how to install amp and sub to honda accord 2000 se
Old 07-04-2004, 04:21 PM
khoi1972's Avatar
Default how to install amp and sub to honda accord 2000 se
how to install the clarion apa 2001 amp to honda accord 2000 SE origional deck
Old 07-04-2004, 04:25 PM
Sohc Driver's Avatar
Default Re: how to install amp and sub to honda accord 2000 se (khoi1972)
hey....is your name Khoi???? LOL , I rarely ever find anybody else with my same name..LOL..sorry for the off topic post..
Khoi
Old 07-04-2004, 04:26 PM
jlv55's Avatar
i dont know if it is possible to install an amp on a stock honda head unit. you need RCA outputs.
Old 07-04-2004, 07:23 PM
Hit the floor!
bodiez's Avatar
Yep you will need an aftermarket HeadUnit. The Honda stock isnt that powerful anyway to even it if did have correct RCA outputs it wouldnt sound as good as a $100 aftermarket headunit. May I recommend this particiular player: JVC KDF401
http://www.dealtime.co.uk/xPC-..._Unit
$100 US for mp3 playback. Awesome deck (i own one )
Old 07-04-2004, 07:24 PM
fw190bvi's Avatar
Default Re: how to install amp and sub to honda accord 2000 se (bodiez)
stock sound systems > everything
Old 07-05-2004, 05:51 AM
fcm
Old Fart
fcm's Avatar
You will need a line level adpt., it will step down the speaker output to a RCA level, or get an amp that has speaker level inputs, there a lot of them.
hope this helps. 94
Old 07-05-2004, 09:05 AM
cd5_2NR's Avatar
Default Re: how to install amp and sub to honda accord 2000 se (fcm)
yup...he's right..you can usually get these at radioshack...
Old 07-05-2004, 11:31 AM
EnjoyTheRideDC2's Avatar
To start off, you need a Hi-lo converter. This uses speaker connections to provide you with a pair of RCA connections. You can ****** one at your local Best Buy car audio department. The cost is 22.99.You can remove the factory stereo and use the speaker leads off of the main harness.
Then, Run your RCA cables along with your remote wire. the remote wire should be provided with the wire kit you puchase. If not, you need a wire that is about 18-16 GA thick, and can run from the radio of your vehicle to the amp (where ever u place it.) Connect that to either the ignition wire or power antennna connection of the car.
The rest is simple. Run the power wire with the fuse into the car, of course making sure the side with the fuse is closest to the battery. You should find a spot to run it on the passenger side floorboard or through the wiring harness that runs from your engine and into the car.
Ground the "Ground" wire to a bare metal surface closest to the amp. You choose your spot
mount amp.....
Reprise
Audio / Security / Video
06-29-2013 07:52 AM
Speed_69
11
08-25-2010 11:11 PM
nicayotte
Honda Civic (2006 - 2015)
12
09-18-2008 06:35 AM
ttvegas2002
08-28-2005 05:57 AM
Dark_Knight
03-07-2004 09:45 PM
Quick Reply: how to install amp and sub to honda accord 2000 se
