How to get hood open? Hood latch broken!
Old 05-06-2004, 05:31 AM
92BlackSi's Avatar
Default How to get hood open? Hood latch broken! NEED HELP ASAP!!
So a couple of weeks back I found out that my hood latch cable was stretched so I had to cut it halfway and manually pull the cable to open the hood. Now the cable is all fugged up and not working and the hood is shut. Is there a way for me to get the hood open without the use of the cable at all???
Modified by 92BlackSi at 2:01 PM 5/11/2004
92BlackSi is offline
Old 05-06-2004, 06:42 AM
zman's Avatar
Default Re: How to get hood open? Hood latch broken! (92BlackSi)
Just get up under ur hood with a screwdriver and push the latch open with the screwdriver. It kinda takes a bit of patience, but once u do it once u'll be able to do it again no problem. I used to have to do it to Saturn Ions all the time cause their hood latch cables broke when it got cold outside.
zman is offline
Old 05-06-2004, 06:55 AM
Andres-eh2's Avatar
correct!
Andres-eh2 is offline
Old 05-06-2004, 07:00 AM
Yeung's Avatar
Default Re: (Andres-eh2)
yep screwdriver.. thats how some theives get under the hood..
Yeung is offline
Old 05-06-2004, 07:41 AM
hatchdrvr's Avatar
Default Re: (Yeung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yeung &raquo;</TD></TR><TR><TD CLASS="quote">yep screwdriver.. thats how some theives get under the hood..</TD></TR></TABLE>
What? no crowbar? sawzall? C4?
Just park it in a bad area of town overnight, I guarantee someone will help you open your hood.
hatchdrvr is offline
Old 05-07-2004, 05:42 AM
92BlackSi's Avatar
Default Re: How to get hood open? Hood latch broken! (zman)
Cool thanks boys will try that out!
Old 05-11-2004, 09:59 AM
92BlackSi's Avatar
K guys I just dived under the car to check out the screwdriver idea. Two things:
1. Where exactly are you putting the screwdriver? The only access to the latch area is through the bumper grill. I can just barely get my hand through the grill but once in no further.
2. You can't see the hood latch, so even if I got in there somehow where would I put the screwdriver??
I need some MAJOR HELP HERE! I don't want to have to do something sick to the hood!!
Old 05-23-2004, 08:53 PM
akaEsCo01's Avatar
bump, i am having the same exact problem
akaEsCo01 is offline
Old 05-23-2004, 09:32 PM
jigjew's Avatar
Default Re: (akaEsCo01)
just follow your hood latch cable and you'll see the "hook" that it is connected to on the latch. Then place the screwdriver in such a way that you will move it the same direction as the cable normally would. Bingo!
jigjew is offline
Old 05-23-2004, 09:40 PM
JDMlyfestyle's Avatar
i love my 22" pry bar. it gets any thing open. thats y i call it the key to the city
JDMlyfestyle is offline
Old 05-24-2004, 10:48 AM
92BlackSi's Avatar
Default Re: (jigjew)
Yeah I got her I needed to remove all the plastic peices underneath to see the latch.
Old 05-24-2004, 08:22 PM
akaEsCo01's Avatar
Default Re: (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I got her I needed to remove all the plastic peices underneath to see the latch.</TD></TR></TABLE>
how did you do it??? i still can't get mine and i cut out my grill too, i have a 97 civic, but i don't think it is any different from a 93...or is it???
Old 05-24-2004, 09:21 PM
4door_gsr_ftw's Avatar
Default Re: (hatchdrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchdrvr &raquo;</TD></TR><TR><TD CLASS="quote">
Just park it in a bad area of town overnight, I guarantee someone will help you open your hood.</TD></TR></TABLE>
The number one way for the lazy people...
4door_gsr_ftw is offline
Old 10-15-2004, 09:52 PM
8point6's Avatar
Default Re: (Pacman88)
Another easy way to open the hood, assuming the cable is in its stock location, would be to remove the top of the fender liner, reach between the liner and the fender, grab the cable and yank it toward the rear of the car.
8point6 is offline
Old 10-16-2004, 06:53 PM
billyhoe's Avatar
Default Re: (8point6)
on my civic i just reach throught the middle of the bumper a lil more towards the passenger side and feel for the cable (thin hard line) then just give it a yank to the left
billyhoe is offline
Old 10-16-2004, 11:11 PM
str8cyko's Avatar
if the cable is completely unattached from the latching mechanism, it would be useless to pull the cable. the screwdriver/crowbar would be the tool to use along with a jack.
tuan
str8cyko is offline
Old 07-16-2016, 03:06 PM
Aryez123's Avatar
K so i have an 04 honda civic and the cable broke off there is no cable at all so what now HELP
Aryez123 is offline
Old 07-16-2016, 04:40 PM
Stancetard Hate Monger
eghatch9295's Avatar
old thread is old. forum choice is wrong. go away.
eghatch9295 is offline
Old 07-19-2016, 05:38 AM
Oh look, I can change this
deschlong's Avatar
Correct forum is for 7th Gen Civics.
Ancient thread closed.
deschlong is offline
haggecha
Honda Civic (2006 - 2015)
01-11-2019 04:23 AM
FritschDog
22
03-31-2017 08:41 AM
Slingah
10-04-2012 09:41 AM
EL Vap133
41
03-31-2004 02:08 PM
Quick Reply: How to get hood open? Hood latch broken!
