Old 06-13-2004, 03:10 PM   #1
projectej8
projectej8's Avatar
Default Hard downshift
Im going to try to make this short and understandable, when i try downshifting from lets say... 3rd to 2nd, the car jerks once and goes. My question is, how do i prevent the car from jerking and downshift smoothy? thanks in advance.
projectej8 is offline   Reply With Quote
Old 06-13-2004, 03:14 PM   #2
duh blacksheep
duh blacksheep's Avatar
Send a message via AIM to duh blacksheep
Default Re: Hard downshift (projectem1)
blip the throttle to where the rpm would be at that speed on 2nd(before letting it go in 2nd)..then let it rip
duh blacksheep is offline   Reply With Quote
Old 06-13-2004, 03:15 PM   #3
JDMSiGuy17
2000 Honda Civic
JDMSiGuy17's Avatar
my guess would be you are letting out the clutch to fast. Also if that isn't the problem try rev matching to make the transition easier. Hope this helps. Click the image to open in full size.
JDMSiGuy17 is offline   Reply With Quote
Old 06-13-2004, 03:17 PM   #4
handa
handa's Avatar
Default Re: Hard downshift (JDMSiGuy17)
out of the topic but isn't downshift a bad pressure to your engine? i've always wonder that.
handa is offline   Reply With Quote
Old 06-13-2004, 03:23 PM   #5
ABK
ABK's Avatar
Send a message via AIM to ABK
Default Re: Hard downshift (handa)
not really, it might be bad for your tranny if not done right. You need to hit the trottle a little before you are going to let the clutch out, also if you are not trying to catch up to anybody fast just hit the trottle a little bit and let out the clutch just like in normal driving.
Swaps, engine work, street tunes cheap in Chicago area, pm me.
ABK is offline   Reply With Quote
Old 06-13-2004, 05:36 PM   #6
projectej8
projectej8's Avatar
thanks guys, yea it feels like im torturing the hell out of my tranny. For example if im cruising in 4th at 40mph, and i slow down to 25, i shift to third and the car jerks hard once and continues on. So i just give it a lil gas before letting go of the clutch?
Old 06-13-2004, 05:49 PM   #7
SkRiBLaH
SkRiBLaH's Avatar
Send a message via ICQ to SkRiBLaH Send a message via AIM to SkRiBLaH
your prollie thinking about "downshifting" is shifting down the gears in order to help slowing down--- no. thats not downshifting. thats ******* your tranny up.
downshifting is putting the car in a lower gear in order to get the RPMs up in the powerband.
Once upon a time there were 300 horses. The End.
SkRiBLaH is offline   Reply With Quote
Old 06-13-2004, 05:50 PM   #8
Skip01
2000 Honda Civic
Skip01's Avatar
Default Re: Hard downshift (SkRiBLaH)
Watch a BMI vid and you'll see how to downshift properly. Click the image to open in full size.
EJ8 BUILD: http://honda-tech.com/showthread.php?t=3194154
Skip01 is offline   Reply With Quote
Old 06-13-2004, 06:14 PM   #9
FATBOYeg6
FATBOYeg6's Avatar
Default Re: Hard downshift (Skip01)
with practice, you can blip the throttle and downshift seamlessly. i shift from 4th to 2nd seamlessly, other people in the car can't even tell except for the rpm's jumping up. it just takes time. the way i learned to do it is to coast in 4th at about 40mph. i clutch in, blip the throttle, and put it into secondwell letting the clutch out just as the rpm's reach where i intend them to be. with practice, you should be able to downshift like this and not even notice it. i find myself doing it and not even noticing i did it. practice man. good luck
Great minds think of ideas, small minds think about people.
FATBOYeg6 is offline   Reply With Quote
Old 06-13-2004, 06:54 PM   #10
duh blacksheep
yeah, or let out the clutch way slower
Old 06-13-2004, 07:32 PM   #11
projectej8
projectej8's Avatar
Default Re: Hard downshift (duh blacksheep)
thanks everybody for your help, i guess i need more practice since im a noob at driving a manual.
Old 06-13-2004, 07:40 PM   #12
bboylito
bboylito's Avatar
Send a message via AIM to bboylito
i thought i knew how to downshift i guess not because your suggestions are different from what i do. Are you guys saying that when going 45 mph in 4th to push the clutch in get in neutral let the clutch out, then throtle to get rpms high, then clutch in again to shift into third or second and then let clutch out???????
i usually just go 45 mph in 4th clutch in rev a lil and drop into third and let go of the clutch...hence i only clutch once not twice, so i rev while the clutch is pressed against the floor and not in neutral.
Wow i wrote a mess well you all have a great day now
Quote, originally posted by hybridcrx
....but flywheel chunks through my car and maybe in my passengers ***** didn't sound like fun.
VOUCHES: nY's FiNeSt, EvasiveMotorsports.com, bluebullet, jimmhatch, FOC-US 2K, prostreetonline.com
bboylito is offline   Reply With Quote
Old 06-13-2004, 08:57 PM   #13
duh blacksheep
Default Re: Hard downshift (bboylito)
you can do that, its the same outcome, but the way you descrive will wear out the syncros really fast. you can just pull it out of gear without the clutch, blip the trottle and then cltuch and gear in, its the same as double clutching but without hitting the clutch twice Click the image to open in full size.
Old 06-13-2004, 09:07 PM   #14
The Airman
The Airman's Avatar
it doesn't wear out the synchros to double clutch this is untrue. its actually assist them. even more what you describe is hard on the tranny if you don't know how to "unload" the tranny first. but yeah just learn how to drive first.
[quote=SleepnCiViC]slightly modded b16's vtec only make noise anway, so its cool[/quote]
한국 말 배우는 학생이에요
13.7 YO!!
[url="http://www.mercedimports.com/modules.php?op=modload&name=Downloads&file=index&req=getit&lid=4"]http://www.mercedimports.com/m...lid=4[/url]
The Airman is offline   Reply With Quote
Old 06-14-2004, 04:35 AM   #15
FATBOYeg6
FATBOYeg6's Avatar
Default Re: Hard downshift (JMaxx)
that is just how i personally do it. when i clutch, i only have to move it about 2 inches to have the clutch fully disengaged, so its more of a double tap when i do it.
Old 06-14-2004, 06:05 AM   #16
boostin4drcivic
boostin4drcivic's Avatar
Send a message via AIM to boostin4drcivic
Default Re: Hard downshift (ninefivehatch)
please rev match when u downshift hard. your tranny will want to hug you afterwards Click the image to open in full size.
'97 civic ex coupe milano red "F VTEC"
[B]LS swap equipped[/B]
[I]-boost is lurking closer than you think!![/I]
[I]-c'mon kids repeat after me, can we say 'T3/T04e OWNS'?!?[/I]
vouch list: tararan [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , kranked91dx [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , 95excoupe [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , hyperITR742 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , voltageGSR [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
boostin4drcivic is offline   Reply With Quote
Old 06-14-2004, 07:02 AM   #17
thrty8street
thrty8street's Avatar
Send a message via AIM to thrty8street
Default Re: Hard downshift (boostin4drcivic)
what happens to the tranny when you downshift hard without double clutching?
my friend does that all the time, he downshifts from 4th to 2nd and the whole car jerks back.
thrty8street is offline   Reply With Quote
Old 06-14-2004, 07:48 AM   #18
duh blacksheep
Default Re: Hard downshift (thrty8street)
when you force your shifter into gear, it will wear out the syncros really fast without double clutching. letting go of the clutch fast to make the car jerk is irrelavent. if your friend keeps this up, his syncros will last way shorter than the average driver and start to grind his gear cause the syncros wont beable to hack that abuse
Old 06-14-2004, 09:12 AM   #19
FATBOYeg6
FATBOYeg6's Avatar
what he said. on a somewhat related note, don't shift hard when your first learning standard. when i first got my car in feb. i thought i was badass driving a standard. now my 3rd gear synchro is on its way out. a hard downshift isn't really needed unless your on a road race course. Click the image to open in full size.
Old 06-14-2004, 10:51 PM   #20
inane
inane's Avatar
heel-toe downshift Click the image to open in full size.
it takes awhile to learn but once you do its sweet and you'll be doing it all the time...
basically when you have to slow down, you press the brake to slow down... while holding the brake down with your right foot the entire time... you push in the clutch with your left foot, downshift, twist your right foot and blip the throttle to the RPMs it needs to be... then you let out the clutch and let off the brake (if needed)... so you're doing a lot at once but it's definitely smoother and better...
the only thing is that you really do need good throttle response to really be a blip... with most stock cars you kinda have to press hard on the throttle or hold it down longer to get it to be where it needs to be...
inane is offline   Reply With Quote
Old 06-15-2004, 02:14 AM   #21
EdLeake
EdLeake's Avatar
As the man says, heel and toe. I drive everywhere heel and toe, i can let the clutch out INSTANTLY without any jerk or missmatch of revs and thats how it should be you don't see pro drivers feeding clutch coming down gears, learn to drive before you wreck your cars people. Click the image to open in full size.
EdLeake is offline   Reply With Quote
Old 06-27-2004, 10:07 AM   #22
Slow_Em1
revv match..then slam it
Slow_Em1 is offline   Reply With Quote
Old 06-27-2004, 12:06 PM   #23
crashN2u
crashN2u's Avatar
According to the DMV he's downshifting, just not doing it right. All of the people I know had to downshift to slow down their cars during the manual driving test. If they didn't do it they lost points. That's why they recommend using an automatic for the test. Also I have heard that it is recommended to do this in conjunction with your brakes to reduce stress on them as well as extend their life. It also brings the vehicles speed down much faster than just using your brakes. I use it while I'm in traffic to keep from hitting the idiot in front of me who just slammed on his brakes because he was tailgating.
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both."
- Ben Franklin
crashN2u is offline   Reply With Quote
Old 06-27-2004, 12:37 PM   #24
egtype-r
egtype-r's Avatar
Send a message via AIM to egtype-r
Default Re: Hard downshift (crashN2u)
what costs more? brake pads? or a new tranny and clutch?
buy my ****
http://hondamarketplace.com/zerothread?id=1449620
egtype-r is offline   Reply With Quote
Old 06-27-2004, 06:51 PM   #25
crashN2u
crashN2u's Avatar
Default Re: Hard downshift (egtype-r)
I've spent more money on my brakes than it would cost to get a new tranny. Besides I have never had a problem with either of my trannys(or would it be trannies) in my cars and I downshift daily to slow down. I've never seen any damage to my engine or tranny. If you do it right it will use your engine to help you slow down. I'm not talking about slamming it from 5th to 3rd at 80-90 MPH. I've seen people do it and that's just stupid.
- Ben Franklin
1992, 2000, 2nd, 3rd, 97, break, civic, downshift, gear, hard, honda, jumps, shift, slave
