Old 06-17-2004, 06:02 PM   #1
nocturnaldragon
nocturnaldragon's Avatar
Send a message via AIM to nocturnaldragon
Default How to -Remove your crank pully-
I've seen a bunch of ppl saying how they cant get there crank pulley off of their car, the bolt is stuck dah dah dah dah dah- Well stop whining this is how to get the mo-fo off once and for all THE RIGHT WAY! not the ghetto way which im guilty of trying and f***ing up my own pulley so here you go.....
Also an Big Powerfull Impact would be easier but not everyone has one at home, so heres how to do it for the rest of us.
Tools Needed.
Harmonic Damper Pulley Holder Snap on Part# Stock YA6010 $65.95
Two Breaker Bars
17mm Socket (I think)
Extension for breaker bar (8ft pipe is my favorite for this application)
Steps needed:
These may vary slightly by vehicle but this is for my car 95 Honda del sol si
(01) First off insert the harmonic dampener holder into the pulley and attach the breaker bar and wedge it into the ground or frame (some place solid!!!)
(02) Stick the 17mm socket with an extension though the plastic shroud in the drivers side wheel well. (I took off the wheal to make it easier and placed the car on jack stands)
(03) Take your long ass piece of pipe onto your extension in a way you can get lots and lots of leverage on it. (counter-clockwise)
(04) Put a little bit of pressure on it and MAKE SURE YOUR OTHER BREAKER BAR WONT MOVE!!!!!!! (If it does on the next step you can get seriously hurt if your not careful!!!)
(05) Take a deep breath
(06) PUSH with all your might on that bar, (counteclockwise) alternate between Pushing on it and just jumping on it for fun and leverage of course but be careful you don’t fall on your ass when it does break free.
(07) When it does come off, RELAX! and have a cold one!
(08) Curse the midget who put the ****er in there!
ITS NOT OVERTORQED! The manual states it should be in with (I cant seem to find it right now most likely cause I don’t car enough to look) but it’s a LOT
Questions feel free to ask! But this should FINALY clear up the issue Thank You Good Bye Piss off Good Luck
"Objects in Mirror are losing"
Modified by nocturnaldragon at 12:51 PM 9/5/2005
My paint project (56k uncertain) - http://www.honda-tech.com/zerothread?id=1262071
Del Sol Pro's and Con's The official end all thread. - http://www.honda-tech.com/zerothread?id=1273946
Originally Posted by flowbee
I wont lie, I've whacked it to a video game before
nocturnaldragon is offline Report Post   Reply With Quote
Old 06-17-2004, 06:13 PM   #2
Padawan
SUPER smartERATOR
Padawan's Avatar
Default Re: How to -Remove your crank pully- (nocternaldragon)
Or my preferred method...
Step 1.) Remove bolt with 3/4" impact gun in 1-2 seconds.
open your mind.
-NEMO ME IMPUNE LACESSIT-
Padawan is offline Report Post   Reply With Quote
Old 06-17-2004, 06:17 PM   #3
nocturnaldragon
Default Re: How to -Remove your crank pully- (Padawan)
I would also LOVE THAT methode but you have to keep in mind most ppl cant afford nice toys like that so i listed the easiest way to do it without Air Tools so the typical kid can do with with standard handtools. Even tho, on mine i had a 1" and the Mo fo wouldent come off, i ended up snapping the pos in half where the two sections were joined and had to replace the entire pully- Dident know untill after i reinstalled and ran the car and the other pully came off and messed up the power steering belt.......
Old 11-09-2004, 06:56 PM   #4
dopamine
dopamine's Avatar
Hi
I am facing some problems using a breaker bar. I ended up breaking the extension. I am not sure if the crank pulley nut is to be turned clockwise to loosen or counterclockwise. I have browsed a lot of posts and everyone forgets to mention that. It would help a lot. I have a Accord 92 Ex
dopamine is offline Report Post   Reply With Quote
Old 11-09-2004, 07:03 PM   #5
Infinity_Racer
Infinity_Racer's Avatar
Send a message via AIM to Infinity_Racer
Default Re: How to -Remove your crank pully- (dopamine)
i just bought a heavy duty impact wrench and used it for the 1-3 seconds it took to remove the nut, then returned it at sears...saved me SOOOOOOO MUCH time and head aches...i wouldve kept it but i really couldnt afford a $250+ tool at the time...maybe i'll go back and get it later on...
I'm an S2000 elitist TOO!! LOL
Infinity_Racer is offline Report Post   Reply With Quote
Old 11-09-2004, 07:20 PM   #6
didyouhearthat
didyouhearthat's Avatar
Good stuff. I broke a ratchet and a socket trying to get that S.O.B. off. It's still counter-clockwise, right?
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." 224 posts
didyouhearthat is offline Report Post   Reply With Quote
Old 11-09-2004, 07:36 PM   #7
Dyzee
Dyzee's Avatar
114ft/lbs is the torque spec on it. (Off my helms)
Dyzee is offline Report Post   Reply With Quote
Old 11-09-2004, 07:46 PM   #8
blackeg
blackeg's Avatar
Default Re: (Dyzee)
seriously the impact gun works in 2 seconds, and wont even rotate your motor slightly off of tdc. the breaker bar is asking to break sockets and shit. believe me ive broken my share of sockets and extensions
hx coupe 2652lbs - lsvtec--318whp/241wtq
12.54@115.57 on bfg's
92 hatch---415whp/300wtq in '07
425whp/286wtq in '08 2410lbs
12.1@125.5 1bar boost @etown fall nats
blackeg is offline Report Post   Reply With Quote
Old 11-09-2004, 08:13 PM   #9
Infinity_Racer
Default Re: (blackeg)
yeah i tried the socket/wrench/extension bar...NOTHING...i ordered the crank pulley tool but it took 4 days to come, so in those 4 days i juss took a trip to sears, came home, took the nut off, went back to sears and that was that...the tool then came in the next day and it helps A LOT when putting the nut back on and tightening it...
Old 11-09-2004, 08:37 PM   #10
yaya
yaya's Avatar
itr eg killed by hurricane katrina.
2002 s2k
yaya is offline Report Post   Reply With Quote
Old 11-09-2004, 09:05 PM   #11
nocturnaldragon
Default Re: How to -Remove your crank pully- (yaya)
Somebody took the time to read my post? im flattered
Old 11-09-2004, 10:11 PM   #12
Dc_Ek
Dc_Ek's Avatar
Nice man! Just like me, it saves me lots of troubles!
Dc_Ek is offline Report Post   Reply With Quote
Old 11-09-2004, 10:19 PM   #13
rovigian
rovigian's Avatar
Send a message via AIM to rovigian
I love all my air tools, mainly my 1/2 impact and harbor frieght impact sockets!
<U>Tally of hondas owned</U>
Civic Si's - 3
Integra LS's - 2
Integra GSR's - 5
Integra Type R's - 1
Accord V6's - 2
Vouches: litterbox, pK1spooled, NoLimitMotorsports
rovigian is offline Report Post   Reply With Quote
Old 09-04-2005, 11:25 PM   #14
Combustion Contraption
Combustion Contraption's Avatar
Send a message via AIM to Combustion Contraption
Originally Posted by dopamine
Hi
I know this is a little late, but for everyone else out there, its counter clockwise.
EARL LASKEY, YOU WILL BE MISSED
CCCylinderheads.com
Buy the 85x89 Project Hatchback!
Combustion Contraption is offline Report Post   Reply With Quote
Old 09-05-2005, 12:23 AM   #15
komat
komat's Avatar
Default Re: How to -Remove your crank pully- (LsVtec92Hatch)
took me like 40sec to take my bolt off with a impact gun
Fully Built 1.92L LSVtec w/ SC61 - 419hp/312tq
Semi Built 1.8L LSVtec 219hp/154tq - all motor
komat is online now Report Post   Reply With Quote
Old 09-05-2005, 11:00 AM   #16
nocturnaldragon
You know not everyone has a big enough impact in there garage that thing is torqued down to I want to say 400ft/lbs I cant find it in my manual but I remember its a LOT
Old 09-05-2005, 11:02 AM   #17
komat
komat's Avatar
Default Re: How to -Remove your crank pully- (nocturnaldragon)
only 130lb/ft
Old 09-05-2005, 11:35 AM   #18
nocturnaldragon
Default Re: How to -Remove your crank pully- (komat)
ok I thought it was a lot more then that, I couldent find it in my shop manual to be sure tho. Either way its more then most impact guns that people have in there homes would be able to handle.
Old 09-05-2005, 12:02 PM   #19
westspeed
westspeed's Avatar
Originally Posted by komat
only 130lb/ft
well i used my 250lb/ft impact and the bitch wont budge
westspeed is offline Report Post   Reply With Quote
Old 12-04-2005, 06:23 PM   #20
Elwuudz
Elwuudz's Avatar
Send a message via AIM to Elwuudz
thanks for the post... i ended up using an impact gun the size of my forearm
spray wd40 at the base of the nut and 5sec it was off
I only wish keeping the alignment on all my gears while tightening the timing belt tensioner was that easy. 1hour of frustration
Elwuudz is offline Report Post   Reply With Quote
Old 12-04-2005, 06:31 PM   #21
my_slow_civic
my_slow_civic's Avatar
Default Re: How to -Remove your crank pully- (Elwuudz)
For $25 this little tool here works wonders.
SLC Theft
04 SSM AP2
my_slow_civic is offline Report Post   Reply With Quote
Old 12-04-2005, 07:57 PM   #22
civic_driver
civic_driver's Avatar
try at least 625lb/ft impact... those other ones are crap.. 250lb/ft impact might work if you have a kick ass compressor but a 625lb/ft will make up slightly for crappy compressor... if you have both quality pieces that pulley nut is a piece of cake..
i got a 1000lb/ft twin hammer in reverse... got it for $120 or so from ebay... kicks ass... wish i had a different compressor but the one i have currently does the job... it cost me $30 used...
99 Civic VP | d16y7 | Automatic
For Sale Thread
civic_driver is offline Report Post   Reply With Quote
Old 12-04-2005, 09:39 PM   #23
HiProfile
HiProfile's Avatar
Default Re: How to -Remove your crank pully- (my_slow_civic)
I saw one of those on ebay just the other day. If not for air tools, I'd be getting that and a nice breaker bar. If you do decide to do it without air tools, you should still get at least a cheap imact socket set. Those hardened bitches are thicker and will rarely break in half (if they do, you and the other 3 ppl pushing on the bar asked for it).
The only problem with those tools are torquing it with the motor out of the car - slightly tricky. I just used the impact to snug it on, then used a paint pen to monitor it for the first 1000 miles - no movement (or one full turn loose ).
1994 Del Slow VTEC - OEM B16A3 - winter beater
1995 Civic EX coupe - turbo D16Z6 - summer beater
1967 Firebird 326 H.O. - SMC 350ci - needs a bigger cam, or turbo...
HiProfile is offline Report Post   Reply With Quote
Old 12-04-2005, 10:28 PM   #24
Tony_EM1
Tony_EM1's Avatar
i just use a 1/2 pry bar with a 19mm socket and a flat head screwdriver on the flywheel... works for me
<FONT COLOR="red">EMO</FONT>mob<FONT COLOR="red">♥</
Tony_EM1 is offline Report Post   Reply With Quote
Old 12-04-2005, 10:36 PM   #25
s2kkk
s2kkk's Avatar
Send a message via AIM to s2kkk
Get a good impact gun.
Boosted - 4/18/05 - Tuned - 6/13/05 - Sold - 8/8/05 http://images.honda-tech.com/set1/smile/emsad.gif
Thats right bitches, sold not stolen.
EH2. Stock B16 w/CTR cams 325WHP@10PSI 12.0@114MPH - SOLD
AP1 GPW. Amuse CF Lip, OEM Black Wheels, Lowered on Eibachs - TOTALED
Current - 2006 Laser Red/Graphite G35 Coupe 6MT. Premium package, Navigation package, Aero package, Luff M1 Comp. Gold 8.5x20F 10.5x20R, Tinted, Lowered, JDM Yellow fog light bulbs.
s2kkk is offline Report Post   Reply With Quote
Bookmarks
1992, civic, crank, crx, harmonic, honda, impact, integra, nut, prelude, pulley, pully, remove, removed, removing, tools
