Replacing valve seals with head on
Old 05-09-2004, 07:06 PM
quiksheit's Avatar
Default Replacing valve seals with head on
Hi, I recently had to change my headgasket. I ran out of time before i could ever do the valve seals and i really regret it. I ve searched and couldnt find anything that tells how to do it with the head still on. Checked helms too. Please help. Isnt there a valve spring compressor for having the head still on?? People talk about the compressed air and rope trick but no one is very specific.
TIA
Old 05-09-2004, 08:30 PM
cougar10ag's Avatar
theres an adapter you cna buy that hooks to an air hose thats screws into the spark plug hole.. if not take an old spark plug. smash the **** out of the porcelin wiht a hammer. and weld on an air adapter. seal it, chekc for leaks and use that.
basically you set each cyl at TDC, screw the adapter in the hole and compress with air.. i dunno how much PSI you need exactly. guess 60psi should be enough. then proceed to work on the walves.
Old 05-10-2004, 08:16 AM
quiksheit's Avatar
Default Re: (cougar10ag)
Thanks... but what about the compressor?? What should i use to get at em with the head still on??
Old 05-10-2004, 08:25 AM
frenchy's Avatar
Default Re: (quiksheit)
in my helms the directions for changing the valve seals is with the head on - it also lists the snap-on p/n for the spring compressor in the tools list
Old 05-10-2004, 05:59 PM
kelly's Avatar
Default Re: (frenchy)
http://www.thetoolwarehouse.net/shop/SP-91400.html
Old 05-10-2004, 07:27 PM
frenchy's Avatar
Default Re: (kelly)
thats the one - probably a third of the price of the snap-on one - welcome to h-t kelly
Old 05-10-2004, 08:14 PM
tilt's Avatar
Default Re: Replacing valve seals with head on (quiksheit)
here is the rope trick. i did this since the air compressor thing was way too exp imo.
remove spark plugs
pick a cylinder you want to work on. set the crank off tdc
stuff the rope through the spark plug hole - you can use a long screwdriver or a wooden stick if you are afraid of damaging the threads.
turn the crank back towards tdc - you will feel the crank stop turning, if not you didnt put in enough rope.
now the valves are safe from falling in
do whatever it is you need to do - replacing the valvesprings, retainers, etc.
turn the crank off tdc, pull the rope out
repeat process for the remaining cyls
CA121
12
03-15-2011 10:43 AM
MIsterE533
10
09-14-2010 07:18 PM
dkk119
03-13-2006 06:27 PM
ricearoni56
16
06-19-2004 09:16 PM
MisterB
06-04-2003 09:31 PM
Quick Reply: Replacing valve seals with head on
