Old 05-30-2004, 03:03 PM   #1
cbgator315
cbgator315's Avatar
Send a message via AIM to cbgator315
Default How to remove the door panels on 2000 accord coupe
If anyone knows where I can get some detailed instructions on removing the door panels of my coupe. I am going to replace the speakers. I know pretty much how to do but I would like to have some instructions just to double check to make sure I am doing it right before I get into and realize I messed something up.
cbgator315 is offline   Reply With Quote
Old 05-30-2004, 05:36 PM   #2
-RedneckDave-
Working
2001 Honda Accord
-RedneckDave-'s Avatar
Default Re: How to remove the door panels on 2000 accord coupe (cbgator315)
There is one screw behind the door handle behind a small cover that is over the screw head. take that out and then take out the screw in the pull handle beside the window controls. If you have manual windows you will have to but a tool to remove the crank, which is sold at most auto parts stores. You have to pull of the plastic piece that is just inside of the side view mirror which just pops off (be careful not to break the clips behind there) The majority of the door panel is held on by clips which just pull out. Start at the bottom of the door and work your way up and back. When all the clips are free remove the plug for the light in the bottom of the door. After that, with the window down, lift the door panel off the frame of the door but be aware that there are still wires attached behind the panel. The door handle should just pull back and then be pushed through the panel. After that just remove the plugs for the controls on the panel and the panel should be free.
Let me know if you have any other questions.
"I'm convinced that if Darth Vader drove an Accord, it would be yours." JG Luder
-RedneckDave- is offline   Reply With Quote
Old 05-31-2004, 01:38 AM   #3
cbgator315
cbgator315's Avatar
Cool I appreciate it. Like I said I pretty much assumed that was how it went. Just wanted to duouble check before I did anything catostrophic.
Old 05-31-2004, 01:51 AM   #4
-RedneckDave-
Working
2001 Honda Accord
No problem.
2000, 2002, 2004, 99, accord, accoud, coupe, door, instructions, panel, panels, removal, remove, removing, speaker
