1991 Accord Cooling Fan Don't Work!!!
Old 06-28-2004, 01:50 PM
hYpE-R-29's Avatar
Default 1991 Accord Cooling Fan Don't Work!!!
I have a 1991 Honda Accord and the coolng fan doesnt run...It runs when I connect it directly to the battery, so I know the motor is fine...I thought it may be the brown sensor near the thermostat so I changed it, and still no work.. I've checked the fuses and its fine... The cooling fan does work if the A/C button is turned on, but then it shuts off after 30 seconds...ANy Ideas..
Thanks
Old 06-28-2004, 01:55 PM
wijiwang's Avatar
check your 'fan switch' its like a sensor.. should be in a housing connected to your intake radiator hose.. it has a plastic tip sticking out with 2 plugs.. try replacing it.
Old 06-28-2004, 06:37 PM
hYpE-R-29's Avatar
Default Re: (wijiwang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wijiwang &raquo;</TD></TR><TR><TD CLASS="quote">check your 'fan switch' its like a sensor.. should be in a housing connected to your intake radiator hose.. it has a plastic tip sticking out with 2 plugs.. try replacing it.</TD></TR></TABLE>
well that didnt work...i think i pulled the A/C one...any1 have any diagrams?...whatelse could be the problem
Old 06-28-2004, 07:15 PM
hondadude's Avatar
Default Re: 1991 Accord Cooling Fan Don't Work!!! (hYpE-R-29)
http://members.troublecodes.ne...h.jpg
Here's the schematic of the fans, you might want to enlarge it.
I might also say you should be sure the coolant is full and the block burped via the 12mm bleed screw at the T-stat housing.
This problem can also be caused by the fan timer unit located against the interior firewall drivers side, left of the steering column. So here's 2 more links to test that.
http://members.troublecodes.ne...2.gif
http://members.troublecodes.ne...1.jpg
Old 07-01-2013, 06:29 AM
junior91hondaac's Avatar
How did you fixed you fan problem
Old 07-01-2013, 06:32 AM
Hi,can you please tell me how did you fix your fan problem
Old 07-01-2013, 06:50 AM
NZXTInerTia's Avatar
He probably fixed them by not bumping a nine year old thread.
motorbreath777
09-18-2016 08:39 AM
ApatheticAccord
10-19-2015 04:17 PM
Homerbsharp
08-28-2011 04:43 AM
clair
08-12-2009 09:24 AM
chechea
08-08-2007 08:56 PM
Quick Reply: 1991 Accord Cooling Fan Don't Work!!!
