CEL??? Manufacturer Control Ignition System or Misfire
Old 06-28-2004, 09:06 AM
Excelerate's Avatar
Default CEL??? Manufacturer Control Ignition System or Misfire
My buddy has a '98 Civic EX. He had a CEL. I used my scanner and we got Manufacturer Control Ignition System or Misfire. Any ideas? Does it just need a tune up, i.e. dist cap, rotor, wires, plugs? And if so, what gap on the plugs?
Old 06-28-2004, 09:32 AM
Filthy Focker!'s Avatar
Default Re: CEL??? Manufacturer Control Ignition System or Misfire (Excelerate)
It could be. Need a bit more info than that though.
Any symptoms associated with this?
Done any mods lately?
When did this happen?
Have you cleared the ecm memory and took it out for a test ride to see if it came back?
How about engine temperature. Is it higher than normal?
How is the idle?
Which cylinder is it misfiring from?
As for spark plug gap, should be written inside the engine bay, near the radiator.
fs
Old 06-28-2004, 09:42 AM
Excelerate's Avatar
Default Re: CEL??? Manufacturer Control Ignition System or Misfire (filthy_shovel)
i dont think he has done any mods recently... it just happened he said... i cleared the code and it came back on as he drove down the road.. well he said the CEL came back on after he left... so it probably is the same one.. ill ask him the rest.. it seesm to idle fine.. and it didnt say what cylinder misfired b/c it said "Manufacturer Control Ignition System OR Misfire"
Old 06-28-2004, 09:56 AM
missing something here. Since it is a 1998, it should be equipped with ODBII diagnostics. What p code was set?
fs
Old 06-28-2004, 10:32 AM
Excelerate's Avatar
im gonna have to check it again... i erased it for him... i just read what it was.. i didnt write down the p number
Old 07-01-2004, 11:48 AM
djickabod's Avatar
Im having the same problems. here are the codes Im throwing
p0500
p1337
p0441
p0170
My set up is
00 b20z2
00 b16a2 head and tranny
00 ITR cams
OBD2 P72
97 hatch
Help!!!!!!
Old 07-02-2004, 05:20 AM
djickabod's Avatar
Bump for problems!
Old 07-25-2005, 01:05 PM
mudshuvelz's Avatar
Default Re: (djickabod)
same problem...i need help asap for ny inspection!
Old 08-03-2005, 08:20 PM
mudshuvelz's Avatar
bump
Old 08-03-2005, 08:31 PM
kkim's Avatar
Default Re: CEL??? Manufacturer Control Ignition System or Misfire (mudshuvelz)
http://www.iequus.com/obd_def.asp
Old 08-03-2005, 08:35 PM
HXvtec's Avatar
Default Re: CEL??? Manufacturer Control Ignition System or Misfire (kkim)
my car did the same ****. i fixed it for a little bit by lowering the fuel pressure but then it came back. i have no idea. i have new plugs, rotor, cap wires and it still does it.
Crazed_GSR
07-13-2013 04:43 AM
92milanoredhatch
01-10-2011 06:04 AM
mynameizstitch
07-25-2007 06:08 PM
Quick Reply: CEL??? Manufacturer Control Ignition System or Misfire
