NEW ENGINE BREAK-IN...Some new ideas
Old 05-27-2004, 08:27 PM
earl's Avatar
Default NEW ENGINE BREAK-IN...Some new ideas
One of the most asked questions is how do I break in my new motor? The short answer is that no break-in is necessary. The only thing that is necessary is to seat the rings. All clearances and fitments should be perfect after blueprinting and precision assembly. So how many miles do you have to drive it to seat the rings? The cylinders are round, the rings are round, the bore is freshly honed and therefore your engine should be ready for tuning immediately. They will continue to seat better over a short period of time but you should be ready to go tune right away.
Do I need to drive it 500 miles before I tune it? Absolutely not. How about 50 miles? No. Perhaps the best thing to do is to drive it all the way to your trailer and tow it to a competent tuner. In second position on the “things NOT to do list” is trying to break in an un-tuned engine by driving it. Too lean an air/fuel will begin to heat and distort parts, too rich will wash the oil off the cylinders causing premature wear. What is in first place on the “things NOT to do list”? Boost on an un-tuned motor. Within 2 to 3 seconds the pistons and cylinders can be ruined.
Well I did put in a new base map or I’m just running off the stock Honda computer. Can’t I drive it like that for a few miles? I’m not even boosting. Well what is the base map? Just someone’s idea of what numbers will start your car. Just an educated guess by someone who does not have a clue what components you are running in your set-up. It’s not intended to drive on for any extended period of time. The same with that stock Honda computer. It could be ok but it could also be dangerously wrong.
So what exactly do I do at the first engine start-up? Pull the spark plugs and crank the motor with your starter for a maximum of 30 seconds or until you see the oil pressure gauge begin to register. Re-install the plugs and wires and fire up that candle. While keeping one eye on the oil pressure gauge, use your other eye to scan for fuel leaks. If there are no fuel leaks, look under the motor for any major oil or coolant leaks. If that is ok, run the engine for 5 to 10 minutes while keeping an eye on the temperature and pressure gauges. Keep the rpm’s between 1000-3000. Shut the engine down and double-check everything. You are now ready for tuning.
But my engine was already tuned from my previous set-up. Well, what happened to your previous set-up? Did you melt a stock piston or crack a cylinder? No problem because now you have forged pistons and sleeves? Wrong. Although you now have stronger components that will take more abuse, you are still not right on your air fuel mixture. Get that thing tuned properly ASAP.
OK, I did it my way instead of yours and now I’m burning a lot of oil. What happened? Well basically you scarred up the skirt of the piston, messed up the surface of the cylinder wall and maybe even egg shaped the cylinder. New pistons are tapered smaller on the top to larger at the bottom of the skirt. Your piston to wall clearance is measured at the bottom of the skirt. As the engine warms up to operating temperature, the upper portion of the piston begins to expand slightly. The bottom of the skirt does not expand much. When you boost in a lean condition, the upper part of the piston expands quickly. Since the ring land area is cut smaller than the tapered skirt below it, the first part of the piston that pushes into the cylinder wall is just below the oil ring. Thus you will see the worst scarring on your piston right under the ring lands where the excess heat is the highest
The more heat that is generated, the harder the piston pushes into the cylinder wall. The uninformed would blame the piston damage on bad piston to wall clearance. Untrue. If that were the problem, the damage would show up at the very bottom of the skirt. What has happened is that you have expanded your piston to the point that it has just ground itself into the cylinder wall. Keep expanding the piston by super heating it and it will push your cylinder egg shaped and maybe even balloon out the cylinder slightly. At the same time this is happening, your ring lands will begin to distort to where they will never seal properly again. Sometimes after doing this, the engine will still run but it will be a smoker. This all happens in a few seconds of high boost with a lean air fuel ratio. Also it can happen from 500 freeway miles of driving where the tune up is off enough to build excess heat at a slower rate, thus doing the same damage over a longer period of time…but the end results are the same. Death to your pistons and cylinder walls.
OK, I’m just going to turn the fuel pressure way up and run extra fat, that way I won’t hurt anything. If you run too rich, you will “wash out” the rings. First, excess fuel will run down the cylinders taking the lubricating oil with it. This promotes direct metal-to-metal contact between the rings and the cylinder wall. This contact does several things. The upper ring begins to wear quickly. The middle ring is actually designed as a tapered oil scraper (it is not used for compression control at all) and the taper will begin to wear down to where it becomes flat rather than angled. When that happens, it can no longer control oil away from the combustion chamber. The last thing that happens is that pretty cross hatch design begins to wear off of the cylinder wall. While most people think that the cross hatch is there to help seat the rings, it also has a secondary purpose. That is to hold microscopic amounts of oil in the grooves to help lubricate ring to cylinder walls. With the walls smooth and no oil control help from the middle ring and a tired upper ring, oil will begin to mix with fuel in the combustion chamber. When this happens, your 93 octane fuel probably hits a value of about 80. Then detonation comes into play and begins to beat holes in the pistons, among other things.
So whom can I blame for this mess? The blind machinist that honed my piston to wall clearance? That poor quality Brand X piston manufacturer? The idiot pro engine builder that assembled my block? My ex-friend that helped me put this all together? Those ignorant engineers that gave me a bad base map with my engine management system? The guy on the internet message board whose buddy knows that it takes at least 1000 miles of break in before you can tune an engine properly? All of the above? Probably none of the above. Go look in a mirror and ask…who started this engine and had no idea what the air fuel ratio was? Who just wanted to jump on it one time to see if it would haul? Who didn’t know that their injectors were at 100% duty cycle at 4000 rpm but they wanted to see how it would run at 6000 rpm? Why it was you. Get that thing tuned right away. You will notice that the more you drive a tuned motor, the stronger it will feel. This is just the rings seating in their final 5-10% as they thank you for tuning first.
Old 05-27-2004, 08:30 PM
Trak_Day's Avatar
Very useful information! I am glad this was posted. I am nearing completion of my motor and want it running asap!
Old 05-27-2004, 08:31 PM
Mad Cow's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (earl)
Just in time for my motor!
Old 05-27-2004, 08:36 PM
94gsr4dr's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (Mad Cow)
earl saves the day
EDIT-make this a sticky
Old 05-27-2004, 08:38 PM
buck02's Avatar
best post yet i saved this on motor break in
Old 05-27-2004, 08:39 PM
B18C1CYA's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (jerseykid609)
well earl you have learned me on this and i am going to use your method , well i guess i will have to get a rollback well its worth it to wait and do it right
Old 05-27-2004, 08:40 PM
Better than steak
Arturbo's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (94gsr4dr)
I would still break in my motor with miles. I feel an engine needs to be heat treated. Just my opinion and this wouldnt be the 1st time we had difference of opinions.
Old 05-27-2004, 08:43 PM
sneakypete's Avatar
Good info earl. I have a quick question though. Is it okay to start the newly built engine on a previous tune? I know you said to not drive the car around without it being tuned first. Also do you recommend changing the oil after the 5-10 minute start up?
Old 05-27-2004, 08:48 PM
el arbi's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (sneakypete)
Wow...excellent write up man. Thanks alot
Arbi, who actually learned something there
Old 05-27-2004, 08:58 PM
Rod.'s Avatar
This is real good info. I almost got my motor completed. Now I feel like I was ripped getting that base map burned now
Old 05-27-2004, 09:00 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakypete &raquo;</TD></TR><TR><TD CLASS="quote">Good info earl. I have a quick question though. Is it okay to start the newly built engine on a previous tune? I know you said to not drive the car around without it being tuned first. Also do you recommend changing the oil after the 5-10 minute start up?</TD></TR></TABLE>I believe the important thing is to not put a load on the untuned engine but if you are running extremely rich, you could wash out the rings quickly at idle.
Old 05-27-2004, 09:05 PM
HXMan's Avatar
Very good post.
How would you suggest driving a long distance to a tuner with a stock engine? Drive there on basemaps, or drive there with the stock ecu and be very carefull not to hit any boost?
Old 05-27-2004, 09:09 PM
earl's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I would still break in my motor with miles. I feel an engine needs to be heat treated. Just my opinion and this wouldnt be the 1st time we had difference of opinions. </TD></TR></TABLE>It already is a seasoned block and crank. Everything else is to perfect spec already. I did say at the end of the post that the engine's rings will continue to seat during the first 500 or so miles. It's that feeling you get when the motor keeps feeling stronger each week. Higher compression with the better seal. What I am preaching is that it is better to tune first than to chance ruining your new motor.
Old 05-27-2004, 09:10 PM
earl's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Very good post.
How would you suggest driving a long distance to a tuner with a stock engine? Drive there on basemaps, or drive there with the stock ecu and be very carefull not to hit any boost?</TD></TR></TABLE>U-Haul tow dolly
Old 05-27-2004, 09:15 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">U-Haul tow dolly</TD></TR></TABLE>
or a roomate with a truck
Old 05-27-2004, 09:20 PM
june's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (Flamenco-T)
Thanks for the info Earl.
June
Old 05-27-2004, 09:27 PM
V-SPEC 1's Avatar
pretty interesting.
Old 05-27-2004, 09:31 PM
Better than steak
Arturbo's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (june)
A LEV perfectly tuned car from honda still recomends a break in. They have millions of dollars of machine work than what most people have in there machine shops to make everything perfect. Even with a perfectly tuned motor from Honda requires a break in. I just dont think Honda would print that just to take up space in an owner's manual.
I do agree that an engine must be perfectly tuned. Honda tunes their cars pretty conservative at around 11.8:1 AFR. Also, take note that running too rich can cause you to detonate too..
art
Old 05-27-2004, 09:40 PM
ki11a8ee's Avatar
Great Info Earl
Old 05-27-2004, 09:43 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">A LEV perfectly tuned car from honda still recomends a break in. They have millions of dollars of machine work than what most people have in there machine shops to make everything perfect. Even with a perfectly tuned motor from Honda requires a break in. I just dont think Honda would print that just to take up space in an owner's manual.
art</TD></TR></TABLE>
Completely different situation. They have thousands and thousands of engineering tuning hours designing their ecu for proper fuel ratios under any load or condition. This is meant for the average H-T that is building a high performance engine for the first time. You are missing the point.
Old 05-27-2004, 09:51 PM
1316130057's Avatar
"Meltdown" Something I've been trying to illustrate for the longest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> Higher compression with the better seal.</TD></TR></TABLE>
Something else I've been preaching for the longest. Good to see that someone else with experience agrees compared to the average comic book reader turned H-T member.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Completely different situation. They have thousands and thousands of engineering tuning hours designing their ecu for proper fuel ratios under any load or condition. This is meant for the average H-T that is building a high performance engine for the first time.</TD></TR></TABLE>
I can understand Arturbo's P.O.V. If you take a peek into the break-in procedure for an S2k, Honda does all but tell you to beat the living crap out of the car. I'm confident that this isn't something that they'd recommend if it weren't a neccessity.
Old 05-27-2004, 09:54 PM
leadfoot78's Avatar
awasome post earl, here are some pics of the motor I have been asking u all the questions about.
u can even see the piston stick out a tinny bit in this pic. but i got a .045 Cometic gasket, should be save.
[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNDA3NTYzNnM0MTNkmQzMXk1NDE%3D.jpg[/img
Modified by leadfoot78 at 9:17 AM 9/20/2004
Old 05-27-2004, 09:59 PM
Better than steak
Arturbo's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (leadfoot78)
I am missing the point..
Old 05-27-2004, 10:00 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> I did say at the end of the post that the engine's rings will continue to seat during the first 500 or so miles. It's that feeling you get when the motor keeps feeling stronger each week. Higher compression with the better seal. What I am preaching is that it is better to tune first than to chance ruining your new motor.</TD></TR></TABLE>
well if you tune it right from the get go...then drive around with the rings gradually seating, essentially raising the compression like you said...wont that throw off the tune a bit also? or is it not enough to effect it?...if you can litterally feel a difference in the cars performance as the rings seat more, i would think that would be enough to alter the tune...at least a little
Old 05-27-2004, 10:10 PM
earl's Avatar
Default Re: NEW ENGINE BREAK-IN...Some new ideas (gritsak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">
well if you tune it right from the get go...then drive around with the rings gradually seating, essentially raising the compression like you said...wont that throw off the tune a bit also? or is it not enough to effect it?...if you can litterally feel a difference in the cars performance as the rings seat more, i would think that would be enough to alter the tune...at least a little</TD></TR></TABLE>You would have to adjust tuning slightly to the changes after a period of use. But my point is to help people make it properly thru the first 1000 miles so that they have the chance to fine tune.
Quick Reply: NEW ENGINE BREAK-IN...Some new ideas
