How to: change thermostat
Old 05-26-2004, 04:58 PM
  #26
JDMlyfestyle's Avatar
i put the jackstands in after i put the drain pan in. cause i didnt wanna have to move the jackstand if it was in the spot for the drain pan. note in the supplies i put jackstands :-D
Old 05-26-2004, 05:03 PM
  #27
Boba Connoisseur
SkyeC's Avatar
Default Re: (JDMlifestyle)
Where do you put your jackstands? I just put mine under the side jackpoints and jack it up either in the front jackpoint or rear... easier that way.
Old 05-26-2004, 05:12 PM
  #28
Default Re: (SkyeC)
Old 05-26-2004, 05:20 PM
  #29
poison's Avatar
Default Re: (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Not True. IF you are idling in hot weather (aka FL) the coolant/water will rush though the radiator too fast for it to be cooled. Your car will overheat if it idles for a long period of time without a thermostat (depends on the cooling system too, AKA if you have a good system, it will take long to over heat BUT it will overheat). </TD></TR></TABLE>
I stand corrected on that part, haven't been to FL
That's why I throw in a plate I was describing earlier
Old 05-26-2004, 05:33 PM
  #30
Turbogixxer's Avatar
Default Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">That's why I throw in a plate I was describing earlier </TD></TR></TABLE>
Yea, that works great.
Old 05-26-2004, 05:45 PM
  #31
........'s Avatar
no thermostat in texas in 120 degree weather = dead honda.
Old 05-26-2004, 08:03 PM
  #32
duh blacksheep's Avatar
what kind of bull **** is that? if your coolant goes through the radiator too fast, you will have excessive cooling...and your engine cant over heat beacuse its cooling more volume/minute
Old 05-26-2004, 08:05 PM
  #33
Boba Connoisseur
SkyeC's Avatar
Default Re: (duh blacksheep)
If it goes through too fast, the radiator doesn't have time to dissipate the heat in the coolant.
Think about it.
He's right, you're wrong.
Old 06-01-2004, 02:02 PM
  #34
i did a test on the the car. the car ran for 43 mins before the temperature gauge went past its normal spot. as soon as i got on it the temperature gauge dropped dramatically.
Old 06-01-2004, 02:14 PM
  #35
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">i did a test on the the car. the car ran for 43 mins before the temperature gauge went past its normal spot. as soon as i got on it the temperature gauge dropped dramatically. </TD></TR></TABLE>
You mean you give the car throttle and the temp went down? You are not running a thermostat?
Old 06-01-2004, 02:35 PM
  #36
i have a thermostat with 5 1/16th holes drilled in it. and the temperature went down when i drove the car. the temperature will be fine at idle while its parked if i turn the fan on.
Old 06-05-2004, 08:34 PM
  #37
nope its sounds like ur Temperature sensor may have went bad or something happened to the connection. unless ur not running a thermostat
Old 06-06-2004, 06:37 PM
  #38
on my b16 its located right below the distributor. it has a rubber boot on it. and its a single wire. really tiny
Old 06-14-2004, 12:18 PM
  #39
JDM PRO's Avatar
Default Re: (l Hybrid l)
is there a proper way to refill the radiator after installing the thermo?
Old 06-14-2004, 12:48 PM
  #40
Default Re: (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">is there a proper way to refill the radiator after installing the thermo?</TD></TR></TABLE>
You open the 10mm bleeder screw on top of the thermostat housing and fill the radiator slowly. If you fill it too fast, you will create a huge bubble in the engine block and the engine will overheat. Of course you closed the bleeder screw when you are done filling it.
Old 08-09-2004, 09:14 PM
  #41
* B A N N E D *
Redline96LX's Avatar
Default Re: How to: change thermostat (JDMlyfestyle)
Nice write up. And gee, what a nice exhaust system, sure there isnt anything missing in it???
Old 08-09-2004, 11:46 PM
  #42
Xxcivic99xX's Avatar
is there any sort of gasket for the thermostat housing?
Old 12-13-2004, 08:00 AM
  #43
ScubaStevo80's Avatar
EDIT - nevermind I missed the bracket in the picture.... estupido mio
Modified by VolpeOwnsU at 3:46 PM 12/20/2004
Old 12-20-2004, 11:43 AM
  #44
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">then sprayed the thermostat with 110PSI of air to insure that all metal shavings are off the thermostat.</TD></TR></TABLE>
Now thats technical..
Old 12-20-2004, 12:07 PM
  #45
Cray91's Avatar
Default Re: How to: change thermostat (Redline96LX)
damn you replaced the entire center section of you exhaust. My "test" pipe replaced just the cat.
nice write-up. Seems a little trivial IMHO. But nice job anyway.
Old 12-20-2004, 12:35 PM
  #46
i have the RSR GTII exhaust with AN-R and its all straight no restrictions at all
Old 12-20-2004, 12:38 PM
  #47
Solracer's Avatar
Default Re: (JDMlyfestyle)
Question for some one, ever since I put a new stock Thermostat in my car, the CEL comes on I belive it throws a code 13 or 14, did I forget to hook something back up? If I turn the car off and turn it back on when it gets warmed up the CEL goes away, any ideas? Car Runs Fine.
Old 12-20-2004, 12:42 PM
  #48
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
to be honest i have never had any experience with the code 13.
the code 14 is prolly cause of the filter/screen on the IACV needs a cleaning.
Old 12-20-2004, 07:56 PM
  #49
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">13 BARO - atmospheric pressure sensor
the code 14 is prolly cause of the filter/screen on the IACV needs a cleaning.</TD></TR></TABLE>
It just seems wierd that it started after I change my thermostat, I checked again and I seems to be a code 14 ICA. Where is the filter/screen that needs to be cleaned?
Old 12-20-2004, 08:28 PM
  #50
the idle air control valve is on the back of the intake manifold. if you are looking at the engine the sensors on the manfiold will be in this order
MAP TPS IACV
it will have a black cylinder on it. remove the 2 12mm bolts and remove the 2 coolant hoses on the IACV. then there will be a screen. use some carb cleaner or brakleen. i use the sea foam parts cleaner..
Then reinstall the iacv and be sure to bleed the cooling system when your done cause u have allowed the cooling system to get air into it.
Quick Reply: How to: change thermostat
