Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 06-26-2004, 10:40 AM   #1
Behan
Behan's Avatar
Default How to: Clutch replacement
THis is not a complete write up you will need a manual to do this job
I changed my clutch recently and had decided to do a write up for those who don't have a helms or a fsm. After completing the job, i wouldn't recommend that anyone (without experience) tackle this job without the manual. The diagrams in the manual were a huge help, especially when trying to locate some of the bolts. I also had a friend there to help( iluvdrt), which if you are doing this with the engine in the car i would say it is required. This write up is more so you know what is involved and what you are getting yourself into. So here goes......
I would recommend you purchase something similar too a craftsmen 256 pc. mechanics tool set to complete this job but I'll do my best too write out all the tools i used.
I'll write in the size of the bolts and any other tools i can remember on each step.
1. Disconnect the battery cables and battery tie down, then remove the battery and tray. i used a 10 mm open/closed wrench for this step
2. Now you need to remove the battery base and base stay. There are 6 12 mm bolts and 2 10 mm bolts. I also used a 12 in extension when removing the base bolts.
3. Now remove the strut bar ( if you have one) and intake, if you have an after market CAI you will need to loosen the splash guard to remove the filter. I used a phillips head screwdriver to remove the clamps used with my aem CAI.
4. If you have an after market intake you may be able to skip this step. Remove the intake control vacuum tank and bracket. there are a total of 4 10 mm bolts between the bracket and tank itself. I didn't know this could be removed when i installed my CAI so thats why it was still there. If you are removing it for good you will need to plug the corresponding vacuum line on the im.
5. Now you need to remove the wiring harness and connectors from the tranny and starter. For this step i used a 10mm, 12mm, and 14mm sockets and or wrench.
5A. wiring harness clamp
5B. tranny ground an starter motor cable stay
5C. starter cables
5D. Back up light switch connectors
5E. Starter removal
6. Now you need to shift the tranny into reverse and then remove the cable brackets and cables from the tranny. I used a 12mm deep well socket and needle nose pliers to remove the cotter pins.
6A. cable brackets
6B. cable removal
7. Now you need to remove the vss from the tranny , do not remove the hoses. i used a 10 MM socket for this. there is also an elec plug on top of the vss.
8.Now you need to remove the slave cylinder and lines, which requires a 12mm and 10mmm socket. There are 2 bolts that bolt the slave cylinder to the tranny and 2 to hold the lines in place.
9. jack the front of the car and support it with jack stands
10. remove the drain plug and drain the tranny fluid. this step requires a 3/8 in ratchet.
11.now remove the rear engine mount bracket stay from the tranny, this step requires a 14 mm socket
12. now you need to release the suspension. Remove the lower ball joint cotter pin and nut ( 19 mm) on both sides . Air tools help. Click the image to open in full size.
12A. remove the damper fork bolt ( both sides) this step requires a 17 mm wrench and/or 17mmm socket or another 17mmm wrench
12B. Remove the passenger side radius rod from the lca ( 17mm) and the cross member ( 17mm deep well socket)
13. now you need to remove both axles from the tranny and remove the intermediate shaft. IIRC the intermediate shaft bolts were 17 mm. Pry the cv axle inner casings from the tranny and intermediate shaft.
14. now remove the center beam, these bolts were 14mm
15. remove the front engine stiffener and clutch cover. the front engine stiffener uses 14 mm bolts and the clucth cover uses 10mm
16. remove the rear beam stiffener IIRC they used 17mm bolts. You may also need to remove the intake manifold bracket stay to access one of the rear beam bolts but i got around it.
17. remove the rear engine mount bracket bolts
18. place a floor jack under the tranny and support its weight. take care not to damage the housing, i used a block of wood.
19. now you need to remove the tranny mount and bracket. the through bolt is a 17mm and all others were 14 mm ( IIRC). it is neccesary to separate the mount from the bracket.
20. remove the 2 upper tranny mounting bolts.
21. remove the 3 lower mounting bolts.
22. now pull the tranny away from the engine until it clears the main shaft. Once you've cleared the main shaft remove it from the car. This was a pain in the *** and requires some finagling (sp?)
23. now i cleaned the tranny housing and the inside of clutch housing. i used simple green and a pressure washer. be sure to remove all the dirt/grime and clutch fibers from the inside of the clucth housing. take care not to let water in the tranny. i plug the diff holes/etc. with rags. you can now also remove the old release bearing.
24. now you can remove the pressure plate and clutch. i believe the pressure plate bolts were 12mm.
25.now you need to remove the flywheel for resurfacing, remove the bolts in several steps in a crisscross pattern. i also recommend having a rear main seal on hand to replace if yours is leaking.
26. take your flywheel to a machine shop for resurfacing.
NOTE: Reassembly is the most critical part and the main reason i suggest having the manual on hand. As i won't be able to detail the process as well as the manual could. A helms or a FSM can be purchased for around 60.00 dollars. You can also try ebay for the FSM on cd-rom, prices are roughly 5.00 dollars.
27. now you are ready for reassembly, use the steps outlined in your manual for the flywheel, release bearing and clutch/pressure plate reassembly. you will need a few special tools to complete this step.
28. once everything is reassembled you can reverse the steps and put your car back together. Click the image to open in full size.
Once again I DO NOT RECOMMEND you tackle this job without a helms or FSM. Which is why i didn't even try to type out the installation process of the flywheel, clutch, etc. We did this in Iluvdrt's driveway ( see pic below) and it wasn't much fun. i would say it was well worth the 400.00 dollars a local shop wanted to charge me. But the knowledge i gained of my car was priceless. It would be considerably easier to tackle this job in a shop with lift. Thanks to Iluvdrt ( ozzy) , i definitely couldn't have done this job without his help.
Disclaimer: the author claims no responsibility for any damage incurred by the use of this write-up. Go buy a damn manual.
Modified by Behan at 11:24 AM 6/28/2004
Modified by Behan at 11:33 AM 6/28/2004
-Steve
<FONT COLOR="red"> My 93 lude </FONT> Sold http://images.honda-tech.com/set1/smile/emsad.gif
Proud Owner of 06 Mitsubishi EVO http://images.honda-tech.com/set1/smile/emthup.gif
Vouches: <FONT COLOR="blue"> Kteller8, Andy D, vehic illu
</FONT>
Behan is offline   Reply With Quote
Old 06-26-2004, 10:55 AM   #2
MugenPoweredLude
damn
awesome write-up Click the image to open in full size.
2005 Evo 8-Vishnu'd 350whp-SOLD! [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
2000 Honda Prelude SH-SOLD!
[url="http://www.hondashowoff.com/profile.php?id=3921"]Visit My Honda Showoff Page![/url]
[url="http://www.onlineshowoff.com/index.asp?section=profile&username=MugenPowerdLude"]Visit My Online Showoff Page[/url]
Good Sellers: Sticky Tires [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
Really Good Sellers and [B]EXCELLENT CUSTOMER SERVICE[/B]: DRFlickner [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
MugenPoweredLude is offline   Reply With Quote
Old 06-26-2004, 10:55 AM   #3
stubk20
stubk20's Avatar
Default Re: How to: Clutch replacement (Behan)
another good write up Click the image to open in full size. ill make sure to save this one
06 rsx type S
00 Infinity G20T
93 prelude vtec (sold)
94 prelude s w/h22a4 (sold)
00 integra gsr
stubk20 is offline   Reply With Quote
Old 06-26-2004, 11:02 AM   #4
Speedra500
Speedra500's Avatar
Send a message via AIM to Speedra500
Default Re: How to: Clutch replacement (stubh22a4)
nice write up, and also you should think about cleaning under the hood every once in a while Click the image to open in full size.
Speedra500 is offline   Reply With Quote
Old 06-26-2004, 11:02 AM   #5
Saki
Saki's Avatar
Default Re: How to: Clutch replacement (Speedra500)
Another Nice Write Up Click the image to open in full size. Click the image to open in full size.
WTB: 4th Gen Prelude Trunk Lid / 4th Gen Prelude Pass. Fender
Saki is offline   Reply With Quote
Old 06-26-2004, 03:03 PM   #6
Behan
Behan's Avatar
really? Click the image to open in full size.
I live on a dirt road so anytime it rains the engine compartment gets covered in that crap. i don't have the stock splashguard , the first time i needed to flush the coolant i found it torn and tied on with a string.
Besides, its not a show car. Click the image to open in full size.
-Steve
</FONT>
Old 06-26-2004, 03:13 PM   #7
PetroGuyX
PetroGuyX's Avatar
Send a message via AIM to PetroGuyX
real nice write up... what would you do if it randomly started raining? lol
95 Champagne SE on OEM 15's and lovin' it
FS: Set of 18's
OEM Wing
JDM climate control w/ all sensors
OEM Headlights and Corners
PM for details and pictures
PetroGuyX is offline   Reply With Quote
Old 06-26-2004, 03:18 PM   #8
Behan
Behan's Avatar
Default Re: (PetroGuyX)
thats funny you mentioned that, we stopped after getting the tranny bolted back on because it was getting dark. About 20 mins after we got everything cleaned up it started to pour.
just check the weather before you change it in the driveway. Click the image to open in full size.
-Steve
</FONT>
Old 06-26-2004, 03:22 PM   #9
pentaq
pentaq's Avatar
great stuff Click the image to open in full size.
it looks like some dirt on your face makes you happy Click the image to open in full size. Click the image to open in full size.
Prelude 94 VTEC- parted out.
Accord Wagon 94 H22 VTEC Turbo.
pentaq is offline   Reply With Quote
Old 06-26-2004, 03:35 PM   #10
prelude1897
prelude1897's Avatar
Send a message via AIM to prelude1897
Pretty good write-up Click the image to open in full size.
97 Prelude-wrecked
00 Prelude-Daily Driver
99 Prelude-RHD Prelude http://images.honda-tech.com/set1/smile/emwink.gif
98 Prelude-Parts Car-SOLD
<FONT COLOR="blue">Retrofit service/pics</FONT>
http://www.myspace.com/bceretrofits
prelude1897 is offline   Reply With Quote
Old 06-26-2004, 03:59 PM   #11
Hawkze_2.3
Hawkze_2.3's Avatar
Default Re: (prelude1897)
Very nice and very helpful Click the image to open in full size.
'95 Prelude--intake, windshield washer lights, rear body kit, carbon fiber windows. '86 Mazda RX7--Chevy & Borg-Warner powered. '99 Honda CRV--Jurassic Park tour vehicle. '98 Chevy Lumina--what is that thing?
Hawkze_2.3 is offline   Reply With Quote
Old 06-26-2004, 04:39 PM   #12
naujcdl
naujcdl's Avatar
Send a message via AIM to naujcdl
nice writeup, but i think i am ok with automatic Click the image to open in full size.
1999 Ford Contour SVT
For Sale http://images.honda-tech.com/set1/smile/emsmile.gif
naujcdl is offline   Reply With Quote
Old 06-26-2004, 05:05 PM   #13
SKDRCR
SKDRCR's Avatar
Default Re: How to: Clutch replacement (naujcdl)
Awesome write up Steve, you gotta little somethin on ya
grease ownz j00 Click the image to open in full size.
Chris
92 lude h22a
Karma police own j00
FOR SALE THREAD http://www.honda-tech.com/zerothread?id=981072
Good buyers: *barroom hero**five-0**PrecisionH23a**LudeyKrus*
Good sellers: *CHK4TIX**lightning**waterboy683*
<FONT COLOR="red">Need used import car parts cheap? Tell me what you're looking for http://images.honda-tech.com/set1/smile/emthup.gif </FONT>
SKDRCR is offline   Reply With Quote
Old 06-26-2004, 05:17 PM   #14
AndyD
AndyD's Avatar
Default Re: How to: Clutch replacement (SKDRCR)
That's not Steve in that pic.
'92 Accord Sedan w/H22A. '92 Prelude Si 4WS engineless. '89 240SX w/SR20DET.
Vouch thread
CB7 F22A1 H22 5spd swap parts FS
AndyD is offline   Reply With Quote
Old 06-26-2004, 05:25 PM   #15
Shakes
space cadet
Shakes's Avatar
awesome write-up steve!
one thing i would like to mention because i have done this before. and this was my downfall. LABEL ALL YOUR FUCKING BOLTS WHEN YOU TAKE THEM OUT!!!!!!
i did mine (00 SH) 98% by myself. took me 2.5 days with a lift. it was the largest task i had ever occured with a car.
my bestfriend helped me twist the tranny out, and then put it back in. probably could have gotten it done a lot faster with him there. HAVE A FRIEND HELP!
-Doug
SMOKE FREE SINCE 10-31-04
01 Subaru Impreza RSTi
Shakes is offline   Reply With Quote
Old 06-26-2004, 06:37 PM   #16
Qfactor
Qfactor's Avatar
good pics. and write up. and while you're in there replace the rear main seal and axle oil seals Click the image to open in full size. Click the image to open in full size.
Qfactor is offline   Reply With Quote
Old 06-27-2004, 05:15 AM   #17
Behan
Behan's Avatar
Default Re: How to: Clutch replacement (Shakes)
thats ozzy, (iluvdrt)
Great point Doug, thats an especially good idea if you not going to be completeing it in one day. We spent alot of time trying different bolts to find the right ones.
-Steve
</FONT>
Old 06-29-2004, 05:37 AM   #18
iluvdrt
iluvdrt's Avatar
simple.
put everything into your buddies station wagon, close the hood, and drink rum and coke all night. Click the image to open in full size.
Originally Posted by pentaq
great stuff
hence the screen name. Click the image to open in full size.
BTW, nice job on the write-up steve, i think you know it still needs one more pic. Click the image to open in full size.
-Jason
Kills Forum OG
Subaru Guru
iluvdrt is offline   Reply With Quote
Old 06-29-2004, 12:07 PM   #19
Daboi630
Daboi630's Avatar
Send a message via AIM to Daboi630
Click the image to open in full size. i need to do my clutch soon.....
[url="http://www.honda-tech.com/garage?cmd=viewcar&id=1038"]95 Prelude SE JDM H22[/url] - Sold [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
03 Acura TL Type S [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img]
[url="http://www.honda-tech.com/zerothread?id=838378"]My Vouch Thread[/url]
[b]*** Type S Cams and 96 Spec Type <FONT COLOR="red">R</FONT> Rims for sale!*** [/b]
Daboi630 is offline   Reply With Quote
Old 06-29-2004, 12:07 PM   #20
Daboi630
Daboi630's Avatar
Default Re: (iluvdrt)
a before pic? Click the image to open in full size.
Old 06-29-2004, 12:54 PM   #21
Behan
Behan's Avatar
Default Re: (Daboi630)
lol, nope, not a before pic. i'll post it later.
-Steve
</FONT>
Old 06-29-2004, 02:58 PM   #22
spnbb2
Guest
Posts: n/a
saved both of em Click the image to open in full size.
your the man behan
Old 06-30-2004, 10:21 AM   #23
flyrod
flyrod's Avatar
Send a message via AIM to flyrod
Default Re: How to: Clutch replacement (Ludinitup)
Thanks for the good writeup and pics! It looks like you may have a slow oil leak under there somewhere, going by the oil/dirt accumulation. I have pulled several prelude trannies, and I do things a little differently:
- leave the power cable attached to the starter, and just set the starter where the battery was
- only separate right (passenger) knuckle
- leave that axle in the knuckle, but pull the inner joint from the tranny
- take out the three bolts on the intermediate shaft, but leave the joint attached (there is enough room to take it out of the tranny when the tranny is loosened from the block)
These steps basically save a little time. I agree, the "finagling" part can be a pain; I've found that if you keep the differential side pushed up until the last minute it will go much smoother. That end is heavy, and the tranny wants to rotate on the mainshaft once you get it back from the block a bit. This tends to drop the differential, and the finagling begins. Try to move it straight away from the block, and drop the front part first. Usually goes fairly smooth that way.
Also, when filling the tranny with oil again, a gear oil bottle with the pointy cone shaped cap works really well. Actually, all you really need is the cone shaped cap, because it will usually screw onto any regular plastic oil bottle. Anyway, the tranny takes 2qt, so just pour the oil into the gear oil bottle and fill the tranny through the vent hole on the top. Put your finger on the tip of the bottle, invert it and put it into the vent. Squeeze, then release and the bottle will suck air back out of the tranny and make room for more oil. So, just squeeze, relax a few times, then repeat for the 2nd quart. Much easier than trying to fill the tranny from the bottom, and no mess. hth...
Stuff for sale: K20A longblock Hondata Stage 4B Chipped P28's
Lots of 4th Gen Prelude stuff: STR fuel rail NIB, Si Brakes, ABS
H22 cams, etc.
flyrod is offline   Reply With Quote
Old 06-30-2004, 04:03 PM   #24
SlowTeg
Send a message via AIM to SlowTeg
Default Re: How to: Clutch replacement (flyrod)
Another useful tip so you don't waste money.. If your old clutch disc wasn't demolished before you changed your clutch then there's no need to get the flywheel resurfaced. It's pretty simple, just feel the friction surface and if it's not nice and smooth get it resurfaced.
Also, the pressure plate bolts are 12 point 10mm bolts. Make sure you have a helms manual for torqueing the important bolts down like the flywheel and pp bolts.
-Mike
SlowTeg is offline   Reply With Quote
Old 06-30-2004, 05:22 PM   #25
Behan
Behan's Avatar
Default Re: How to: Clutch replacement (SlowTeg)
thanks for the helpful tips flyrod and slowteg, keep them coming. Click the image to open in full size.
-Steve
</FONT>
1990, accord, acura, change, clutch, contour, fork, h22, honda, pictures, prelude, process, replace, replacement, replacing, svt, tsx
