#1 | |||||
My garage |
#2 |
good job and yes lots of work. all worth it now. you can smog anywhere and not have to pay anyone extra.
#3 |
Yup thats true. I hope this is helpful to whom ever is trying to bar their jdm motor, this is my contribution to h-t.com
My garage |
#4 |
Hey I talked to you earlier today about your engine good to hear you didn't have to ditch it, to legalize it.
91 Civic Ex stock (automatic) 91 Civic Rt4wd .... (fixing) 90 Crx HF stock Vouches |
#5 |
another great write up
congrats for finally getting it BAR certified
Formula 1 Legend: Ayrton Senna da Silva (Mar 21, 1960- May 1, 1994) My girls: 92 DA9, 05 GTO 6M |
#6 |
Thanks everyone. I just hope this helps someone on the board, it would've helped me alot while I was trying to figure out what I needed to swap over. I think the hardest part was the oil pump because you have to remove the crank gear and pulley along with the oil pan.
My garage |
#7 |
i need some info on this too, i currenty have type r too. where did you take your car to pass those thingly. also what i did was run evap hose to jdm itb hose u mention & it runs fine.
#8 |
The main reason I bent that little dick off the throttle body is because I was afraid they'd know it didn't resemble the stock usdm itr one. Supposedly they have pictures of everything but I didn't see them pull out any photo albums. The state ref doesn't care if the jdm setup doesn't pollute more than the usdm model they just want it to be in exactly the same setup as the usdm version.
Modified by 2kgs-R at 12:13 PM 6/26/2004
My garage |
#9 |
this is definately gonna help me! good work!
Buy my REAL DEAL EK9! http://hondamarketplace.com/showthread.php?t=2665075 Vouch Thread http://www.honda-tech.com/zerothread?id=983948 |
#10 |
with all the USDM upgrade to pass the bar test do you lose HP?
- 00 Honda Civic HB (Flamenco Black) - 05 Honda S2000 (Silverstone Metallic) |
#11 |
yes because the stock cat. sucks nutz!
Other than running stock header+cat. there wont be any decrease in power. Infact the intake manifold I have now has been slightly ported to fit a larger throttle body, and the runners have been ported slight too. I felt a significant difference after installing this usdm intake manifold because of the porting done. However when running a usdm ecu I get a check enigne light (code 45 too lean or too rich).
My garage |
#12 |
Great post , it helps me , now have confirmation that JDM's don't have vtec press. switch..... I can't find one used here , did you have to buy yours new? Thanks again! Bob
#13 |
My friend had a b18c laying around in his garage and I asked him if I could borrow the vtec solenoid with oil pressure switch.
My garage |
#14 |
i know this might sound lame/stupid but is it worth wild to swap these usdm parts on just for the bar test? and then re-install it back with the JDM parts later? im located in the mid-west so we dont have the bar sticker nor even inspection sticker
#15 |
If you don't have to, don't do it. Also there would be no benifit for me to return the parts I installed back to jdm. The parts don't really effect performance their just slightly different and have sensors etc..
My garage |
#16 |
1999 Honda CivicMy Garage |
now that ur bar'd. do u have to keep that stuff on there to pass inspection every year? or will they just look at that sticker and say, oh he's good to go.?..????
#17 |
when I go for smog I'll probably have to run stock cat. and stock header, or a header with carb numbers but for the most part I think I can run whatever intake and whatever exhaust I want.
My garage |
#18 |
hey, i have a 91 crx hf with b16a2 motor.....what do i have to do in order to pass the state referee .... wat kind of stuff do i have to buy for my car.??? is it the same item i need tat is listed above!!!
Modified by Dyn0speed at 6:09 AM 6/28/2004
boosted Teg |
#19 |
I honestly don't know, what year is the motor? you'll probably have to add everything that the usa version has.
My garage |
#20 |
I was wondering how did you manage to get all the USDM ITR parts, aren't they hard to get?
How much did all parts add up to? I am considering to BAR my 96 ITR Motor. By the way, your write up is one of the best I have ever seen, great job man...
#21 |
uh yeah it was a bitch trying to source all the parts, the hardest part to find was a stock cat.
I made a spread sheet of how much everything costs and it added up to about $700 but that was including a new throttle body. Alot of the little things like timing belt cover and purge solenoid I got for free from a good friend. Thanks
My garage |
#22 |
Thanks for sharing this valuable how-to info
#23 |
np
My garage |
#24 |
What year is your car? I am wondering because why did they give you a year 2000 sticker for your 96 motor. Unless your car was year 2000, but that does not make even more sense since don't you need a the same year or older motor?
Please enlightment me.. I am looking to smog my car in OCT. I have a 96 HB with 96 LS motor.
Inspct: Bar'ed 2/18/05 Swap: EK9-B18B 5.10.04 Dyno'ed : 122.48 HP 113.3 TQ Stock Winston @ Tech3 Performance, San Jose Vouch 4 ME: Vouche for me if we have been invovled in a transaction. Thanks. http://www.honda-tech.com/zerothread?id=853002 Voucher http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif : Aber: maxpsi backdraft:B_Cruz: H23vtecEG: Cnote: prjctCIVIC b18c1_powered_si & Djmarvelous hellogoodbye |
#25 |
yeah your correct but I think someone already mentioned this.
The reason why I passed with a 96 motor is because they couldn't tell what year the motor really was, I even over heard someone mention that it was a 2001 at the state ref.
My garage |
| Bookmarks |
| Tags |
| 92, b16a2, bar, difference, honda, intake, integra, jdm, legal, legalize, legallizing, legally, manifold, motor, swap, tech, type, usdm, year |
