New starter grinding On the Flywheel
Old 07-01-2004, 12:42 AM
g2homboi's Avatar
Default New starter grinding On the Flywheel
Okay I've just helped my friend install a new starter in his 93 Prelude, we thought it was the starter but ended up being the battery, so we kept the starter. The problem is now the starter grinds when we start the car. It does it for at least 2 seconds then stops. My question is should we replace the starter, with the starter it originally had, or is it safe to let it grind everytime the motor starts, and you can give me any other advice to fix the problem. By the way I do not know what flywheel he has installed, since he just bought the car. Any help would be appreciated.
Old 07-01-2004, 12:58 AM
@ries's Avatar
Default Re: New starter grinding On the Flywheel (g2homboi)
The ring gear on the flywheel might have moved. Try inspecting it through the hole between the tranny and the block... it's a small rectangular plug.
Modified by @ries at 3:24 AM 7/1/2004
Old 07-01-2004, 01:04 AM
g2homboi's Avatar
if it's moved, is it possible to fix it without tearing out the tranny?
Old 07-01-2004, 11:45 AM
g2homboi's Avatar
bump..
Old 07-01-2004, 12:10 PM
Banned
kb58's Avatar
Default Re: (g2homboi)
A couple things:
Take the starter out and very carefully compare the teeth to the old starter.
Unless you're positive you bought the right starter, take it to another store and compare it to another starter for the same car.
And like you said, the flywheel is suspect... but since the old starter worked you know at least those teeth match.... so compare the old and new starter before ripping the engine apart.
Old 07-02-2004, 02:19 AM
g2homboi's Avatar
i actually examined it before installing. I notice they were different before I installed the new starter. The new one sticks out a little bit more than the old. Thanks for the advice everyone.
Old 07-02-2004, 11:27 AM
LudeyKrus's Avatar
Replace the starter w/ the original one, take the new one back to the store for a refund, and don't mess with it anymore.
G60
10-13-2020 12:58 PM
dmanfree
06-21-2013 12:38 PM
Whiteranger
05-27-2013 06:39 AM
GoneImport
02-18-2008 06:45 AM
h22a_black
02-13-2008 06:12 AM
Quick Reply: New starter grinding On the Flywheel
