuff with a regular propane torch.
http://www.alumaloy.net/
anyone have experience with this?
HatchBox is offline   Reply With Quote
Old 07-08-2004, 12:45 PM   #23
Happyman
Happyman's Avatar
pwnt!
'97 SOHC Turbo Del Sol - Sold | '93 SR20 240sx - Sold | '04 G35 - Sold | '99 Red CX Hatch - New DD
Happyman is offline   Reply With Quote
Old 07-08-2004, 01:22 PM   #24
Frozen E
H-T White Ops
2008 Honda Element
Frozen E's Avatar
....And to braze anything you need a hell of a lot more heat than you're going to get out of your little butane torch thing there. We use oxy/acetylene rigs to braze copper lines to the steel outlet fittings on compressors when we do installs. I'm talking anything from small 3/8" lines to big 3" bastards. We use brass to braze and I'm just telling you that a butane torch like the one pictured is NOT going to be melting any brass rods any time soon.
Anyway, to the OP, go to a shop and have them work some magic for you. Trying to do it yourself when you have no idea what you're doing is just going to screw things up with you having to go to a shop anyway. So just skip the middleman (yourself). Click the image to open in full size.
Frozen E is offline   Reply With Quote
Old 07-08-2004, 01:28 PM   #25
PlastikOwl
Guest
Posts: n/a
Default Re: Welding with pocket butane torches???? (IslandSi)
you could make Creme Brulee with that torch. And then you can come on HT and tell us all how "fabulous" it was and how an accident with it gave you a permanent lisp.
butane, contact, depot, good, hawaii, home, metal, pocket, projects, small, torch, torches, weld, welding, whats
