> Acura Integra Type-R
Old 06-09-2004, 08:59 PM   #1
.RJ
.RJ's Avatar
Send a message via AIM to .RJ
Default Koni Shock Install (56K :burn:)
A write up with some pics here, in case you guys have not done this before.
Difficulty: On a scale of 1-5, I give this project a 2.
Time: 2-4 hrs, depending on how fast you work, if you have an impact or lift, how drunk you are.
First, you pick up some busted ass used Konis. Then you call up CRX Lee (<-- link there) and ask him to rebuild and revalve them stiffer. He'll send you some pimpy boxes like this
Now put the car on stands and take your spinnerz off
Assemble your tools
And we'll start with the front suspension first. Remove the 12mm bolts holding the brake line to the shock
Remove the brake line from the shock
Then remove the 14mm pinch bolt at the top of the shock fork
Now remove the bolt holding the shock fork to the lower control arm. Secure the bolt with a 17mm wrench, and remove the 17mm nut
Use a BFH and a drift to tap the bolt out of the LCA
Drop the shock fork off of the shock
Remove the 14mm nuts on the shock tower, the shock will drop once they are removed (hold onto the shock body as you do this)
Remove shock assembly towards front of the car
That was easy, now onto the rear......
Disconnect the swaybar endlink from the LCA, 14mm bolt
Remove the lower shock bolt, 14mm
Remove the upper shock bolts, also 14mm
The shock will then drop
Remove the 14mm bolt holding the upper control arm to the trailing arm. This gives the suspension enough droop to get the shock assembly out
Remove shock assembly towards rear of the car
Ok, everything's out lets take them apart
Get your spring compressors and compress the spring
Using a 14mm wrench and a 5mm hex/allen key, remove the upper shock mount bolt, and the upper mount
Take the spring off
Label your springs if you are re-using them
*** If not, and are just replacing springs on the stock shocks then you would just reassmble now in the reverse order of dissasembly. Spring compressor is usually not required with lowering springs***
Using a prybar and BFH or other suitable device, pound the brake line bracket off of the stock shock. Give it solid hits and work around the bracket until it slides off
Separate the rubber bushings from the metal collar in the upper shock mount
Replace the stock metal collar with the one supplied by Koni
One ITR's the shock shaft is too large for the stock upper mount (stock is 10mm, Koni is 12mm). They're metal on top and bottom, so I took them to a machine shop where they bored out the holes on a drill press so that the shock shaft will fit through. I do not think this is a problem for civic and other integra mounts, they are supposedly 12mm.
<FONT COLOR="red">Warning: Ghetto-Fab Ahead</FONT>
The bumpstops didnt fit over the Koni shock shaft either. So I introduced them to Mike's dremel.
Line up the brake line bracket with the divot on the shock as shown, and pound the bracket in place. I used a piece of steel tubing I had sitting around and light taps with the BFH until its all the way on.
Install the circlip on the shock body
Then the ring for the spring seat
Now the spring seat
Dust cover, bumpstop and washer
Compress the spring, put the upper hat, washer, and pair of 20mm nuts on the shock shaft.
Take the spring compressors off, and installation is the reverse of dissasembly. On the front, make sure the divot on the shock is lined up with the pinch bolt on the lower shock fork. The lower fork will not slide all the way on and the bolt will not thread freely in if they are not lined up. In the rear, jack up the lower control arm to get the upper control arm back onto the trailing arm once the shock is in.
Torque specs for ITR on reassembly:
Front
Upper Hat 36 ft-lbs
Pinch Bolt 32 ft-lbs
Lower fork 47 ft-lbs
Brake Line Brackets 16 ft-lbs
Rear
Upper Hat 36 ft-lbs
Lower Shock Mount 40 ft-lbs
Swaybar Endlink 29 ft-lbs
UCA 40 ft-lbs
Modified by George Knighton at 3:50 PM 7/7/2008
Madison Motorsports
CB750 | CB350 | SV650
04 Trek 8000 | 06 Trek Pilot 2.1 | 85 Trek 660
Racing is one of the finest mechanisms for the disposal of money - RR98ITR
.RJ is offline Report Post   Reply With Quote
Old 06-09-2004, 09:04 PM   #2
GettaluvR
GettaluvR's Avatar
Default Re: Koni Shock Install (.RJ)
wow nice write up !!
let us know how's the ride
2005 Infiniti G35 coupe 6MT w/ Nav
2003 BMW 330i --sold
2001 BMW 330i --sold
2001 CW ITR RIP stolen
DEC 27th 2003 2pm came home dec 29th 2:30pm found out my car was not in my garage.
bought it July 10th 2001
24000km only
1986 VW Golf -- sold....
GettaluvR is offline Report Post   Reply With Quote
Old 06-09-2004, 09:05 PM   #3
.RJ
.RJ's Avatar
Default Re: Koni Shock Install (GettaluvR)
Rides like its on jackstands now
Battery died on the impact, will finish later
Madison Motorsports
Old 06-09-2004, 09:14 PM   #4
FyrFytr
FyrFytr's Avatar
Send a message via AIM to FyrFytr
stunna!
TW 2009 Honda Fit Sport (Daily Driver) BRP 2000 Impreza 2.5RS
CW 1998 Integra Type-R (stolen) 1984 Toyota Supra (wrecked)
FyrFytr is offline Report Post   Reply With Quote
Old 06-09-2004, 09:14 PM   #5
Mugen Type R
Mugen Type R's Avatar
Send a message via ICQ to Mugen Type R
i only have 3 things to say:
Nice write up,
thanks alot for the good info and pics that were clearly indicated with photoshop
and last but not least:
WOW, your the man!
Once your rear wiper and motor is removed, take it to your parent's house, because they love storing your random car parts.
Mugen Type R is offline Report Post   Reply With Quote
Old 06-09-2004, 09:21 PM   #6
navin
navin's Avatar
Default Re: (Type R 98-870)
what...where's the call for the snagglet33f mechanic to come over and help..err drink brews..
fix my car ryan, and nice write up
TFU EH2
navin is offline Report Post   Reply With Quote
Old 06-09-2004, 09:23 PM   #7
.RJ
.RJ's Avatar
Default Re: (navin)
Its busted again?
Madison Motorsports
Old 06-09-2004, 09:34 PM   #8
navin
navin's Avatar
Default Re: (.RJ)
the idle ownz me...
Honda IACV's
TFU EH2
Old 06-09-2004, 09:38 PM   #9
MissMyHonda
MissMyHonda's Avatar
nice writeup
MissMyHonda is offline Report Post   Reply With Quote
Old 06-09-2004, 09:38 PM   #10
.RJ
.RJ's Avatar
Default Re: (navin)
Swap that chit out for another one
Madison Motorsports
Old 06-09-2004, 10:05 PM   #11
Bbasso
Bbasso's Avatar
Very cool, thanks RJ for the write up.
Bbasso is offline Report Post   Reply With Quote
Old 06-09-2004, 10:10 PM   #12
Tim Maryak
Tim Maryak's Avatar
Send a message via AIM to Tim Maryak
Default Re: (.RJ)
bling blang, why no springs to slam it?
<U> 1999 Acura Integra GS-R </U>
<FONT COLOR="blue">.:. OEM JDM .:. Neuspeed .:. A'pexi .:. KYB .:. Skunk 2 .:. AEM .:. Energy Suspension .:. NGK .:. Denso .:.</FONT>
162whp/121tq 12/27/03
Tim Maryak is offline Report Post   Reply With Quote
Old 06-09-2004, 10:12 PM   #13
py1188
py1188's Avatar
Send a message via AIM to py1188
Default Re: Koni Shock Install (Bbasso)
Good write up. I've done this so many times I can now do it in my sleep
Erick http://images.honda-tech.com/set1/smile/embeer.gif
'00 PY1188
py1188 is offline Report Post   Reply With Quote
Old 06-09-2004, 10:28 PM   #14
Mindtrap
Mindtrap's Avatar
Default Re: Koni Shock Install (py1188)
thanks rj, exactly what i needed.
alex jones: 9/11 road to tyranny
UnPATRIOTIC? UnAMERICAN? or merit credibility? you decide for yourself.
http://propagandamatrix.com/mu....html
Mindtrap is offline Report Post   Reply With Quote
Old 06-09-2004, 10:51 PM   #15
Eluder200K
Eluder200K's Avatar
Send a message via AIM to Eluder200K
Default Re: Koni Shock Install (Mindtrap)
Sweet, thanks for the great write-up RJ
When I did the shocks on my buddies R I just used the car as a spring compressor and took the top shock retaining nut off with the car on the ground, that way you don't need to use spring compressors (which can be kinda scary). Does anyone else use this technique? It sure is a heck of a lot easier, that's for sure.
ITR Expo 4 DVD Teaser
ITR Expo 3 DVD
Other short videos
Panekmechanik.com
Eluder200K is offline Report Post   Reply With Quote
Old 06-09-2004, 11:00 PM   #16
itr1244
itr1244's Avatar
Default Re: Koni Shock Install (Eluder200K)
damn.. nice How to "".. that's nice.. thanks alot
itr1244 is offline Report Post   Reply With Quote
Old 06-09-2004, 11:32 PM   #17
jiahanhao
jiahanhao's Avatar
Send a message via AIM to jiahanhao
i did the same thing with my ceevic
Originally Posted by ActiveAero@some dood
How do you know your a good driver? Did you compete in the FIA World Freeway Offramp Top Speed Championship?
jiahanhao is offline Report Post   Reply With Quote
Old 06-10-2004, 01:15 AM   #18
RGoose18
RGoose18's Avatar
Default Re: Koni Shock Install (jiahanhao)
Amazing write up! Keep it up
RGosline18@hotmail.com
RGoose18 is offline Report Post   Reply With Quote
Old 06-10-2004, 02:03 AM   #19
Slow_Em1
[quote=.RJ]
good ol' craftsman tools.
Slow_Em1 is offline Report Post   Reply With Quote
Old 06-10-2004, 02:18 AM   #20
littledan
that's the best how to i've seen yet.
littledan is offline Report Post   Reply With Quote
Old 06-10-2004, 04:43 AM   #21
bender
bender's Avatar
Default Re: (littledan)
Very nice how-to; especially the warning on what parts need to be modified. Thanks.
27 DS ATL region SCCA
bender is offline Report Post   Reply With Quote
Old 06-10-2004, 05:06 AM   #22
EleanoR
EleanoR's Avatar
You ain't kidding. Once you do this once the next couple of times will go by much faster. Just make sure you slow yourself down the first few times because in my case I accidentally put stuff on the new Koni shock in the wrong order which didn't hurt it but I realized later that day so I had to take the shock off the car for a 2nd time
mike
FS ITEMS: B18C 85mm Short block, Momo Cup GT Seat! http://hondamarketplace.com/showthread.php?t=2494097
EleanoR is offline Report Post   Reply With Quote
Old 06-10-2004, 05:17 AM   #23
Philly_NBP_R
Philly_NBP_R's Avatar
Default Re: Koni Shock Install (EleanoR)
nice write up .RJ
2001 NBP ITR #386 - sold 02/18/05
2002 Subaru Impreza 2.5 RS - fun to drive, needs 100 more hp...
Check out some pics here
Philly_NBP_R is offline Report Post   Reply With Quote
Old 06-10-2004, 07:33 AM   #24
PatrickGSR94
PnP Hater Moderator
1994 Acura Integra
PatrickGSR94's Avatar
Send a message via AIM to PatrickGSR94
woooo finally a write-up showing the CORRECT way to install Konis, including the brake line bracket swap, hardware modification and everything!
Only one thing, though:
I don't understand this part. When you replace that metal tube inside the upper mount for the one supplied by Koni, the new one is of a larger ID to accomodate the Koni shock piston. What exactly did you have to get machined?
Also I didn't have to do anything to my bumpstops, I just jammed them over the piston and they eventually got past that little piece where the washer sits.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline Report Post   Reply With Quote
Old 06-10-2004, 07:41 AM   #25
.RJ
.RJ's Avatar
Default Re: Koni Shock Install (PatrickGSR94)
The tops and bottoms of the rubber that sits in the shock mount are 1/8" or so metal, there's no washer on top of them like on civics and integras. Its just large enough for the stock shock shaft, and hence about 2mm too small for the larger Koni shock shaft. Lee @ Koni told me that only ITR's and S2000's have a 10mm shock shaft. I have no idea why......
Since the holes were enlarged, I used the koni supplied washer on top, under the nuts to be safe.
If you had a drill with a good 12mm carbide bit, I suppose this could be done at home, but I dont so to the machine shop it went. Only cost me $25 to have them drilled out.
Madison Motorsports
Bookmarks
acura, assembly, bracket, brake, busted, civic, difficulty, honda, install, installation, integra, koni, konis, line, s2000, shock, shocks
