| Welcome to Honda-Tech! | ||
#1 |
1992 Acura IntegraJoin Date: Feb 2004
Location: That's the wrong tone... I'm Skunk2 certified.
Okay, so my positive lead from the battery to my amps touched the chassis of the car, and burned out the fuse while I was on a delivery. Stupid me didn't secure the amp to the car. I got back to Domino's, shut off the car, and tried to start it back up again for another delivery. It started, but it took 2 tries, and it didn't sound right. I went on the delivery without shutting off the car, came back, and had to start it up again. When I turned the key, the accesories came on, but when I tried to start it, nothing happened. The second time I turned the key, the accessories didn't come on, and still wouldn't start. (of course) Soo, I'm going back with a multimeter to try and see if I can figure out what's wrong. Could it be the ignition, or the starter? This sucks. Please help me out.
#2 |
oh, and come to think of it, it smelled like something was burning inside the car right after it shorted out.
#3 |
| Garage is empty, add now |
test the voltage on your battery. a short to the chassis will put out massive current. it could be dead or damaged.
90 RS money HOLE!! [img]http://images.honda-tech.com/set1//smile/emcrook.gif[/img] 94 GSR motor done blowed up Vouches: lanojp1, thenick, AcMan23, slooogsr, dohcdelsol, y_design, twopointzero, slixxracing, g2witrotas, art701, ef9guru36 [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] FOR SALE: [url="http://www.honda-tech.com/zerothread?id=1026920"]GSR crank/rods/pistons[/url], [url="http://www.honda-tech.com/zerothread?id=1013322"]DA partout[/url] |
#4 |
battery voltage is fine
#5 |
did you check all your other fuses?
#6 |
i got it running. i disconnected and reconnected the battery. that got the accessories back up. Then I tapped on the starter with a socket wrench. BAM! It started right up. So tomorrow morning I gotta get a new starter from Advance. Thanks for the help, Publius
Modified by MugenDude at 2:20 AM 6/4/2004 |
| Tags |
| amplifier, car, lead, shorted, shorting |
