> Honda CRX / EF Civic
Old 06-19-2004, 02:56 PM   #1
limpy
limpy's Avatar
Default b16 2nd o2 sensor
i want to hook up the 2nd o2 sensor in my crx with a b16 but don't know where the hell to run the wire. so where does it go?
"if it doesn't fit, force it. if it breaks then it needed to be replaced anyway."
limpy is offline Report Post   Reply With Quote
Old 06-19-2004, 03:06 PM   #2
garlic jr
garlic jr's Avatar
Send a message via AIM to garlic jr
Default Re: b16 2nd o2 sensor (limpy)
on hhu.com their was a link to this question... integra forum...
i think it was that if u had an obd1 system with obd2 motor u could run the 2nd o2 onto a piggy back tricking the ecu into thinking u have a working 2nd o2 sensor...
why the hell did u buy a obd2 motor? in a crx no less.. dont wanna know what that was like getting it to work
1994 Honda Civic, b16a 1st gen swap...stock. 10 flat in the 1/8 with NO traction all the way to 3rd gear !!!
garlic jr is offline Report Post   Reply With Quote
Old 06-19-2004, 03:12 PM   #3
Rywire
Rywire's Avatar
Its c8 if you are running obd0.
PS, if it bogs, and hesitates then switch them around. Ryan
He never said it was obd2
Droppedcrxsi.com for B16 / B18 / K20 Swap Info
rywire.com
skunk2.com
karcepts.com
Rywire is offline Report Post   Reply With Quote
Old 06-19-2004, 03:36 PM   #4
limpy
limpy's Avatar
Default Re: b16 2nd o2 sensor (droppedcrxsi)
c8 allready has a wire in it. do i tap into that wire or can i plug it into a pin some where else. it is obd0 by the way.
Old 06-19-2004, 04:26 PM   #5
Rywire
Rywire's Avatar
This only works if you have the the wires comming out at you with the clip side up.
rywire.com
skunk2.com
karcepts.com
Old 06-19-2004, 05:33 PM   #6
limpy
limpy's Avatar
so it is the only one on the smallest clip that has no wire in it? what do i how do i put it in the clip?
Old 06-21-2004, 11:26 PM   #7
Tman
Tman's Avatar
Send a message via AIM to Tman
I need to know this also...
91 CRX HF w/ b16
Vouches: Renoracing
Tman is offline Report Post   Reply With Quote
Old 06-21-2004, 11:40 PM   #8
Rywire
Rywire's Avatar
Default Re: b16 2nd o2 sensor (Tman)
I allready told you.
rywire.com
skunk2.com
karcepts.com
Old 06-22-2004, 08:05 AM   #9
crx_88_si
crx_88_si's Avatar
this also might help in o2 placement..
Vouche: Jay-C
My Car: http://www.cardomain.com/id/crx88si
crx_88_si is offline Report Post   Reply With Quote
Old 06-22-2004, 09:12 AM   #10
88DXCRX
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Send a message via AIM to 88DXCRX
You need to add a wire at C8 and wire the o2 sensors as shown:
living that automotive dream
88DXCRX is offline Report Post   Reply With Quote
Old 06-22-2004, 09:37 AM   #11
crx_88_si
crx_88_si's Avatar
SAVED, great informational pics !
Vouche: Jay-C
Old 06-22-2004, 09:44 AM   #12
EL Vap133
Moderator
EL Vap133's Avatar
Send a message via AIM to EL Vap133
Default Re: b16 2nd o2 sensor (88DXCRX)
Phil to the rescue!
EL Vap133 is offline Report Post   Reply With Quote
Old 06-22-2004, 10:17 AM   #13
Rywire
Rywire's Avatar
Default Re: b16 2nd o2 sensor (EL Vap133)
YA, there ya go!! Thats what I was looking for.
rywire.com
skunk2.com
karcepts.com
Old 06-22-2004, 11:03 AM   #14
nautica_t
nautica_t's Avatar
how do you tell which one is the primary o2 and which is the secondary o2, according to that picture, i have it switched around, would it make a difference if they were switched? TIA.
don't mean to hi-jack the thread.
Beware of Acura 2000 (Ontario, CA)
OG Crowhouse CF Winglet
Vouches: see profile
nautica_t is offline Report Post   Reply With Quote
Old 06-22-2004, 12:12 PM   #15
limpy
limpy's Avatar
Default Re: b16 2nd o2 sensor (nautica_t)
great pics that really helped. now how do i put the wire into the clip that goes into the ecu. isn't there a pin that goes over the wire that goes into the ecu? how do i get it in the pin?
Old 06-22-2004, 12:25 PM   #16
Rywire
Rywire's Avatar
If yours is running good, and there is no hesitation, its correct. If there is hesitation, switch them.
rywire.com
skunk2.com
karcepts.com
Old 06-22-2004, 12:29 PM   #17
88DXCRX
88DXCRX's Avatar
If you have it switched,it will run like crap..and will be too rich..
Go here: http://honda-tech.com/zerothread?id=404493&page=1
and http://honda-tech.com/zerothread?id=404493&page=2
and read what a guy called "Camshaft" had to say..(2 pages)
P.S.>If you do have them switched around,be sure to reset your ECU while
you are at it..
To wire it up you need an extra pin from a donor harness or an unused
wire if you have one.
For info on removing the pins,go here: http://www.deepstaged.net/rpecu4gb.htm
Old 06-22-2004, 04:13 PM   #18
nautica_t
nautica_t's Avatar
88DXCRX.
okay can i just take out the o2 sensor and switch spots. or are the actual o2 sensors built differently. cuz than i'll just switch the positions rather than re-splicing the wires. cuz right now, i guess you could say the primary o2 sensor wire is spliced into the secondary o2 sensor on the ecu pinout. and primary pinout wire is connected to secondary o2 sensor.
i don't got much bog.
only bog i get is when i'm in 5th gear goign about 110-115 KM/H at about 4 grand, it bogs there, if i put on the throattle it kinda chokes, so would changing my o2 sensor wiring correct this?
-> and by the way, i'm suppose to connect the A/F ratio to the primary o2 sensor correct, it doesn't bounce liek all the other A/F ratio i seen. Thanks 88dxcrx, you've been a great help so far. very much appriciated.
Old 06-23-2004, 08:19 AM   #19
88DXCRX
88DXCRX's Avatar
Yes,you can swap positions of the O2 sensors in the exhaust manifold..
That is what I would have done if I had known at that time..
Since my engine was already installed,
I figured it would be hell to get the sensors so
I just switched the two wires at the ECU.
For my car,having the o2 sensors wired correctly
made a big difference in the performance and drivability.
Good Luck,Phil
Old 06-23-2004, 09:06 AM   #20
nautica_t
nautica_t's Avatar
hey 88dxcrx, it feels a bit better now that i have changed the wires over, but we'll see how much response it has on the highway
thanks again bro. but i have another problem now lol
but i'll make a new thread.
Old 06-24-2004, 02:37 PM   #21
limpy
limpy's Avatar
Old 06-24-2004, 02:47 PM   #22
88DXCRX
88DXCRX's Avatar
answered above:
Old 06-24-2004, 05:07 PM   #23
RCautoworks
Send a message via AIM to RCautoworks
Little tip, the pic posted above showing the clips and numbers is a great pic but the pic is backward compared to how other sites list them, so just use 1 chart and you will be good.
RCautoworks is offline Report Post   Reply With Quote
Old 06-25-2004, 02:20 PM   #24
limpy
limpy's Avatar
Default Re: b16 2nd o2 sensor (90blackcrx)
Originally Posted by 88DXCRX
answered above:
thank you that was what i needed to know. everyone should save this page for some damn good info!!
Old 06-28-2004, 07:28 AM   #25
luciffer
luciffer's Avatar
I all ready have both my o2 sensors in, wired up and working correctly with the original white and green connectors.
But i want to replace the o2 sensors, so my question is are the two sensors the same and what is the replacement part no.
thanks
***Edit *** called my local honda dealer and for the o2 sensor from a 92-95 si they want $250 CND per sensor. I am i crazy or is this nucking futs? Has anybody replaced these o2 sensors with non OEM sensors? If so what brand and how did it turn out.
Modified by luciffer at 5:08 PM 6/28/2004
Modified by luciffer at 5:24 PM 6/28/2004
luciffer is offline Report Post   Reply With Quote
Bookmarks
af, b16, b16a, bar, civic, honda, location, o2, ratio, removing, sensor, sensors, tech, tricking, wire
