Old 05-14-2004, 08:56 AM   #1
RyanEJ8
RyanEJ8's Avatar
Default D-Series Camshaft and Valve Spring Install Write-Up (Lots of pics)
Camshaft/Valve Spring Install Write-Up
This is a technical write up to inform you of how a camshaft and valve spring install is done with the cylinder head on the car. The install was done on a SOHC VTEC D16Y8 head. For the most part, this can be helpful with all Hondas, but of course there are differences between a VTEC and a non-VTEC head, and a SOHC or DOHC head. With that said, if you have anything other than a D16Y8 head I would recommend consulting another manual for at least the torque specs.
PARTS AND TOOLS:
The parts used in this install are the ZEX #105300 camshaft and ZEX #912-16 valve springs. The specs on them are as follows:
ZEX D16Y8 #105300 Camshaft
VTEC Intake/Exhaust
Advertised Duration 260/268
Duration @ .050 220/216
Max Valve Lift .455/.430
Centerline 107/111
Lash .007/.009
ZEX D16Z6/D16Y8 #912-16 Valve Springs
.896" Outside Diameter
.600" Inside Diameter
Installed 50 lbs @ 1.950", Open 170 lbs @ 1.050"
Spring Rate 240 lbs/in
Coil Bind Height 1.360"
Single Spring coil for both intake and exhaust
Here is a comparison of the stock spring next to the ZEX spring.
You will need a valve spring compressor to perform this job. I used a Sears Craftsman overhead valve spring compressor. A few modifications needed to be made to the valve spring compressor in order for it to be used with the 4 valve per cylinder Honda head. (Don't make fun of my excellent MS Paint skillz. )
You will also need a compressed air source and an adapter for the spark plug tube. Many cylinder compression gauges utilize a screw-in fitting that may work with your air hose quick-disconnect fitting. I removed the one-way valve from my Actron compression tester and used it.
These are the other tools you'll need.
1.) Metric socket set
2.) Ratchet and extensions
3.) Timing light
4.) Torque wrench
5.) Feeler gauge
6.) Flathead screw driver
7.) Break-in lube (generally supplied by camshaft manufacturer)
INSTALLATION:
1.) Remove the valve cover.
2.) Set the engine at TDC for cylinder #1 and remove the cam gear.
3.) Remove the spark plug wires. Then unplug the distributor and remove the 3 bolts holding it to the head.
4.) Loosen the rocker arm assembly bolts a 1/4 turn each in the correct order until the spring pressure is relieved, but do not completely remove the bolts from the rocker arm assembly or it will start to fall apart on you.
5.) Lift the rocker arm assembly from the head.
6.) Lift out the stock camshaft. It's going to drip oil everywhere, so you might want to have a couple shop towels ready.
7.) At this point you'll want to take a look at the contact faces and adjuster tips of the rocker arms and make sure there is no excessive wear. Then take a look at the camshaft bearing surfaces on both the head and the rocker arms. Make sure there are no deep scratches or wear.
8.) Remove the spark plug in the cylinder you are about to install valve springs on, then thread the adapter into the spark plug hole and connect an air hose from a compressed air source.
9.) The valves should be held in place by the air pressure now. Stuff bits of paper towel in all your oiling holes and anywhere the keepers could fall into. Make sure it's a big enough wad where it won't soak up too much oil and fall into your engine.
10.) Use the valve spring compressor to compress the spring and remove the keepers with a magnetic screwdriver. I had a better picture of this, but don't know what the hell happened to it.
11.) Lift the valve spring and retainer from the head with the spring compressor.
12.) Compress the new valve spring with retainer using the spring compressor. (The retainer is not pictured here, I was only testing the spring compressor fitment at the time the picture was taken.)
13.) Place the end of the spring with the most closely wound coils towards the cylinder head and carefully place the keepers in between the valve stem and spring retainer.
14.) Relieve the pressure from the valve spring compressor and make sure the keepers are seated properly.
15.) Repeat steps 10-14 for the rest of the valve springs in the cylinder you are working on, then repeat the process for the other 3 cylinders.
Here are the ZEX valve springs installed.
16.) Clean the camshaft, the bearing surfaces in the head and the rocker arms. Remove any dirt with a clean, lint-free cloth.
17.) Lubricate the camshaft bearing surfaces in the head and rocker arms and the lobes on the camshaft thoroughly with the provided assembly lubricant. Install the new camshaft seal with the open side facing in. Now carefully lower the camshaft into the head.
Put a drop of camshaft assembly lubricant on the bearing surfaces here, make sure your fingers are clean, and rub it in some.
Make sure the camshaft is thoroughly lubed and set it in just like this.
18.) Apply sealant to the cylinder head contact surfaces next to bearings 1 and 5 and install the rocker arm assembly. Make sure everything lines up properly.
19.) Hand tighten the rocker arm assembly bolts a little at a time, in the proper sequence. Then torque them to Honda's torque specifications in two or three steps, in the proper sequence.
D16Y8 Rocker Arm Assembly Torque Sequence and Specifications
19.) Place the cam gear and keyway on the end of the camshaft and torque it down. Make sure the cam gear is lined up at TDC with a straight edge. You will also want to check to make sure the bottom end is still lined up TDC as the air pressure may have moved it some. Now slip the timing belt back on and make sure it is tensioned properly.
20.) Put a new seal on the distributor and reinstall it. Make sure you have not turned it around 180 degrees.
21.) Now adjust the valve clearance to specifications.
21.) Rotate the crankshaft counterclockwise by hand for two complete revolutions. Recheck the alignment marks on the cam gear and crankshaft. The timing marks should still be aligned. If they're not, remove the timing belt and set all the timing marks again.
22.) Torque the valve cover down and make sure all hoses, grounds, covers, and spark plugs/wires are installed at this point and you're ready to start her up! Have the timing light handy and be ready to set your timing when the engine reaches operating temperature.
I will probably be editing this some over the next few days as I might find something I want to add or change, so please give any comments or suggestions.
Modified by RyanCivic2000 at 11:13 PM 5/14/2004
2000 Honda Civic EX Coupe D16Y8, 12.80@105.8 14 psi SOLD
2004 Ford F150 XLT Supercab Triton V8
RyanEJ8 is offline Report Post   Reply With Quote
Old 05-14-2004, 08:59 AM   #2
Buktheng
Buktheng's Avatar
Send a message via AIM to Buktheng
Nice job on the write up!
Yezzir!
Buk Ha Nee Bai Gyn Kee Tat!
Buktheng is offline Report Post   Reply With Quote
Old 05-14-2004, 09:09 AM   #3
JCracer723
JCracer723's Avatar
Send a message via AIM to JCracer723
Default Re: (RyanCivic2000)
dopeness
JCracer723 is offline Report Post   Reply With Quote
Old 05-14-2004, 09:20 AM   #4
Built to Spill
el diablo
Built to Spill's Avatar
Default Re: D-Series Camshaft and Valve Spring Install Write-Up (RyanCivic2000)
I have the same zex cam w/ crower valve springs and retainers....i love it, but The only problem i had was that with mild tuning, i couldnt make power past 7k with my setup. I believe the problem is with the cam...alot of other people have had problems with the cam not making any power after redline also.
But great write-up
-Richard
My Vouch Thread
Built to Spill is offline Report Post   Reply With Quote
Old 05-14-2004, 09:46 AM   #5
gitwidit
gitwidit's Avatar
Default Re: D-Series Camshaft and Valve Spring Install Write-Up (Built2Spill)
Nice job Ryan
Very informative and good pics.
Another Retired Setup- 400whp, 304wtq D16
http://www.turbod16.com
http://www.lovefab.com
gitwidit is offline Report Post   Reply With Quote
Old 05-14-2004, 10:02 AM   #6
ELSpool
ELSpool's Avatar
Sweet job Ryan!
Acura 1.6EL - D16Y8
11.22@125mph - Sold
ELSpool is offline Report Post   Reply With Quote
Old 05-14-2004, 11:01 AM   #7
BauleyCivic
Risky Business
2005 Toyota Corolla
BauleyCivic's Avatar
Send a message via AIM to BauleyCivic
Default Re: (ELSpool)
Great information here
My comprehensive preview of the 2010 Formula 1 Season
http://www.honda-tech.com/showthread.php?t=2676702
BauleyCivic is online now Report Post   Reply With Quote
Old 05-14-2004, 11:02 AM   #8
thenick
thenick's Avatar
Send a message via AIM to thenick
we should colaborate all the sohc faq's into one massive SOHC upgrade thread....good job man
fairisfoulandfoulisfairhoverthroughthefogandfilthy air.
thenick is offline Report Post   Reply With Quote
Old 05-14-2004, 11:56 AM   #9
Krayzielix
Krayzielix's Avatar
Send a message via AIM to Krayzielix
Default Re: (ixiblindixi)
Krayzielix is offline Report Post   Reply With Quote
Old 05-14-2004, 12:12 PM   #10
civicminded92
civicminded92's Avatar
Thanks for sharing
Good job!!
1992 VX with D16Z6 motorvation
SOHCHONDA.COM
civicminded92 is offline Report Post   Reply With Quote
Old 05-14-2004, 12:21 PM   #11
AlphaQup
AlphaQup's Avatar
Send a message via AIM to AlphaQup
Default Re: (k12ayz1e)
Good sh*t!! I'll be doing this soon. How much does the cam and springs run? Also how noticable are the hp gains?
Excellent Write-up
HID retrofit club
member #0047
AlphaQup is offline Report Post   Reply With Quote
Old 05-14-2004, 12:33 PM   #12
drewbie
drewbie's Avatar
Send a message via ICQ to drewbie Send a message via AIM to drewbie
Default Re: (AlphaQup)
awesome i needed this.
how much did the valve springs run?
2008 Race Engineering Rookie of the Year.
www.raceengineering.orgwww.ctbrakes.com
See me on trackdaze's August VIR 2008 section. Teal hatch
drewbie is offline Report Post   Reply With Quote
Old 05-14-2004, 12:45 PM   #13
kadburry
kadburry's Avatar
Default Re: (Mr. Teal)
good write up
<U>vouch thread</U>
http://www.honda-tech.com/zerothread?id=905264
kadburry is offline Report Post   Reply With Quote
Old 05-14-2004, 12:50 PM   #14
A D NOH
A D NOH's Avatar
Default Re: (kadburry)
great write up!!!!
Any dyno tuning in the future?
A D NOH is offline Report Post   Reply With Quote
Old 05-14-2004, 01:07 PM   #15
Turbogixxer
Turbogixxer's Avatar
Default Re: (JDM EK9)
great write up ryan
Turbogixxer is offline Report Post   Reply With Quote
Old 05-14-2004, 01:33 PM   #16
Nsane1
Nsane1's Avatar
Location: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Default Re: (turbogixxer)
Excellent Write-up
PS3 Gamertag: Nsane1
Reppin' Western KY:http://www.honda-tech.com/zerothread?id=1554136
If your from Western KY or surrounding areas, check us out:http://www.westkyimports.com
Nsane1 is offline Report Post   Reply With Quote
Old 05-14-2004, 01:43 PM   #17
743power
743power's Avatar
Send a message via AIM to 743power
Default Re: (VogueSilverHX)
cool, I have heard from a couple of reliable sources that the OEM z6 springs are plenty capable for hi lift/rpm, and they also have a pretty high coil bind # from what I have seen. I need to replace the springs on a z6 head I have because they have some rust on them.
How much did the zex springs cost?
Thanks for the writeup, lets keep this kinda stuff alive in this forum.
"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
-Albert Einstein
743power is offline Report Post   Reply With Quote
Old 05-14-2004, 01:54 PM   #18
Street Ghost
Street Ghost's Avatar
Good write-up.
Street Ghost is offline Report Post   Reply With Quote
Old 05-14-2004, 02:24 PM   #19
Caveman74
Caveman74's Avatar
Send a message via AIM to Caveman74
Default Re: D-Series Camshaft and Valve Spring Install Write-Up (JDM Ninja)
Swell write up, Very informative
06' Nighthawk Black Pearl Civic Si
207.6 HP -- 150.7 TQ
S2000 Retro w/ Maxima Fog Retro
Caveman74 is offline Report Post   Reply With Quote
Old 05-14-2004, 02:30 PM   #20
EKsite
EKsite's Avatar
Great write up!
Originally Posted by JMU R1
The number one technical problem with sport bikes is handlebar actuator malfunction.
2005 YZF-R6
EKsite is offline Report Post   Reply With Quote
Old 05-14-2004, 03:43 PM   #21
blackeg
blackeg's Avatar
im down for that
when i was doing valvetrain shizzy, i had the same problem about the spring compressor- it was too fat and kept popping out of the spring.
did you re-adjust your valve lash too after this??
top notch write up man
hx coupe 2652lbs - lsvtec--318whp/241wtq
12.54@115.57 on bfg's
92 hatch---415whp/300wtq in '07
425whp/286wtq in '08 2410lbs
12.1@125.5 1bar boost @etown fall nats
blackeg is offline Report Post   Reply With Quote
Old 05-14-2004, 04:47 PM   #22
RyanEJ8
RyanEJ8's Avatar
Default Re: (blackeg)
Thanks for all the compliments guys.
Valve lash adjustment is step 21 of my write-up.
I got the ZEX cam for $255 and the valvesprings for $165.
Old 05-14-2004, 04:54 PM   #23
Eee Pee
Eee Pee's Avatar
Send a message via AIM to Eee Pee
Good job Ryan.
Few for ya...
Race hatch 94 EP #13
Other hatch '02 EP3
Eee Pee is offline Report Post   Reply With Quote
Old 05-14-2004, 06:46 PM   #24
Ricey McRicerton
Moderator
Ricey McRicerton's Avatar
Default Re: (Eee Pee)
Incredible writeup. It's great to see threads like this.
09 SI Sedan
Ricey McRicerton is offline Report Post   Reply With Quote
Old 05-14-2004, 06:55 PM   #25
Tad
good shit man
Tad
SOHC luva!
Tad is offline Report Post   Reply With Quote
Bookmarks
2000, adjusting, adjustment, camshaft, civic, compressor, d16y8, head, honda, install, series, sohc, spring, springs, triton, v8, valve
